Old 08-25-2008, 10:49 AM   #13621
shadow102's Avatar
Trader Rating: 21 (96%+)
Originally Posted by t3amfish View Post
sorry, still new to the lingo... what is the C Hub? and do you have a picture of an upgraded one? i have to go down to the shop because i need a new spur gear.. so i might as well pick up a better C Hub while im there...
The c hub is the piece that looks like a big c that holds the front knuckles to the car and is attached by a hinge pin to the front a-arms. The pro4 and regular cyclone c hubs are what you want preferably the 4degree caster ones
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 08-25-2008, 11:39 AM   #13622
ShaunMac's Avatar
The 4 degree carbon graphite c-hub is part #HP73518.
C-Hubs, Steering Blocks, A-arms and Rear Hubs are some of the more common parts that will break in an impact. If you race somewhere that doesn't have HB parts in stock you might think about stocking up on these parts in case you break at the track.
ShaunMac is offline   Reply With Quote
Old 08-25-2008, 01:11 PM   #13623
are the rear hubs, front C hubs and steering blocks on the new TC the same as the morespeed earlier version? cheers
blueskieshlg is offline   Reply With Quote
Old 08-25-2008, 01:47 PM   #13624
RC MARKET's Avatar
Yes same !
New lot steering block & rear hub was arrived !
hope fixed new toe-in issue .
RC MARKET is offline   Reply With Quote
Old 08-25-2008, 03:31 PM   #13625
SammyZ's Avatar
Trader Rating: 138 (100%+)
yes the same parts!
SammyZ is offline   Reply With Quote
Old 08-25-2008, 03:54 PM   #13626
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
is there a thicker carpet chaasis for the TC availible yet?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 08-25-2008, 04:04 PM   #13627
Korey Harbke's Avatar
The currently available 3.6mm chassis is great for carpet racing and it fits on the TC without any modifications. If you are running on carpet with rubber tires the stock chassis is actually just perfectly fine.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-25-2008, 04:20 PM   #13628
bigb11's Avatar
I wanted to use the thicker chassis and two pro-diffs for carpet. if I can find a kit.
Old 08-25-2008, 04:51 PM   #13629
Kit's are due early September. Sounds like you might be running foam tires on carpet. The setup you were thinking of doing will be great. I would also suggest the 2.5mm upper deck and middle deck as well.
-Korey
Old 08-25-2008, 05:18 PM   #13630
bigb11's Avatar
thanks I will.
Old 08-25-2008, 05:49 PM   #13631
SammyZ's Avatar
-Korey
i had that setup in my cyclone and it was awsome
Old 08-25-2008, 10:28 PM   #13632
hanzo3's Avatar
Trader Rating: 55 (100%+)
I just picked up a second hand cyclone black. The car has a front one-way installed as well as a center one-way. Was it worth it to get or should I have gotten the TC? The brushless motor mount is $50.
Is there a asphalt top deck and chassis? or is it designed for it?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 08-25-2008, 11:07 PM   #13633
mangoman's Avatar
The brushless motor mount is only needed for 6 cell modified motors (like a 3.5).
You may need to upgrade to the new center pulleys though if you are planning on running 17.5.
And the cyclone is an Asphalt weapon as it is.... stick with the existing decks.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-25-2008, 11:43 PM   #13634
cyclone speed's Avatar
just a quick question , the cyclone TC has an 18 tooth pulley and the moorspeed an 16 tooth pulley .what would be best for modified racing 5.5 brushless .
And also does the TC has an 18 tooth pulley only for the front belt or on both belt (i know that sounded like a silly question but i wasnt sure) and whats the advantage of the 18 tooth pulley
thanks in advance
cyclone speed is offline   Reply With Quote
Old 08-25-2008, 11:59 PM   #13635
SammyZ's Avatar
the cyclone moorespeed has 16t pulley's and the new TC has the 18t pulley's You can put 18t pulley's on any car if you want. the 18t pulley's bring your DTR to 2.166 but if you were using the 16t pulley's your DTR will be 2.4375 i think.
Whatever you do, get the 18t pulleys. yes both pulley's on the TC are 18t.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
