Old 08-22-2008, 05:02 PM   #13591
pcar951's Avatar
Trader Rating: 19 (100%+)
Default Why?
I'm looking at the pics of the dope wiring jobs (very nice), just wondering why nobody drills their ball cups so you don't have to pry them of for adjustments?
pcar951 is offline   Reply With Quote
Old 08-22-2008, 05:56 PM   #13592
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I never really touched mine for setup. But I never felt like doing it
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-22-2008, 05:58 PM   #13593
ShaunMac's Avatar
I have always drilled the ballcups for easy access. Makes quick roll-center adjustments much easier. Plus, the ballcups stay tighter, longer. Popping them off only a few times adds unwanted slop to the suspension.
ShaunMac is offline   Reply With Quote
Old 08-22-2008, 06:14 PM   #13594
vazzo's Avatar
Trader Rating: 100 (100%+)
Hi Guys
Im going to be running modified 6.5R Novak, do any of you run this motor and if so what gearing do you recommend, Novak state that 8.5 FDR is a starting point but I'm a little worried as I tried the 3.5 FDR on the 17.5 and thermalled the motor. Im running 48 pitch gears as well. I was thinking more like a 8.78 FDR which is a 90 spur and 25 tooth pinion. Would rather hear from the experts before I try this though. Ill be running the car mainly in the evening and sometimes during the day so I guess I will need both gearing options.
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 08-22-2008, 06:56 PM   #13595
shadow102's Avatar
Trader Rating: 21 (96%+)
Originally Posted by vazzo View Post
Hi Guys
Cheers
Adrian
The reason why you thermaled the 17.5 and the reason you will thermal the 6.5 is your fdr calculations are off. It looks like you are calculating using the old 16t pulleys which gives you a 2.4375 internal ratio. Being you have a TC the 18t pulley gives you a 2.18 internal ratio
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 08-22-2008, 08:44 PM   #13596
pcar951's Avatar
Yup! Now lets all go and drill our ballcups.
Old 08-23-2008, 01:22 AM   #13597
mangoman's Avatar
I bought a second car which had them drilled, its better than sliced bread!
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-23-2008, 05:09 AM   #13598
shadow102's Avatar
What size drill bits are you guys using to drill the ball cups?
www.nexusracing.com
www.go-rc.org
Old 08-23-2008, 05:49 AM   #13599
A Ilievski's Avatar
Trader Rating: 39 (100%+)
I just use a 2mm drill bit. Enough so that the 2mm driver can fit into the ball cup to loosen the ball screws.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 08-23-2008, 07:33 AM   #13600
STLNLST's Avatar
The car is ready for battle!!!! I changed back to th Xray springs and I will try to test back to back linear vs progressive springs. Wish me luck........
STLNLST is offline   Reply With Quote
Old 08-23-2008, 08:56 AM   #13601
mangoman's Avatar
I use a really small drill bit then a reamer to finish it off.
www.smaracing.org
Old 08-23-2008, 09:10 PM   #13602
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
does anyone know where I can get the TC. it out of stock everywhere?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 08-23-2008, 10:33 PM   #13603
Korey Harbke's Avatar
I actually just recently did this. It was HPI Pro 4/linear springs vs the hara/progressive springs.
The hara springs in general make the car feel very very very smooth. The car doesnt change directions quite as fast as the linears, and makes the car feel very stuck. They are a great way to smooth out a car in reaaallllllllyyyy high grip applications I think, because it also keeps the car pretty flat for the the most part.
The linear springs seemed to free up the car overall. They allowed the car to change direction faster and transition much harder. My car had more overall steering with them. I think they would suit lower traction tracks a little better where you need the increased weight transfer.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-23-2008, 10:50 PM   #13604
corallyman's Avatar
Trader Rating: 98 (100%+)
K-Man,
Was this testing done at SIR? SIR is asphalt right now correct? It's been awhile since I've been there.
Do you think you would see the same thing on Carpet Foam and or Rubbers? I've been wondering about the Hara Springs, glad you tested them.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 08-24-2008, 12:10 AM   #13605
Originally Posted by corallyman View Post
K-Man,
Steve
Hey Steve,
All this testing was done at SIR (now asphalt). I'm pretty sure my findings will transfer to rubber tire carpet racing. These springs are too soft for any foam tire racing though. Talking to some of my buds at HB, they commented the full Hara spring line falls between HPI silver and HPI Gold (from the pro 4 set). They are just very fine increments of adjustment specifically for some special conditions faced in some situations.
If you notice, they seem to be popular at Yatabe Arena, and the track where the TITC is held every year. Those are known to be very smooth, and ridiculous traction asphalt tracks. So the fact that they smooth out a car makes a lot of sense.
-Korey
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
