Old 08-16-2008, 11:23 AM   #13471
cyclone speed's Avatar
im running MOD 5.5 .
And how do i change the toe in angle at the rear of my car if .Does it have to be changed with the toe block or can it be changed with anything else for the rear
cyclone speed is offline   Reply With Quote
Old 08-16-2008, 11:38 AM   #13472
RC MARKET's Avatar
setup your car need balance setup start,
can't setup Rear or Front only !
if you Spool , you can try F - kick up ( FF 0.5 FR 1mm or FF FR 1mm ),
Rear downstop more drop ( smaller flow )
5 or 6 cell ?
RC MARKET is offline   Reply With Quote
Old 08-16-2008, 12:13 PM   #13473
shadow102's Avatar
Trader Rating: 21 (96%+)
Just finished in a elecronics store here...is it bad that I am excited I founds purple zip ties?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 08-16-2008, 03:00 PM   #13474
does the brushless motor mount raise the motor or move it forward?
i have a Andy Moore wce with a 13.5 Novak and the motor seems to be sat on the chassis
Kev-h
Kevh
Cyclone WCE
LRP Sphere TC spec
Novak SS 13.5
Spektrum 2.4
kev-h is offline   Reply With Quote
Old 08-16-2008, 03:16 PM   #13475
Kev-h
The motor is in the same place,, The BL motor mount raises the lay shaft 2mm so you have room for a spur that is 4mm larger. They should call it a brushless lay shaft holder thingy
Lazer Guy is offline   Reply With Quote
Old 08-16-2008, 03:26 PM   #13476
thanks.
does that not stop the heatsink middle chassis sitting square?
is it normal for the motor to be on the chassis?
Kevh
Cyclone WCE
LRP Sphere TC spec
Novak SS 13.5
Spektrum 2.4
Old 08-16-2008, 03:42 PM   #13477
With the BL mount you use two 2mm shims on the rear balk heads under the rear top plate and it sets flat.
I have two chassis, one is BMI and the motor sits right on the chassis on both of them.
Your Welcome
Old 08-16-2008, 09:38 PM   #13478
5 or 6 cell ?
I run 5 cell , yes i have a spool . i have set up my car front rear . i have 3mm of uptravel all round .
my setup : RF 1.5 , RR 1.5
FF 1.5 , FR 2
If you want my full setup i will post it .
thank you
Old 08-16-2008, 10:57 PM   #13479
Default cyclone
anyone know who has the new kit in stock?
imber is offline   Reply With Quote
Old 08-16-2008, 11:32 PM   #13480
do you mean the cyclone TC , if yes
http://rcmarket.com.hk/product_info....oducts_id=3619
Old 08-17-2008, 12:17 AM   #13481
grizzle's Avatar
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Default stock motor mount
Your Welcome
In order to use bigger spur gears, I was thinking of lifting the stock motor mount by putting 2mm washer/spacers between the chassis and the bottom of the stock motor mount. This will also raise the motor, will there be any concern with affecting the handling because of the motor lifted by 2mm?
Pro4, TA05R, Cyclone TC, 3PK2.4, NGLLRME, TA04R
grizzle is offline   Reply With Quote
Old 08-17-2008, 12:18 AM   #13482
RC MARKET's Avatar
FF 1.5 , FR 2
thank you
ok mail to me !
but FF &FR shim more will slower in second turn !
rolling more so need more time to return to std for next turn rolling .
Old 08-17-2008, 12:30 AM   #13483
Korey Harbke's Avatar
Originally Posted by STLNLST View Post
The only bad thing with you being a team driver is that you are gonna catch my post count by the end of the year being so helpful....
We got these cars rocking out here bro. Scotty's set up is dialed. All we want to do now is test the new proptoform body and see how it runs on the car. I have been going back and forth with the regular mazda 6 and the AP stratus. The DNA 2 was my body of choice last year but it turns in way too hard with our current set up. I think I'm only going to run 13.5 for the rest of the year. Mod is hit or mis around here.
Awesome, you'll have to post those setups up for all to see. I've been running 13.5 for the most part. SIR is waay to small to be running mod without it being a white knuckle experience, so most don't run it. I did do a little 10.5 testing last night, but the setup still needs a little work. It's a little pushy still...
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-17-2008, 03:20 AM   #13484
Korey and Guys
can you do me a favour and measure on a setup station how many degrees total steering travel on each lock you run on the cyclone.
I have a feeling that why my car pulls rear end round due to running to much lock.
richard baker is offline   Reply With Quote
Old 08-17-2008, 04:48 AM   #13485
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can any one tell me a online shop that has this instock, ive been trying to get one here in Australia for ages, and even the main distributer says they have tried and might not be able to ever get one????
but the hot bodies Europe site says its available
hpi-92611 its a HB/HPI Team sweat shirt (Jumper) XXL
LOSI123 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
