Old 08-12-2008, 10:32 PM   #13426
Korey Harbke's Avatar
Yup, they drop right on
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-12-2008, 10:33 PM   #13427
cyclone speed's Avatar
hi guys im running 5 cell mod with brushless and the minimum weight limit is 1450grams and my car is around 1505 grams .
I would like to know what is the weight of your car and what could i do to lower the weight , my car is a cyclone moorspeed
cyclone speed is offline   Reply With Quote
Old 08-12-2008, 11:02 PM   #13428
Shadows's Avatar
Trader Rating: 23 (100%+)
anyone got a "second batch" TC kit recently? and can confirm if HB has fixed the rear hub alignment issue? I noticed new kits now have the 2008 reedy winner sticker of HARA stuck on the front of the box... or are these the same old kits (with the bad batch of rear hubs) with a new sticker?
Shadows is offline   Reply With Quote
Old 08-13-2008, 04:49 AM   #13429
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Iím just looking for some starting gearing for an Orion 5.5 or equivalent turn. I do not have the brushless motor mount.
I plan to run it with 108/31*2.4375 = 8.491 FDR. Is it in the ballpark? I do not have the motor yet and never ran anything hotter than 10.5 on the Cyclone.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 08-13-2008, 05:56 AM   #13430
jag88's Avatar
Originally Posted by Korey Harbke View Post
The current batch of rear hub carriers has been misdrilled, so the best solution so far has been to either get some aluminum rear hub carriers from 3 racing or Jet Racing, or to try to redril the hole till it gives the correct amount of rear toe in.
Future batches of the rear hub carriers have been said to be much better, so this shouldn't be a problem for too much longer hopefully.
-Korey
Good news....... but I wonder how will we tell the old from the new ?
New part number ?
jag88 is offline   Reply With Quote
Old 08-13-2008, 06:00 AM   #13431
yokemad's Avatar
@RcMarket
What are the issues of 008?
yokemad is offline   Reply With Quote
Old 08-13-2008, 06:44 AM   #13432
KHoff7's Avatar
Komkit running mod at 301!?
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 08-13-2008, 09:14 AM   #13433
komkit's Avatar
Yes sir!
Was going to do 3.5 but couldn't get the gearing w/o brushless motor mount. So 5.5 will have to do
Old 08-13-2008, 09:15 AM   #13434
KHoff7's Avatar
That will be fun. I might have to think about that since I have a 5.5 also
Karl Hoffmeister
Old 08-13-2008, 10:17 AM   #13435
tenpins77's Avatar
Send a message via AIM to tenpins77
Okay guys,
this is probably going to sound completely stupid and ridiculous but this is my first "real" touring car, so here it goes!
I noticed that after building the car i put wheels/tires on it and the car doesn't roll smoothly? I mean i can put it down and push it, but lets say i was on a big open floor, and i pushed the car it wouldn't continue to roll? Perhaps im just used to shaft driven cars. Is this normal because its new/belts etc, or did i once again screw something up?
Also some food for thought,
When putting the car together, to be exact page 12 of the manual, shows that the center one way's carbon fiber screw plate should be facing the left side of the car? However i have been told it should be on the right side? Also are we suppost to gap the spur gears and one ways so that they are even on the shaft or should i use shims?
wel now that most of you are probably scratching your head or laughing out uncontrollably, any help would be great
Tim
tenpins77 is offline   Reply With Quote
Old 08-13-2008, 10:57 AM   #13436
STLNLST's Avatar
Trader Rating: 21 (100%+)
New part number ?
it's probably going to be the same part number so it's going to be a hit or miss. Get the alum hubs and cal it a day.
STLNLST is offline   Reply With Quote
Old 08-13-2008, 12:02 PM   #13437
RC MARKET's Avatar
Originally Posted by yokemad View Post
@RcMarket
Motor pinion touch front belt & touch battery bar !
belt life short
RC MARKET is offline   Reply With Quote
Old 08-13-2008, 01:22 PM   #13438
TheCoolCanFanMan's Avatar
Originally Posted by tenpins77 View Post
Okay guys,
Tim
Hi Tim
The car will roll freely in time given on the track, as you say, the belt needs to bed in, make sure the belts are not to tight in the 1st instance and readjust your diff after a couple of 3 laps.
Don't bother with the plate, just make sure you do the screws up equally onto the spur and gently, as you are adding rotational mass to the drive chain if you put the plate on.
Just space the spur gears and pulleys so the belts don't rub on them.
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 08-13-2008, 01:59 PM   #13439
KHoff7's Avatar
Originally Posted by TheCoolCanFanMan View Post
Hi Tim
Malc
Also if you have a center one way make sure the front belt is riding on the one way pulley not the rear belt.
Karl Hoffmeister
Old 08-13-2008, 02:08 PM   #13440
Rdog's Avatar
Trader Rating: 83 (100%+)
You also might want to check the center shaft on your spur. There should be a little play in the shaft on the pulleys between the spur. I had a similar problem on mine.
Rdog is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
