Old 08-11-2008, 12:39 PM   #13381
TheCoolCanFanMan's Avatar
Originally Posted by artwork View Post
Can someone with a TC please measure the distance from the bottom of the top deck to the top of the chassis? Trying to figure out how LIPO is gonna fit in the car.
The Orion 3800 30c's fit fine, just remove about 1mm to 1.5mm o material from the centre brace.
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 08-11-2008, 12:50 PM   #13382
Originally Posted by Korey Harbke View Post
I can post my current setup for a high traction indoor track. The kit setup is pretty good for the most part too.
Front:
Spring: HPI Pro 4 Pink
Oil: AE 45wt
Piston: tamiya 3 hole
Rebound: 75% with the foam
Shock position: #2 on the new suspension arm, #3 on the tower
Swaybar: 1.4mm
Caster: 4 deg
Camber: 2 deg
Upper Link: long, with 3mm under the inner pivot
Arm sweep/toe block: 2.0 deg
Shims under suspension blocks: FF=1.0 FR=1.0mm
Droop: 6mm off a droop gauge
Ackerman: 4mm on the center arm and position #2 on the steering knuckle
Front Drive: Spool
Rear:
Spring: HPI Pro 4 Silver
Oil: AE 40wt
Piston: Tamiya 3 holes
Shock Position: #2 on the new suspension arm, and #4 on the tower
Swaybar: 1.2mm
Camber: 2 deg
Upper Link: long on the bulkhead, inner position on the rear hub, 1.5mm under the inner pivot
Rear Toe: 2.0 deg
Shims under suspension blocks: RF= 1.5mm RR= 1.5mm
Droop: 6mm off gauge
Wheelbase: stock on everything
Body: Protoform Mazdaspeed 6
Tires: Speedmind/Sorex 36R premounts
Hi Korey
I tried your setup at my club on Friday, and it was a little loose at first until the first round had finished (4 heats, 22 racers) so I brought the droop to 5mm all round, I have never had sooooooooo much grip from this car, and as the night went on, I brought the droop back to 6mm but was still far to grippy as the rubber was laid, btw, i didn't put a 2 degree bar on the rear as I didn't have one, so put a 2.5 on. What would of been your suggestion to loosen the car up please
I tried the setup at my out-door track, and again had a great amount of grip with 5mm droop on the rear and front, but the initial turn in was catching me out a little, maybe I could have slow the servo down a little from my hand-set, but went to a 1.5 bar on the front and put 5.5 of droop on the front, again what would you have done please.
Cheers Malc TCCFM
Old 08-11-2008, 02:23 PM   #13383
STLNLST's Avatar
Trader Rating: 19 (100%+)
gave the wrong info.....my bad. Read the post wrong.
STLNLST is offline   Reply With Quote
Old 08-11-2008, 02:48 PM   #13384
vazzo's Avatar
Trader Rating: 100 (100%+)
Could someone please post up Hara's Reedy winning setup and what changes he made to the TC as far as parts.
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 08-11-2008, 03:11 PM   #13385
Korey Harbke's Avatar
TheCoolCanFanMan- So It sounds like the car worked good for a while, but then became too stuck overall as the night went on. The 2.5deg rear toe will make the rear end stick more overall, especially mid-exit. So... the 2 deg rear toe probably would have helped out a little bit with letting the car roll through the corners a little better. You could also try just standing up the shocks a little bit, or run thicker swaybars to help free it up overall.
Now to smooth out initial turn in, I would try a little bit less front camber. Also try a normal Protoform Mazda 6, rather than a Protoform Mazdaspeed 6. The normal mazda 6 is muuuch smoother overall than the Mazdaspeed 6. I just like a lot of steering . You can also try adding a little more shims under the front suspension blocks. Go up to 1.5mm like STLNLST said, and maybe even try 1.0mm FF, and 1.5mm FR to give the front end a little antidive. It should make the car a little smoother on entry, and give more on power steering comming out of a corner.
Vazzo- http://www.hpiracing.co.jp/contents/...ra080525TC.pdf
Thats Hara's reedy setup. You should keep in mind that the condiditons at the reedy race were pretty unique. No traction compound allowed for the Invite guys like him, and the Speedmind/sorex premounts tend to make the car push a bit. It should be a good starting point for a typical outdoor asphalt track though.
The only things that I saw that werent stock on his car were servo mounts, aluminum shock pivots, and aluminum rear outdrives. The intent was to run mostly everything stock, because the car is awesome in it's stock form. Other things he had on his car were just different springs, pistons, and swaybars for tuning.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-11-2008, 03:33 PM   #13386
Stew Noble's Avatar
-Korey
Also....
- Cut rear deck for more traction.
- Version 3 spool, with POM outdrives and alu sleeves.
// S N F //
Stew Noble is offline   Reply With Quote
Old 08-11-2008, 04:00 PM   #13387
RC MARKET's Avatar
Originally Posted by Stew Noble View Post
Also....
RC MARKET is offline   Reply With Quote
Old 08-11-2008, 05:16 PM   #13388
vazzo's Avatar
Thanks for the info guys, is the V3 spool the one that comes with the stock kit ie front one way and spool all in one? Can someone please explain the cutting of the rear deck in detail as I dont understand sorry.
RCMarket can you please give me the part numbers for Version 3 spool, with POM outdrives and alu sleeves.
Cheers
Adrian
Old 08-11-2008, 08:24 PM   #13389
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Korey... as for your setup, a couple things i didnt see.
1. front and rear arm spacing.
2. rear hub spacing
3. what motor
4. final drive ratio
36R's???? WTF, we thought we had high bite running up to 32R's....
thanks for the help.
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 08-11-2008, 11:31 PM   #13390
Oh... I thought the arm spacing was pretty much stock. I dont have the car in front of me, but I do remember I have the front wheelbase a little shorter than the stock setting.
I have the thick spacer in front of it, and the thing one behind it. As far as the rear I have the thick spacer in front and the thin in the back. The rear hub is the same way as the rear arm. So the rear end is stock as far as I know.
Yea, we have a lot of grip at my track. 32's wear out in about a run, plus they have a very narrow temp range. It's bumpy too, so it can throw me for a loop every now and then when it comes to setup.
As far as motor... I've been running a little bit of everything. Not so much mod right now, but mainly 10.5 and 13.5. Gearing depends so much on the track and motor battery combo, so I'm not going to get into that. I am running the 18T center pulleys that give a 2.166 internal ratio since they came stock with the TC kit.
-Korey
Old 08-12-2008, 03:58 AM   #13391
shadow102's Avatar
Trader Rating: 21 (96%+)
Also....
anybody have a pic of this?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 08-12-2008, 04:09 AM   #13392
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
RCAmerica, X-Ray, Hudy, Ko Propo, Protoform, PRS, Jaco, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, NEXT, www.SuperiorHobbies.com
We're going to skate to one song and one song only!
Dave Bowser is offline   Reply With Quote
Old 08-12-2008, 05:26 AM   #13393
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Dave Bowser View Post
Nice pic...but where's the CF Spur gear holder?
yyhayyim is offline   Reply With Quote
Old 08-12-2008, 05:50 AM   #13394
RCFREAK's Avatar
thanks Korey for the tips...
THE TC didnt come with carbon spur gear plate...
Arv.
Old 08-12-2008, 06:53 AM   #13395
RC MARKET's Avatar
Cheers
Adrian
Ver.3 spool
http://rcmarket.com.hk/product_info....roducts_id=218
POM
http://rcmarket.com.hk/product_info....oducts_id=4063
Steel Cup
http://rcmarket.com.hk/product_info....roducts_id=219
Thankyou !
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
