Old 08-09-2008, 06:28 AM   #13351
Khador12's Avatar
I have noticed that on most of the set up I have found that the spacers under the front pivot blocks are higher on the rear. Am I reading this right?
Khador12 is offline   Reply With Quote
Old 08-09-2008, 07:14 AM   #13352
RC MARKET's Avatar
I'm saw hara also F 1mm , R 1.5mm
RC MARKET is offline   Reply With Quote
Old 08-09-2008, 09:19 AM   #13353
STLNLST's Avatar
Trader Rating: 19 (100%+)
Mostly all of the set up's have 1.5mm spacers front and rear. The set up's with 1.0FF and 1.5FR are set up's with anti dive. Which set up's are you looking at that have the front higher than the rear?
STLNLST is offline   Reply With Quote
Old 08-09-2008, 11:52 AM   #13354
shadow102's Avatar
Trader Rating: 21 (96%+)
i know i have front kick up in my setup (1.5 FF .5FR) but i also run an extremely bumpy track
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 08-09-2008, 11:55 AM   #13355
RC MARKET's Avatar
F spool ?
Old 08-09-2008, 12:10 PM   #13356
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
there are two new one's waiting to go into something. One for on raod and the other off road. That one pictured is one that Scotty and I are gonna test with first thing Sunday morning. We have a few ideas from the Speedworld cup that we have been waiting to try my next time out.
Wait, you do off road to? What are you racing? 4wd, or 2wd?
Modding a speedo, I will have to be there for that next race. Any chances it will go boooom?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-09-2008, 12:55 PM   #13357
shadow102's Avatar
Originally Posted by RC MARKET View Post
F spool ?
yeah front spool
www.nexusracing.com
www.go-rc.org
Old 08-09-2008, 03:30 PM   #13358
RC MARKET's Avatar
yeah front spool
U can test
FF 0.5 FR 1 mm
RF 1.5 RR 1.5mm
Old 08-09-2008, 09:21 PM   #13359
STLNLST's Avatar
2wd B4 coming to a track near you...... I really do see off road placing a strain on the motors like mod sedan. I'm only going to run 13.5 in off road. I'm starting out in sportsman too
Old 08-09-2008, 11:01 PM   #13360
pcar951's Avatar
Anyone heard any real reports on the new TC? There's gotta be some guys running the new car? It's pretty invisible in my part of the world. Just wondering if it's any better than the WCE.
pcar951 is offline   Reply With Quote
Old 08-10-2008, 12:40 AM   #13361
Korey Harbke's Avatar
The new TC kit is awesome. The main changes from the WCE kit and the TC kit are the 2 way front spool/one way (very similar to an xray multi diff), the pro spec rear differential, the reversible suspension arms, the new swaybar mounts, and the ability to use the atc post options. There are also some improved upper bulkheads/shock tower mounts, and other things to accomidate those.
Personally, the two most valuable changes in my opinion are the pro spec ball diff, and the new suspension arms. They offer more tuning options to get the car really dialed in. The pro spec ball diff is probably the smoothest diff I've ever run.
The POM outdrives are awesome as well. After 40 packs on the car, I didn't see the smallest bit of wear. I have recently changed them out to the optional aluminum outdrives, but I really don't see a need for them. I'll probably switch back to the POM outdrives because they are lighter and the aluminum ones haven't shown any real advantage over them just yet.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-10-2008, 05:34 AM   #13362
STLNLST's Avatar
Car was completed yesterday but I wasn't able to post pics. I'm on my way to pick up Scotty so we can throw down against the Tamiya homies. Race report later on tonight...........
Old 08-10-2008, 10:02 AM   #13363
ShaunMac's Avatar
-Korey
What class are you running? 13.5, MOD, Carpet, Asphalt? I hope to have the new diff soon. We're on asphalt now, but will be going indoors in a couple months for some rubber carpet racing.
ShaunMac is offline   Reply With Quote
Old 08-10-2008, 11:05 AM   #13364
I've been running asphalt on a extremely high bite indoor track. I'm running a little bit of everything as far as motor. Just depends on what has more entries that night. But the POM outdrives are dialed.
-Korey
Old 08-10-2008, 03:27 PM   #13365
shadow102's Avatar
ran the cyclone for the first time today...had nothing but problems all day. First heat had a cv axle pop out weird and bind in the spool...turn marshal fixed it but when he set it back down the car drove really weird. Back in the pits it turns out the 3racing layshaft snapped in half somehow (probably cause its aluminum and as a random hole in it.) so i modified the one way shaft i had and ran that the rest of the day with the locked pulleys. Next qualifier i had the center of one of the sweep wheels rip out so that put me a couple laps down. The last qualifier wasnt much better as my pinion cam loose and slid down the motor shaft. Sucks going full speed down the front straight then having no brakes. All the while i was changing the setup a littler here and there but something wasnt right...finally just got annoyed and pulled out the rear gear diff i put in and threw back in the ball diff. Car immediately felt better and i ended up placing second in the main...so all in all a good day.
Any body wanna pick up a cheap gear diff? gotta buy the new ball diff. How often do you guys change out the balls on the new diffs?
www.nexusracing.com
www.go-rc.org
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
