Old 10-06-2005, 03:50 AM   #1321
Trader Rating: 23 (100%+)
G'day all!
Just downloaded some of Hara's setups from HPI Japan and ran into a little problem when trying to use it on my car
I saw on most of his setups that he runs spacers under the sus blocks. using the pro 4 ones for the toe blocks are easy but what to use for the black sus blocks? any suggestions? cut some of the spacers in half
cheers
poop is offline   Reply With Quote
Old 10-06-2005, 04:12 AM   #1322
Trader Rating: 16 (94%+)
Originally Posted by poop
G'day all!
cheers
to get the 1.5mm under the F/R blocks im guessing two of these, as looking at the pics of his car there appears to be a visible gap between the chassis and the blocks...
HPI Aluminum Washer 3x6x0.75mm Purple
http://www2.towerhobbies.com/cgi-bin...?&I=LXGPC4&P=7
domo is offline   Reply With Quote
Old 10-06-2005, 07:02 AM   #1323
well I just tried 1.5mm under the front f/r block, which has resulted in the steering turnbuckles binding on the f/r block at about half steering travel....
the solution isnt obvious (other than a dremel)... any ideas?
edit: found a close up pic of hara's car from IIC and its a dremel fix...
Old 10-06-2005, 07:49 AM   #1324
We used TakeOff 3x5 x0.5 or 0.75 mm black & Purple colors
HKRCMODEL is offline   Reply With Quote
Old 10-06-2005, 08:31 AM   #1325
rc-zombies's Avatar
Originally Posted by S-T-R-l-K-E-R
stormer hobbies just ran out of kits anyone know where i can get one at a decent price?
someone on the for sale thread had one for $390 don't know if it's still available... shipped from HK.
Old 10-06-2005, 08:37 AM   #1326
rc-zombies's Avatar
in the RcModel thread they have mentioned new upper bulkheads were going to be released..anybody here have any info or pics on them?
Old 10-06-2005, 09:06 AM   #1327
You've cut the black pivot block?
Hugo is offline   Reply With Quote
Old 10-06-2005, 09:18 AM   #1328
rc-zombies's Avatar
nope...just file away alittle of the blocks. there will be no support if the center bar is cut-off. I see by the chassis drilled cut-outs that can provide for a split type pivot block like the Yok BD.
I added 1mm spacers on mine...it does touch the turnbuckles just slightly. I'll probably take the dremel as well later this weekend and before I get them recolored to purple.
Old 10-06-2005, 09:42 AM   #1329
Solara's Avatar
Trader Rating: 16 (100%+)
If using 1mm spacer can prevented me to dremel those brand new alum pivot blocks..........I would use it.
After all, it is just 0.5mm different.........using Hara's 1.5mm spacer doesn't make me drives like Hara...........HARA can dremel any parts or screws all he want cause he might have a new cyclone every weekend...LOL.
There are nothing DREMEL cannot do...just remember that....may be I can dremel my Pro 4 into the cyclone....the belt might be a little bit tough.
Old 10-06-2005, 10:20 AM   #1330
but in titc not have use space in Sus. mount & he used F spool
Old 10-06-2005, 12:08 PM   #1331
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
just got word that the bulkheads are plastic. is this true? pls reply asap. thnaks to all in advance
S-T-R-l-K-E-R is offline   Reply With Quote
Old 10-06-2005, 12:30 PM   #1332
Skill's Avatar
I don't have a Cyclone yet but I'm 100% sure that they are black anodised aluminium.
Skill is offline   Reply With Quote
Old 10-06-2005, 01:06 PM   #1333
rc-zombies's Avatar
nope...they are aluminum.
Old 10-06-2005, 03:58 PM   #1334
They are 100% aluminium.
the dirt is offline   Reply With Quote
Old 10-06-2005, 04:07 PM   #1335
black-knight's Avatar
R/C Tech Charter Subscriber
G'day all!
cheers
just use shims as used on tamiya kits.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
