Old 08-07-2008, 09:01 PM   #13321
Korey Harbke's Avatar
I can post my current setup for a high traction indoor track. The kit setup is pretty good for the most part too.
Front:
Spring: HPI Pro 4 Pink
Oil: AE 45wt
Piston: tamiya 3 hole
Rebound: 75% with the foam
Shock position: #2 on the new suspension arm, #3 on the tower
Swaybar: 1.4mm
Caster: 4 deg
Camber: 2 deg
Upper Link: long, with 3mm under the inner pivot
Arm sweep/toe block: 2.0 deg
Shims under suspension blocks: FF=1.0 FR=1.0mm
Droop: 6mm off a droop gauge
Ackerman: 4mm on the center arm and position #2 on the steering knuckle
Front Drive: Spool
Rear:
Spring: HPI Pro 4 Silver
Oil: AE 40wt
Piston: Tamiya 3 holes
Shock Position: #2 on the new suspension arm, and #4 on the tower
Swaybar: 1.2mm
Camber: 2 deg
Upper Link: long on the bulkhead, inner position on the rear hub, 1.5mm under the inner pivot
Rear Toe: 2.0 deg
Shims under suspension blocks: RF= 1.5mm RR= 1.5mm
Droop: 6mm off gauge
Wheelbase: stock on everything
Body: Protoform Mazdaspeed 6
Tires: Speedmind/Sorex 36R premounts
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-07-2008, 10:29 PM   #13322
cyclone speed's Avatar
hi guys , i have a probleme on my hb cyclone . my probleme is the folowing situation:
every time i wont to set equal droop left right 5mm , then once the droop is set i lift the car at its centerline and both wheel dont lift at the same time . i dont know whats wrong because i set the ride height , adjust tweak , but when it comes to the droop i have to put 3mm droop right and 6mm droop left for both wheel to lift at the same time but my car still drives well . My shock lenght are equal left right but i dont know whats the probleme.and also for droop when i set droop 3mm and 6mm my car has 4mm uptravel and both wheel lift at the same timewith 4mm uptravel .
And also for adjusting the tweak when the tweak is equal left right ,
the ride height is fine but the spring collar between them it has 4mm diference
thanks alot if you cuold help me out thanks
cyclone speed is offline   Reply With Quote
Old 08-07-2008, 11:10 PM   #13323
Check to make sure your chassis is perfectly straight. Remove the shocks from the car, and loosen all the top deck and rear deck screws. I usually take droop blocks on a hard, perfectly flat surface (glass, hudy setup board, or anything similar). Then I set the car on the droop blocks and make sure they aren't sitting directly under any screws, press down on the shock towers. While the shock towers are being pressed down, tighten the screws in a X pattern.
Also, sometimes tires with really large airgaps, or poor mounting jobs can make for a weird shaped tire that will throw the tweak off.
If that still has you in a tweaky situation, make sure your bulkheads are straight by taking them off the car and testing them on a peice of glass. Just lightly tap long the bulkhead while it's laying down on the glass to see if it rocks around or anything. I do periodically to my car to keep things in check.
The suspension blocks are suspect to being a little out of whack sometimes. They can twist the chassis if they are REALLY bad, but check and make sure they are flat anyway.
Hope that helps you out
-Korey
Old 08-07-2008, 11:42 PM   #13324
thanks i will try everything but i think that my chassi is twisted because it rocks side to side. And also tyre did have a big air gap
Old 08-08-2008, 12:20 AM   #13325
when adding 4mm of shims to the servo saver the stock ball studs are too short to thread in. does anyone know what length to get for a new set of ball studs so that they will thread, and if so where?
thanks!
Cheese City Xtreme Rc
-Tim
timmaay is offline   Reply With Quote
Old 08-08-2008, 12:40 AM   #13326
Cyclone Speed- Yea... thats not good. But when you fix that, the tweak problem should go away!!!
Timmmmmmmaaaaaaaaaaayyyyy- I think there are two sizes. I use the ball studs that are 13mm in length and they work good.
-Korey
Old 08-08-2008, 01:36 AM   #13327
TheCoolCanFanMan's Avatar
Front:
Oil: AE 45wt
Swaybar: 1.4mm
Caster: 4 deg
Camber: 2 deg
Front Drive: Spool
Rear:
Oil: AE 40wt
Swaybar: 1.2mm
Camber: 2 deg
Rear Toe: 2.0 deg
Thanks for that Korey
What overal length do you have your shocks, do they differ from front to rear?
So you have done away with 2mm all round under the sus blocks, infact you are quite away from a stock setup.
What ride hight front and rear?
I use a Losi droop gauge which sits on the bottom of the chassis and work the measurement from the end of the wish bone, would it still be 6mm droop in this case?
Do you have a gap on the roll bar mount, as per the instructions?
I use Losi oil for my shocks, what is the difference in viscosity relation to the AE oil, if any is there?
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 08-08-2008, 01:38 AM   #13328
thanks you KOREY
Old 08-08-2008, 01:40 AM   #13329
could anyone post their setup for a medium traction track and for low traction track outdoor with rubber thanks you
Old 08-08-2008, 01:59 AM   #13330
RC MARKET's Avatar
how many cell ?
RC MARKET is offline   Reply With Quote
Old 08-08-2008, 02:45 AM   #13331
-Korey
ok i have ball studs that fit, but when i shim 4mm the ball ends touch the front pivot and won't allow it to turn. so my question is how do you over come that?
thanks again!
-Tim
Old 08-08-2008, 03:02 AM   #13332
Originally Posted by RC MARKET View Post
how many cell ?
5 cell modified racing with vector 5.5
Old 08-08-2008, 03:52 AM   #13333
if possible fot a tight and technichal track thanks
Old 08-08-2008, 04:59 AM   #13334
thanks again!
Have you got the front and rears pivot blocks mixed up?
Old 08-08-2008, 06:24 AM   #13335
shadow102's Avatar
Trader Rating: 21 (96%+)
thanks again!
i have the same problem when you go to the outside hole on the rear up rights. what you do is shave off the top of the ball cup just gotta keep an eye on the amount of dirt that gets in there as it will wear out the ball end quicker
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
