Old 08-07-2008, 03:20 AM   #13306
xraysteve's Avatar
i think people are going a little over board monting there lipos. they are safer then the sub-c. all you have to do is put them in there and tape them. they do not need a bumper or anything to protect them. i have seen a dart thrown in one and a nail beat in another and guess what no explosion.
lazer speedway everything else is a parking lot
xraysteve is offline   Reply With Quote
Old 08-07-2008, 03:40 AM   #13307
shadow102's Avatar
Trader Rating: 21 (96%+)
its not really a matter of protection but more of the issue of keeping the pack in one place in the chassis and not having fly out. The battery slots are way too wide for the orion and Core RC cells that i at least know of
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 08-07-2008, 05:01 AM   #13308
grizzle's Avatar
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Default lipo in place
Yes, the yeah racing lipo have slots in the bottom to simulate the nimh cell battery packs. I cannot use the included battery holder for the nimh cell because the lipo battery case won't fit and won't clear the top deck. If I will not use the battery holder the lipo is sliding all over the chassis.. so I make something to keep the lipo from moving, specially during crashes.. next item will be the battery post and brace..
I'm also planning to install a protection for the motor, same one they have on the tamiya TA05.. I'm afraid a hit on the side on the chassis will damage the motor, specially the sensor wires..
By the way, the rear hub mod using grab screws, to even out the rear toe in, did not work for me. It resulted in vertical slop.. .. I'll just get the aluminum rear hubs instead...
Pro4, TA05R, Cyclone TC, 3PK2.4, NGLLRME, TA04R
grizzle is offline   Reply With Quote
Old 08-07-2008, 06:55 AM   #13309
The thing I don't like about clamping my LiPo's in is it tweaks my chassis. I use two servo mounts laying down one in front and one in back of the pack (I had to drill holes for them two) and 3 servo mounts standing up down the middle in the holes that are already there, then tape them in. I use soft pack 6000's so I glued some plastic on the front and back of my LiPo's to keep from denting the packs where it touches the servo mounts and the rear bulkhead, then some foam on the inside and out side on the packs for more protection. I know it sounds like over kill but I only had to do this one time and my packs have no dents anywhere and never move around. I hope you understand what I'm doing
Lazer Guy is offline   Reply With Quote
Old 08-07-2008, 07:02 AM   #13310
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Shoe-Goo a piece of 600 grit sand paper or cut a small piece of a sand paper that have a sticky glue on the back side along these cross piece, your Li-Po pack ain't going no where once you tape them.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 08-07-2008, 09:42 AM   #13311
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Droop
A couple questions:
1) When setting droop with droop gages, especially int he front arms, are u guys measuring at the outer hinge pin set screw, or on the arm? By using the set screw, 4mm gives the car 0 uptravel on my car, which is weird.
2) Tamiya or schumacher 3 hole pistons work on the Cyclone shocks ok?
yyhayyim is offline   Reply With Quote
Old 08-07-2008, 09:46 AM   #13312
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
Originally Posted by yyhayyim View Post
A couple questions:
on the arm
Old 08-07-2008, 09:55 AM   #13313
yyhayyim's Avatar
Originally Posted by Marcos.J View Post
on the arm
Thank you sir...trying to get re-aquainted with the Cyclone quirks
Old 08-07-2008, 09:56 AM   #13314
Super Moderator
Marcos.J's Avatar
lol, and as far as the shock piston i m pretty sure that I used Tamiya ones on my cyclone a while back.
Old 08-07-2008, 10:22 AM   #13315
Korey Harbke's Avatar
Tamiya pistons work great so far. The 3 hole pistons are a good alternative to the HB 1.1mm 3 hole pistons that are common on the more recent setups for the car.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-07-2008, 12:06 PM   #13316
yyhayyim's Avatar
-Korey
Thanks Korey...are u also running 3 hole pistons?
Old 08-07-2008, 12:14 PM   #13317
Hebiki's Avatar
i thought you were running a 416?
i ran the 3hole tamiyas on my cyclone (when i had it.) worked great.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-07-2008, 12:36 PM   #13318
RC MARKET's Avatar
Yes 3 hole is a best choice ,
but Tamiya piston too soft !
RC MARKET is offline   Reply With Quote
Old 08-07-2008, 02:07 PM   #13319
I'm running 3 hole pistons with 45wt up front, and 40wt in the rear. The 2 hole pistons I think work better when the grip is really high... but just run 30-35 wt oil. It'll have the same overall feel, but pack up a little faster.
I just think the 3 hole setup is better for most tracks
-Korey
Old 08-07-2008, 03:29 PM   #13320
TheCoolCanFanMan's Avatar
-Korey
You or any of the guys got any setups for the TC yet, as I keep trying things but end up going back to kit setup
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
