Old 08-04-2008, 04:24 AM   #13231
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by cyclone speed View Post
Im running 28 because most people at local track use them and just to say that i dont know what does on throtle or off throtle means so i wont really understand . I think my car suffers from understeer.
I'm not even getting that complicated...
all i mean is that it sounds like you want to run full throttle into a turn, have the stick and make the turn...what it sounds like to me is that you need to slow down more getting into the turn and then see what happens...
too much speed in a turn will cause the rear end to spin out on you - as would the need to slam on the brakes...
so pick something on the track as a breaking point - and when your car gets near there, let off the throttle so the car slows into the turn...now you should be able to make the turn without spinning and loosing as much time...believe it or not, even the "fast guys" back off their throttle when they race - its just a lot less noticable for them since they are normally way more consistent then the average driver...
the only other thing I can think of is - how tight is your rear diff?? does the rear spin freely or does it seem tight?? if its too tight, that will add to you spinning out effort...loosen the diff up until the rear spins freely - and adjust as needed...
I wasn't thinking one time and did this to my rear diff and couldn't figure out what was wrong, until I had another driver's car in my hand and spun his rear wheels...then I went "doh!! I got the rear diff too tight"...I loosened it up and the issues went away
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-04-2008, 04:33 AM   #13232
cyclone speed's Avatar
thanks i will try all your recomendation . But id like to know about droop : when it say 5mm droop on the setup sheet of a pro does it mean that when the pro put the droop guage it will show 5mm or does it mean that the wheels lift from the ground at 5 mm over the ride height .
And could you tell me the description of on throtle , off throtle , on power steering and off power steering .
cyclone speed is offline   Reply With Quote
Old 08-04-2008, 06:27 AM   #13233
Coldn's Avatar
Send a message via MSN to Coldn
hy every one, i have a Hara Edition, but i want to know.
I was thinking in buy all the hop ups, to convert my Hara edition to the TC edition. Does it worth, pay for all the ups
Coldn is offline   Reply With Quote
Old 08-04-2008, 08:01 AM   #13234
RE cyclone speed
if you are having problems with the rear of the car, i would advise a softer raer brace/ deck ( make your own if you already have the 2mm frp one on of the cyclone TC) as it will increase rear end flex....
re coldn
the hara edition is a very good car.
You will send £'ssss buying all the individual hot ups for your hara edition over time, so probally best to bite the bullet and buy a TC.
blazer2 is offline   Reply With Quote
Old 08-04-2008, 09:29 AM   #13235
Khador12's Avatar
What body is everyone using for rubber tire and asphalt?
Where can you find the 1.1 3 hole pistons and the 1.2 sway bar in stock?
Khador12 is offline   Reply With Quote
Old 08-04-2008, 10:01 AM   #13236
1.1 3 hole are for the pro 4 but work perfectly fine with the cyclone cause i use them:
http://www.apexmodels.com/product-se...&title=tune_up
for the body i use the mazda RX8 as good as the mazda 6
for the sway bar:
http://www.apexmodels.com/product-se...sories&id=9011
Old 08-04-2008, 10:37 AM   #13237
Khador12's Avatar
Thanks for the help but it seems that they do not ship outside the EC and I am in the United States.
Old 08-04-2008, 11:08 AM   #13238
sorry but i will keep looking and tell you if i find any
Old 08-04-2008, 11:13 AM   #13239
check this for the sway bar
http://www.rcmart.com/catalog/bodies...acturers_id=46
Old 08-04-2008, 11:31 AM   #13240
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by grizzle View Post
Guys... can anybody confirm that uneven rear toe is caused by the rear hubs? I replace the rear hubs with my pro4 spare rear hubs and I supposed they are not molded right also... I have yet to try other brand rear hubs. Have anybody get around this problem other than buying the aluminum rear hubs or changing to tamiya 416 rear hubs and pins?
If you are getting uneven tire wear then it has to be something else other than the rear toe problem. Even though the toe is off it wasn't eating up rear tire's. I could be wrong but no one out my way experienced that problem. Is it both rears wearing the same or one side more than the other?
STLNLST is offline   Reply With Quote
Old 08-04-2008, 11:43 AM   #13241
Coldn's Avatar
Originally Posted by blazer2 View Post
RE cyclone speed
re coldn
humm. thank you
a heard about the diff of hara edition. there are a problem if i run with a 3.5 motors? the diff dont suport this turns?
today i run with a 540-J, in a competition class, but i want to upgrade class, and go to 10.5 and 3.5 classes
Old 08-04-2008, 11:50 AM   #13242
STLNLST's Avatar
Originally Posted by Coldn View Post
humm. thank you
The diffs that come with all the cars before the TC are terrible IMO If you already have the Hara car just get the new diff and you're set.
Old 08-04-2008, 12:36 PM   #13243
could anyone tell me the meaning of : on power steering, off power steering, on throtle and off throtle please .
Old 08-04-2008, 12:42 PM   #13244
artwork's Avatar
Trader Rating: 62 (100%+)
On power steering would be the same as on throttle...The car will have more steering when the car is accelerating. off throttle would be when the throttle input is at neutral, thus more steering when the trigger is at neutral.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 08-04-2008, 01:05 PM   #13245
Coldn's Avatar
do you know were i find that new diff set? i search in rcmart and tower hobbies, but i dont find.
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
