Old 07-30-2008, 07:52 PM   #13186
Little_Mike's Avatar
if youre going to do solely drifting with it youre wasting your money.
drifting isnt evolved enough to the point that you can drift better with a top notch touring car than with, say, an HPI RS4. By all means go for it if you are going to do regular racing to, but the cyclone's true potential is in traditional road course racing, and not drifting.
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 07-30-2008, 10:21 PM   #13187
EJ20's Avatar
Originally Posted by Mond-HPi View Post
ic... my friend recently got one Yokomo Masami special Touring car, he has touch up the car to become drift, lol when i try it for drift , its kinda cun ...
I would say Pro D from HPI will be a good Drift car. If you read some Japanese RC magazine, you will find out there's a lot of manufactuer already have new car came out with totally new design!
EJ20 is offline   Reply With Quote
Old 07-31-2008, 02:21 PM   #13188
Help please, I'm a little confused the clone tc manual says put 2mm shims under toe and pivot blocks all the way round, the moorespeed says no shims, what would i gain by adding 2mm shims to the moorespeed and how would this affect the car?
cheers
kevh
kev-h is offline   Reply With Quote
Old 07-31-2008, 02:32 PM   #13189
artwork's Avatar
Trader Rating: 59 (100%+)
cheers
kevh
It should increase roll center which will in turn increase traction by allowing the car to roll more side to side. Typically used for rubber tire racing on asphalt.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 07-31-2008, 05:29 PM   #13190
yyhayyim's Avatar
Trader Rating: 26 (100%+)
What surface are you running in?
yyhayyim is offline   Reply With Quote
Old 07-31-2008, 06:46 PM   #13191
shadow102's Avatar
Trader Rating: 21 (96%+)
Figured i would post here along with the WTB thread i am going to put up. I am looking for the 3racing SSG chassis that for some reason they discontinued. I am trying to convert my car completely over to SSG and this is the only part i cant find anywhere.
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 07-31-2008, 06:54 PM   #13192
RC MARKET's Avatar
This 2 body have what feel ?
RC MARKET is offline   Reply With Quote
Old 07-31-2008, 07:15 PM   #13193
shadow102's Avatar
how do they perform? i like the Cadillac
www.nexusracing.com
www.go-rc.org
Old 07-31-2008, 07:17 PM   #13194
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
+1 on the Cadi
Old 07-31-2008, 07:27 PM   #13195
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Who makes the Cadillac body? I like it as well.
CarlosG. is offline   Reply With Quote
Old 07-31-2008, 09:02 PM   #13196
Korey Harbke's Avatar
cheers
kevh
When you add shims under the suspension block it raises the roll center. This will usually increase initial grip into the corner, but produce less grip through the middle and exit. It also allows weight to transfer side to side faster. The combination of these two things makes the car more reactive off center, and is usually pretty nice on rubber tires. We just run a softer suspension to get that mid-exit grip back
Usually if you need a little more overal traction I will reduce the amount of shims under the suspension blocks by .5mm. It helps smooth out the car and make it a little more locked down.
Now, on foam tires where we want to smooth out the car so it won't be so twichy and hard to drive, we take most of the shim out. If the roll center is too high the car will be very inconsistent and make the car lift up in the corners in very extreme cases because it transfers weight so fast.
For asphalt... I usually start with 1.5mm shims all around, and then work from there. Currently I am running 1.0mm in the front and 1.5mm in the back.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-31-2008, 09:13 PM   #13197
Geek_Speed's Avatar
Hot Bodies (HPI)
http://www.hotbodiesonline.com/products/en/66815.html
Here's a place that has it in stock apparently:
http://demonpowerproducts.co.uk/prod...oducts_id=2925
Geek_Speed is offline   Reply With Quote
Old 07-31-2008, 09:21 PM   #13198
CarlosG.'s Avatar
Thanks for the info Geek_Speed.
Old 08-01-2008, 12:58 PM   #13199
has anyone moved from a 415 to cyclone? I really like the design of the cyclone and fro a lot of drivers it seem easy to drive. i like the 415 but could never get it setup to suit me.
i am wondering what the cyclone drives like in low grip carpet condition that we have in the UK or tarmac.
Smoking motor.. is offline   Reply With Quote
Old 08-01-2008, 01:56 PM   #13200
Hebiki's Avatar
Smoking motor.. i moved from a 415 to the cyclone AME (then later on from a cyclone AME to a 416)
the cyclone is definitely an easy car to set up to your liking
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
