Old 07-26-2008, 11:39 PM   #13141
Originally Posted by mdttb View Post
Thanks but now the site has problems as you cant check out I get a error.
Runtime error in /mm5/5.00/modules/component/cmp-mv-paymentfields.mvc @ [0000000a:0000008e]: modules/component/cmp-mv-paymentfields.mv: Line 97: MvDO: Unable to open '/mm5/5.00/': Is a directory
Holy batman if it aint one thing it's another.............. any one wanna buy a used Cyclone TC
Fixed. Sorry about the glitch.
aboyerHPI is offline   Reply With Quote
Old 07-27-2008, 12:12 AM   #13142
Geek_Speed's Avatar
Default Driveline binding
I have a friend with a Cyclone TC, essentially new.
His driveline has a problem binding up somwhere. For about 1/2 a turn of the spur gear it is "free", then, for about 1/4 turn it is "stiff". This is of course with the pinion removed.
There is nothing visibly bent, nothing visibly rubbing, or out of alignment.
Disconnecting the front drive belt shows that the binding is somewhere in the spur to rear area. The rear diff seems "normal".
Any suggestions on how to further diagnose and solve the problem. With the resistance in his driveline, it's like he's running with a drag brake enabled all the time.
Thanks.
Geek_Speed is offline   Reply With Quote
Old 07-27-2008, 01:25 AM   #13143
Try realigning the pulley on the centre shaft, it may be binding on the middle deck.
savageguy is offline   Reply With Quote
Old 07-27-2008, 07:29 AM   #13144
Scott B's Avatar
Trader Rating: 42 (100%+)
Thanks.
Check to make sure there a no small rocks or debry (sp) in the pulleys (center and diff pulleys).
Mugen Racing USA, Gizmo Racing USA, Sweep Racing Tires, R1 Wurks, Protoform...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is online now   Reply With Quote
Old 07-27-2008, 08:02 AM   #13145
slakr's Avatar
Trader Rating: 28 (100%+)
Originally Posted by slakr View Post
I bought this Cyclone Front Solid Axle (Spool) for my Cyclone S
https://www.ssl-stormerhobbies.com/c...ns&pn=HOT61045
But the stock Cyclone S dogbones don't push far enough into the spool outdrives.
Are there other parts I need to put a spool in my Cyclone S?
Thanks.
Anyone?
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 07-27-2008, 01:49 PM   #13146
Trader Rating: 2 (75%+)
The small foam pieces that go into your outdrives for the stock diffs should be placed in the outdrives of your spool, thats what I did and I have not had any issues with it!
hope that helps
-randy
JDMmonkeybear is offline   Reply With Quote
Old 07-27-2008, 02:05 PM   #13147
karlo511's Avatar
Thanks.
check the rear pulley to make sure it's centered when assembling the rear diff. if it's off, then it will create a high and low spot causing the belt to tighten and loosen with each revolution.
karlo511 is offline   Reply With Quote
Old 07-27-2008, 02:50 PM   #13148
slakr's Avatar
hope that helps
-randy
Actually, the pins or ears on the dogbones don't slide into the oneway outdrive past the beveled portion of the slots on the outdrive. It is as if these pins or ears are to big or the slots in the oneway outdrive are to small. Can't even get the dogbones in far enough to stand the tires straight.
Old 07-27-2008, 06:25 PM   #13149
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
I've got a new pro diff in the package if anyone needs one. PM me.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 07-27-2008, 10:29 PM   #13150
Geek_Speed's Avatar
For those wondering, we took the spur / middle pulley assembly apart, rebuilt it, recentered it (with great care) put it back together, and that did indeed correct the problem.
Thanks for the suggestion.
Old 07-28-2008, 01:34 PM   #13151
Khador12's Avatar
Was able to get my first race on my TC this weekend. I used the stock setup and had a hard battle to get the victory. The set up is a little on edge, how can I get more of a neutral setting on asphalt? I was using Jaco blue tire and a 5.5 brushless.
Khador12 is offline   Reply With Quote
Old 07-28-2008, 02:54 PM   #13152
STLNLST's Avatar
Trader Rating: 19 (100%+)
What set up were you running? You need to give some of that info so that people can suggest what to try.
STLNLST is offline   Reply With Quote
Old 07-28-2008, 03:14 PM   #13153
Scott B's Avatar
He said he was running the "STOCK" setup, duh can't you READ!!!!
Old 07-28-2008, 03:18 PM   #13154
Scott B's Avatar
You can try my REEDY race setup thats on gearchart.com. They are very easy and smooth to drive. I think it should work for the TC as they are very similar cars. As for the springs try the stock springs first since the Hara "blacks" are hard to find, or you can try HPI "blues".
Old 07-29-2008, 01:26 AM   #13155
is there anyway to adjust anti dive/squat on the cyclone?
timmaay is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
