Old 07-11-2008, 05:48 PM   #12976
Korey Harbke's Avatar
It sounds like one of your pulleys for either the center layshaft is weird, or the front main pulley isnt on straight.... That would be the only thing I can think of that would cause the tight-loose syndrome.
Also make sure the pulleys are perfectly clean with no gunk or gravel in it. Having little chunks of asphalt in your pulleys at SIR isn't totally unheard of. That would be a possible cause for the clicking sound AND the belt tension weirdness.
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-11-2008, 05:51 PM   #12977
Spools make a lot of cars make weird noise. Listen to a tamiya car run around the track with a spool. They make an odd sound when you hit the gas out of the corner. The universal axles will also chatter when they are put at an extreme angle, some more than others.
I've heard the MIP CVD's out of the Moorespeed/World Champ edition kit help cut down on the chatter a bit, but I haven't received my kit to actually start testing all that cool stuff just yet. Should have it early next week I'm thinkin
-Korey
Old 07-11-2008, 06:00 PM   #12978
Rdog's Avatar
Trader Rating: 83 (100%+)
Thanks for info Korey really appreciate it. Ill check that stuff out.
Rdog is offline   Reply With Quote
Old 07-11-2008, 06:18 PM   #12979
Originally Posted by tomracing View Post
does anyone know more about hara's setup at the ETS?
was there loads of grip out there or what.
I spotted some shots of his car on redrc showing he used the extra torsion control thingies under his upperdeck at the front.
then also a glimps of one of the springs (front) to be "a yellow?"
now hpi pro4 yellow would be very hard and perhaps more logical with the torsion control. or hara yellow??? but that would seem strange perhaps so soft at the front?
anyway you twist it hara has been onfire lately and it would be good to find out whats making the speed.
anyone?
here's a redrc shot:
Hi there,
I've been there in the same table as hara.
There was a lot of grip and a very smooth track, he used 70WT at the shocks, for sure hpi yellow (because some times he tried gold spring). And yeah you can believe that the rear shocks were all layed down, but in the weekend they (Moore and Hara) also changed to the 3rd hole counting from down. Pack at front position. But this track is so special that i think it will be dificult to make it work at any other track.
Here is my little mobile gallery: http://picasaweb.google.com/jorgesim...INALSANDERNACH
Also Paul Lemieux was there and super fast also, a big hug to Paul, very nice person and very simple person.
A fantastic weekend.
jorgesimes is offline   Reply With Quote
Old 07-11-2008, 06:23 PM   #12980
And by the way, what is making that speed is for sure HARA.
Old 07-12-2008, 01:30 PM   #12981
What is the biggest 48p spur gear I can put in my cyclone?
HB Cyclone WCE
M8 spektrum, LRP Pulsar 3, Novak GTX
baggus is offline   Reply With Quote
Old 07-12-2008, 01:45 PM   #12982
RC MARKET's Avatar
Yes Hara F shock used which yellow spring ?
RC MARKET is offline   Reply With Quote
Old 07-12-2008, 02:23 PM   #12983
JL
I've used a 79t before and it's pretty close to the limit. I know a few guys say you can go up to 81t but it must be really close to the rear top plate and the ground!
JL is offline   Reply With Quote
Old 07-12-2008, 06:20 PM   #12984
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Do you guys carry the Hara spring set?
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 07-12-2008, 06:22 PM   #12985
shadow102's Avatar
Trader Rating: 21 (96%+)
x2 does anybody carry that spring set?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 07-12-2008, 09:45 PM   #12986
I know RC Market has them, and Hot Bodies USA will have the full hara spring range in stock again very soon from what I understand.
-Korey
Old 07-13-2008, 12:53 AM   #12987
81
Itchy is offline   Reply With Quote
Old 07-13-2008, 01:28 AM   #12988
Thanks IL and Itchy. So i will buy a 80t spur gear to have some free space beetwen the spur and the rear top plate and beetwen the spur and the ground.
HB Cyclone WCE
Old 07-13-2008, 02:02 AM   #12989
mangoman's Avatar
81T is fine, it is the maximum suggested 48 pitch spur.
You can actually use an 82T but it sticks out slightly and can rub on the middle plate. The best thing about the 81T is that for most rubber tyres the rollout is the pinion you use so you dont need to carry a rollout chart :P
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 07-13-2008, 08:23 AM   #12990
tomracing's Avatar
thanks so that was mostly the track then.
so cool hara making a really good comeback lately hope he can keep it up towards the worlds.
jorge mentioned here hpi here:
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
