Old 07-10-2008, 09:50 PM   #12946
Arushmen's Avatar
Originally Posted by BlackedOutREVO View Post
FDR- Final drive ratio
Yeah, gear it up, just make sure it isnt running to hot, I dont like to get my motors over 150-160. But under 170 is good
I liked in the 5's the best for infield punch
Ok, I got It
But is possible to change the timing? I need more rpm
Arushmen is offline   Reply With Quote
Old 07-10-2008, 10:20 PM   #12947
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Arushmen View Post
Ok, I got It
advancing or retarding the timing on the brushless motors only really change the point of where the power band takes place. Sooner in the throtle pull or later in the throtle pull. From what you're describing your best bet would be to gear up from 5.5 to about 5.2-5.0 but pay attention to your motor temps. What are other guys at your track gearing their motors at?
STLNLST is offline   Reply With Quote
Old 07-10-2008, 10:47 PM   #12948
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Is there shades up at SWR? Or is everyone bringing there pop-ups? I dont remember lol
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-11-2008, 12:04 AM   #12949
Originally Posted by mangoman View Post
What motor are you running protyne?
I'm running the HPI X30 30T motor for the HPI challenge held here. Pretty lower powered motor so trying to keep the drive trains as smooth as possible. FDR is 3.8.
protyne is offline   Reply With Quote
Old 07-11-2008, 12:09 AM   #12950
STLNLST's Avatar
shades up but I'd bring the pop ups anyway. It's made of some sort of mesh material. It blocks some sun but still allows some to shine through.
Old 07-11-2008, 02:43 AM   #12951
TheCoolCanFanMan's Avatar
Ok, I got It
I think you will you will find you cannot alter the timing on a Novak 10.5 anyway
Malc
TheCoolCanFanMan is offline   Reply With Quote
Old 07-11-2008, 04:20 AM   #12952
shadow102's Avatar
Trader Rating: 21 (96%+)
Malc
depends on the speed control
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 07-11-2008, 05:10 AM   #12953
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Anyone know the Hara’s spring rate compare to the original Cyclone springs?
Thanks,
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 07-11-2008, 05:44 AM   #12954
Malc
Loosen the 3 screws on the sensor lead end and put your finger nail into the notches in the blue timing ring. Push it anti-clockwise to advance the timing and clockwise to retard. Before you move it, mark the side of the can with the current position. Then move it all the way forward and mark again, then all the way back and mark. That will give you the standard position for this motor and the overall range you can play with. I've had 2 Novak motors and they came with different timing out of the packet.
But be warned advancing the timing will lead to increased heat and you risk over heating the motor if you don't adjust your FDR to suit the increased RPM.
THancock is offline   Reply With Quote
Old 07-11-2008, 06:16 AM   #12955
shadow102's Avatar
As far as shoe goo being used to hold down the servo are there and adverse effects if say i wanted to remove the servo from the chassis...like will it hurt the CF
www.nexusracing.com
www.go-rc.org
Old 07-11-2008, 07:14 AM   #12956
I was talking about the motor itself, I thin you can adjust with a SP speedo, is this right
Malc
Old 07-11-2008, 07:18 AM   #12957
Thats the thing about life, you learn sumit new every day
Malc
Old 07-11-2008, 07:19 AM   #12958
shadow102's Avatar
Malc
Yeah the SP has 9 timing adjustments all advanced
www.nexusracing.com
www.go-rc.org
Old 07-11-2008, 07:33 AM   #12959
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I have not seen it do anything to the CF that its been used on...
Clean up is even easier then servo tape - very clean, not annoying bits of tape left all over
Really don't even need to clean the area once you remove the goo - you can just put down another dab and glue another one down
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-11-2008, 08:44 AM   #12960
Arushmen's Avatar
Thanks everybody for yours opinion.
I have a gtb/10,5 ss sistem combo.
I will try with 5.2 fdr. if I still need more power I will try to retarding timing
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
