Old 07-03-2008, 07:40 AM   #12826
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by BlackedOutREVO View Post
It is lol, WELL somewhat
You should see my nice bent hinge pin, I did it up on the practice day LOL, so I need a new one of those and a arm, then its a car
I don't know if we are going to have enough parts to keep you racing for two full days....
STLNLST is offline   Reply With Quote
Old 07-03-2008, 02:46 PM   #12827
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Well as long as you dont keep hitting the walls and breaking there will be plenty of parts for me
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-03-2008, 07:09 PM   #12828
STLNLST's Avatar
This car is too controllable for me to hit the walls. It was made just for me....
Old 07-03-2008, 08:41 PM   #12829
Give me a 3.5, I will fix that real fast i think
Old 07-03-2008, 09:30 PM   #12830
STLNLST's Avatar
I could give you a 3.5 but at the rate you're going it will never see the track if you don't put the car back together.
Old 07-03-2008, 10:07 PM   #12831
I need to get over to Billys, still have to pay for the SWR cup
I need a 13.5, but im building a D4 WCE, so I will use my 13.5 that falls apart for all I care
Old 07-04-2008, 02:56 AM   #12832
EJ20's Avatar
Hi, I have a question about on what situation should I use the rebound foam? Or not?
EJ20 is offline   Reply With Quote
Old 07-04-2008, 07:49 AM   #12833
STLNLST's Avatar
I would play around with it and see what you personally like. I have tried with and without and really can't say that it's changed the way the car felt running the exact same set up. However....the next time I decide to run something in the cap I'm using o-rings instead of the foam.
Old 07-04-2008, 07:53 AM   #12834
shadow102's Avatar
Trader Rating: 21 (96%+)
I want to add more flex to my cyclone and know the new TC version has adjustable flex. Is this something that can be put on the older cyclone and is so anybody have the part number?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 07-04-2008, 10:55 AM   #12835
lightfoot's Avatar
Adjustable flex ? Really ? How ?
lightfoot is offline   Reply With Quote
Old 07-04-2008, 11:49 AM   #12836
shadow102's Avatar
The main new feature of the upper deck is that it is compatible with our new Adjustable Torsion Control system, or ATC for short. The ATC posts are 2-piece anodized aluminum posts that connect the main chassis and upper deck with variable levels of stiffness. These posts can be left unattached for free lateral movement of the front end, giving you extra traction and steering control, or they can be attached to the upper deck with o-rings of various densities to adjust the level of chassis twist you want to get. You can also use the posts in their 'solid' configuration to firmly attach the front end of the upper deck to the main chassis. Yet another first from Hot Bodies, to give you the best results on the track!
found the part
http://www.hotbodiesonline.com/piw.p...=61283&lang=en
www.nexusracing.com
www.go-rc.org
Old 07-04-2008, 12:01 PM   #12837
RC MARKET's Avatar
found the part
Yes Hara had in Euro Championship used !
RC MARKET is offline   Reply With Quote
Old 07-04-2008, 12:06 PM   #12838
I have made a custom fiberglass rear top deck to mine Cyclone WCE. It does seem to improve rear traction.
You can buy the rear top deck from the TC (i believe it fits the regular cyclone) as soon at it becames available (i just couldnt wait, hence the homemade top deck ).
Itchy is offline   Reply With Quote
Old 07-04-2008, 01:56 PM   #12839
cyclone speed's Avatar
Hi, how often do most of people rebuild there diff, because mine after 30 minutes of run when i turn one wheel the other one will rotate in diferent way (that's normall) but it will rotate like if there was no diff grease in it like if it was grinding, and how do you adjust it very tight or very smooth .
Could someone tell me when to adjust a diff very tight or very smooth.
cyclone speed is offline   Reply With Quote
Old 07-04-2008, 03:02 PM   #12840
EJ20's Avatar
Thanks! Clint. I was thinking if it will less aggressive w/o the foam, easy for the tires ( less overheat )? Especially at SpeedWorld? And hopefully if you know what's the best inserts for the track? I heard a rumor about RP insert?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
