Old 06-27-2008, 12:25 PM   #12811
RC MARKET's Avatar
Originally Posted by diesel View Post
Are you using serpent S400's gear diff on your cyclone?
Thanks.
before N year product !
RC MARKET is offline   Reply With Quote
Old 06-27-2008, 01:44 PM   #12812
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Originally Posted by STLNLST View Post
Futaba 9550 and the Airtronic 94360
The Futaba is in there now for it's smaller foot print.
That's what I was looking for, a smaller foot print. Thanks!
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 06-28-2008, 08:40 AM   #12813
Default Cyclone Tc top deck
just putting together a Cyclone TC on the setup board the chassis is nice and level, as soon as i fit the topdeck it pulls the bulkheads together and i can rock the car from side to side slacken the deck of and it lies flat.
anybody had the same prob wondered if i used a topdeck from wce would this cure the problem.
Cheers
Kev-h
kev-h is offline   Reply With Quote
Old 06-28-2008, 08:50 AM   #12814
STLNLST's Avatar
Trader Rating: 19 (100%+)
the servo doesn't hang off the side of the chassis and it's a hair lighter than my Airtronics servo so that's less weight to add to the battery side to balance the car from left to right using lipos.
STLNLST is offline   Reply With Quote
Old 06-28-2008, 05:20 PM   #12815
ASM
ASM's Avatar
Dude, you couldn't have read my mind any better. I'm using lipos too and I'd like to lessen the weight needed on the right front. It's almost ridiculous!
Scott Meeks
USVTA Member #116
Old 06-29-2008, 11:35 AM   #12816
RC MARKET's Avatar
Hara Won in Euro Championship Round 4
Hot Bodies Cyclone-sat-1haracyclone-1.jpg   Hot Bodies Cyclone-sat-1haracyclone-4.jpg   Hot Bodies Cyclone-lrsun1modwinners-1.jpg
Old 06-30-2008, 08:17 AM   #12817
cyclone speed's Avatar
hi i have a hot bodies cyclone moor speed WCE and i run at wlrc race track . I was wondering if anywone could help me out please .I would like to know your setup at wlrc for this car
This is my setup :
108 spur and 35 pinion
3mm spacer between the upper bulkhead and the inner pivot for front
and 2mm between upper bulkhead and inner pivot for rear
5mm front ride height
5.5mm rear ride height
5.5mm droop front
5mm droop rear
standart suspension 2 holes ,1mm each ,40w oil standart spring gold rear silver front
camber 1.5
castor 4
wheelbase is standart
and for the "dive" and"squat" is: 1.5mm under the suspensionpivot block rear
and 2mm front suspension pivot block and 1mm under rear front suspemsion pivot block dodge stratus bodyshelle
for the toe angl because i dont have the proper tools to mesaure it there is 25mm difference between each palstic thing that screw themselves to the turnbuckles
4mm ackermann
and i think thats it
for the elctronics:
lrp5.5turn gearing 7.5 (108 spur 35 pinion)with novak GTB 1st brushless profile with gemini 2 transmitter with micro 41 mhz receiver and T2M diamond digital servo (0.12 @ 60 , 13 kg torque) and finally i have 1 pack of orion SHO 4200 batteries , + 1 pack of demon ep 4200 + 2 pack of LRP hv2 vtec 4200 bigmama
and i forgot to say that i never run there when there are races i only go weekdays to practice myself
Thanks alot if you guys could help me out
cyclone speed is offline   Reply With Quote
Old 07-02-2008, 05:24 PM   #12818
shadow102's Avatar
Trader Rating: 21 (96%+)
Hey everybody just bought my first cyclone...upgrading from a pro4 so i can interchange parts running both chassis. i am running the car on asphalt mostly on 36r sorex's with a 13.5 brushless lipo setup. The surface is med to high grip and extremely bumpy. I am looking for a setup to get me started and competitive any body have a couple good setup sheets i can try thanks?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 07-02-2008, 06:10 PM   #12819
Woz
is there a HB solution for the rear toe?
Woz is offline   Reply With Quote
Old 07-02-2008, 06:27 PM   #12820
Scott B's Avatar
Trader Rating: 43 (100%+)
My Reedy setups are on gearchart.com. They should be a good starting point for most tracks.
http://www.gearchart.com/index.cfm
Pm me if you have any questions.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 07-02-2008, 07:44 PM   #12821
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Scotty, any changes I should make for the SWR cup?
Also, is the 13.5 still a go for me?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-02-2008, 09:04 PM   #12822
STLNLST's Avatar
Just get the car together first.....LOL
Old 07-03-2008, 03:39 AM   #12823
shadow102's Avatar
Ok bare with me as i am still a cyclone newb...Before the car gets here i wanted to order a couple parts i know i am going to need/want. I am looking for the part numbers on a few things:
Belts for the 18t pulley
Spool (i know there are a couple versions not sure which one i need)
18t pulley (not sure if i need locked or one way i have no idea which does what)
aluminum servo mount
moorespeed hinge pins and shock shafts.
I think that should about do it.
The other question i have is i was looking at buying the TC version before i found a good deal on a upgraded black version. The TC version has the new variable twist deck design i was wondering if this is possible to run on the older cyclone or if its even worth it.
www.nexusracing.com
www.go-rc.org
Old 07-03-2008, 04:23 AM   #12824
Hi Guys again,
No you haven't scared me off. I have a question for you. Have any of you guys ever tried putting A123's into a Cyclone S. If you have, how have you found it?
Pannda
Pannda is offline   Reply With Quote
Old 07-03-2008, 07:38 AM   #12825
It is lol, WELL somewhat
You should see my nice bent hinge pin, I did it up on the practice day LOL, so I need a new one of those and a arm, then its a car
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
