Old 06-06-2008, 07:39 PM   #12571
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
Originally Posted by k_bojar View Post
plenty good....
cool im used to running truggy where you have to have a 76 chevy steering box to turn em.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Old 06-07-2008, 10:06 PM   #12572
Is it necessary to run the brushless motor mount with the 18t pulleys? Does anyone run them together? It seems like the brushless motor mounts have become scarce.
Tony Vega is offline   Reply With Quote
Old 06-07-2008, 11:56 PM   #12573
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
All the BL motor mounts are for is for huge spurs..... So no, you dont need one for the other. If your running mod, then run the BL motors mounts and stock pulleys, stock, 19t run the stock motor mounts with the 18T pulleys
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 06-08-2008, 07:08 AM   #12574
STLNLST's Avatar
Trader Rating: 19 (100%+)
All I can say is WOW. This car was so dialed yesterday that I TQ'ed and won 10.5 at Norcal. The cheap fix for the rear toe in worked as well. Here's the break down for what to do.
Tamiya 416 rear hubs and the rear outter hinge pins is all you need and a reamer. The hot bodies rear outter hinge pins are 2.5mm and you need to ream the outter part of the arm to 2.6mm to fit the Tamiya hinge pins. Once you do this your toe in worries are over. (Insert clapping and rejoice) Now here's the catch... but it's a good one if you ask me. The Tamiya rear hub is shorter in height than the hotbodies so you will have to use shims in order to get it back to regular height. I added 3mm of shims. The last catch is that the holes on the Tamiya hub are inbetween the what we use for hotbodies. On the Hotbodies we always use the inner hole on the hub. The Tamiya hub has their hole inside the hotbodies inner hole and the Tamiya outter hole is inbetween the Hotbodies inner and outter hole (did I lose anyone in the explaination) So what I ran was the Tamiya ouuter hole (middle of the Hotbodies holes) The car was even better than it was for the Reedy race. I also made some spring changes and moved the rear shocks out a couple of holes.
This set up was dialed and Norcal yesterday. It's definately one of the better set up's I have run on the car. Scotty would be proud of me If you were at Norcal yesterday you saw the Black Hara in action I also palyed around with bodies yesterday and really liked the all purpose stratus.....remember that body? The speedworld cup is gonna be fun. The complete set up I ran will be posted today for sure. I only have one thing to do with my kids and other than watching the playoff game I have no other plans as of right now.
STLNLST is offline   Reply With Quote
Old 06-08-2008, 07:28 AM   #12575
what are the part numbers for those two tamiya parts?
TomB is offline   Reply With Quote
Old 06-08-2008, 07:31 AM   #12576
STLNLST's Avatar
I will get those for you once I re pull out my rc gear. I knew there was something I forgot.
Old 06-08-2008, 07:45 AM   #12577
STLNLST's Avatar
Hinge pin part #53917
Rear hub part#51333
Old 06-08-2008, 08:26 AM   #12578
RMF-888's Avatar
Send a message via Yahoo to RMF-888
i just upgrde my 16t pulley to a 18t pulley can anyone show or post the computation when i use 18t pulley on my WCE tnx
RMF-888 is offline   Reply With Quote
Old 06-08-2008, 10:29 AM   #12579
STLNLST,
Do the Tamiya hubs break easy? Simple fix, and cheap to, I like it
Old 06-08-2008, 10:57 AM   #12580
bmmer701's Avatar
Trader Rating: 17 (100%+)
(spur/pinion) * 2.167 (for 18t pulleys)
bmmer701 is offline   Reply With Quote
Old 06-08-2008, 01:31 PM   #12581
STLNLST's Avatar
Originally Posted by BlackedOutREVO View Post
STLNLST,
I don't know. I only had one crash and it didn't really upset the car. The stock HPI hubs didn't really break easy. The two times I replaced hubs were due to the ball studs breaking inside them. The hubs were fine.
Old 06-08-2008, 01:42 PM   #12582
wats the differnce running the 18teeth pulleys to the standed 16 ones? dont want to buy them if they dont make a huge differnce
thanks mark
mwoods is offline   Reply With Quote
Old 06-08-2008, 02:14 PM   #12583
KHoff7's Avatar
18 tooth pulleys give you a taller final drive, you don't really need them.
Has anyone tried a cyclone carpet conversion? are they even available?
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 06-08-2008, 04:54 PM   #12584
SammyZ's Avatar
Trader Rating: 138 (100%+)
i have a moorespeed with a HB 3.6mm chassis, the low mount foam tyre shock tower, the 2.5mm top deck, the solid middle deck, a front ball diff and some other cool parts. Its awsome on carpet!
SammyZ is offline   Reply With Quote
Old 06-08-2008, 05:50 PM   #12585
RMF-888's Avatar
tnx a lot
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
