Old 06-03-2008, 12:51 PM   #12511
dizzy1's Avatar
Trader Rating: 24 (100%+)
STLNLST- What was the HB guys doing to fix it? Just wonder if it involved loosening and moving the blocks, works but 1 good hit and it's out the window.
dizzy1 is offline   Reply With Quote
Old 06-03-2008, 04:04 PM   #12512
Im curious about that to...
I tried diferent things, but without any success
BTW- I tried 3 diferent hubs, one of them was from an old PRO4, but the problem remained, so im not sure if the problem is 100% hub related.
Itchy is offline   Reply With Quote
Old 06-03-2008, 04:41 PM   #12513
bmmer701's Avatar
Trader Rating: 17 (100%+)
maybe the blocks?
bmmer701 is offline   Reply With Quote
Old 06-03-2008, 04:57 PM   #12514
lightfoot's Avatar
Originally Posted by bmmer701 View Post
maybe the blocks?
Thats my vote...
lightfoot is offline   Reply With Quote
Old 06-03-2008, 06:07 PM   #12515
maybe the blocks?
I dont think so. i reversed the block (that is i mounted it backwards, with the '3.0' faced down) and i got the same reading: 3 left side, 2 right side. If it was the block the problem should have been reversed. Also a friend with the same problem tried a different toe block on the rear and got the same readings.
I guess this might be the sum of too big tolerances in the hubs, arms and the chassis plate.
Can you confirm in wich side are the toe is wrong?
The three Cyclones i know all have the same problem: less toe on the RIGHT side.
Old 06-03-2008, 07:00 PM   #12516
STLNLST's Avatar
Trader Rating: 19 (100%+)
It's pretty hard to explain on the net but I'll give it a shot. The toe problem is that the left rear has more toe than the right side......what Hara showed me was take your left side hub in your hand and use a varible rate dremel or hand tool and place it in the hinge pin hole while slightly turning the hub to the left. Do this until the bit comes out on the other side.
For the right side you would do the same thing while slightly turning to the left as well.
This method seem to work for him but when I put these hubs on the car the toe is still off. I may switch them from left to right to see if by some chance they were put on the wrong side. It looked and sounded so simple when he did it but I don't trust myself to get it correct in my hands.
If I have confused anyone I do apologize as it's much better to be shown this trick rather than my butchered attempt to explain it.
STLNLST is offline   Reply With Quote
Old 06-03-2008, 08:00 PM   #12517
Understood perfectly
Unfortunely i have already tried it without any sucess. I only did it to the right hub (since my left is 3 spot on as it should). I started shiming a litle, then a litle more, then a litle more. It was stull not enough, so i did the same to the rear arm. In the end i did get it to 3, but i also had like 10 of slop!
(and a wasted hub and arm)
In any case thanks for the explanation
Old 06-03-2008, 08:25 PM   #12518
arn671's Avatar
Trader Rating: 14 (100%+)
Default Measuring front droop
Hey Guys, I was looking at set up sheets for asphalt and am wondering where the front droop is measured from? Is it under the outer hinge pin or under the nub/setscrew for outer hinge pin? Thanks in Advance!
arn671 is offline   Reply With Quote
Old 06-03-2008, 08:37 PM   #12519
CSF0623's Avatar
from under the hinge pin
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 06-03-2008, 08:46 PM   #12520
If I want to run a brushless motor with a stock Cyclone S, do I need to get the optional motor mount?
aviaar is offline   Reply With Quote
Old 06-03-2008, 08:57 PM   #12521
lightfoot's Avatar
Nope... I just changed mine out... no problems...
Old 06-04-2008, 06:55 AM   #12522
If you run Mod you may want the brushless motor mount, I run a 114 spur and I think there is room for 120 with the BL mount.
Lazer Guy is offline   Reply With Quote
Old 06-04-2008, 10:23 AM   #12523
mangoman's Avatar
Depends on brushless motor and cells.
6 cell, 3.5 and 4.5 you probably need it
5 cell you dont.
But i suspect you are not going to run a big motor like that. If you are you will want to upgrade some parts on your car.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 06-04-2008, 10:47 AM   #12524
Woz
does anyone know if the new Cyclone TC has the same problem with rear Toe?
Woz is offline   Reply With Quote
Old 06-04-2008, 01:26 PM   #12525
STLNLST's Avatar
received my precision order today so I will install the alum hubs tonight and check toe in and report back to you guys and then I will be checking out my other planB this Saturday and let everyone know if the toe is correct. I'd rather go with plan B because it's cheaper and everyone can do it.
Stay tuned...................
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
