Old 05-31-2008, 03:40 PM   #12481
Scott B's Avatar
Trader Rating: 43 (100%+)
Originally Posted by prodriver View Post
Hi Guys, from the pics from the reedy race, what shell is that that Hara is using?
Ricky
Hara used the Protoform Mazda Speed 6.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 05-31-2008, 03:57 PM   #12482
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
My bad
When did Hara switch bodies then? lol im behind
Originally Posted by STLNLST View Post
You might be better off going by Billy's to get some because I don't know when I'll see you next to give it to you.
You racing at the next SWR race?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 05-31-2008, 04:00 PM   #12483
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by BlackedOutREVO View Post
My bad
When is the next SWR race? I'll be at norcal next weekend.
STLNLST is offline   Reply With Quote
Old 05-31-2008, 04:04 PM   #12484
Shoot. Its on the 7th
I need to buy some anways. Thanks though
Old 05-31-2008, 04:06 PM   #12485
HarshGuy's Avatar
Hey STLNLST, or Scotty
Can I borrow some diff grease? Im pretty sure I can find my black grease, but I cant find my lil HB's thing of the clear stuff, or whatever you guys use for the main diff balls
My diff was on the gritty side, so I tore it down...
Scotty boils his main diff balls.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-31-2008, 04:13 PM   #12486
STLNLST's Avatar
I'm gonna get my race in at Norcal and then get geared up for the Speedworld cup. I'm shooting for a top 3 finish in mod at this event.
Old 05-31-2008, 05:14 PM   #12487
LOL, I already boiled it all, just need a lil grease in it
Old 05-31-2008, 06:28 PM   #12488
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
For the best diff lube..... I just happen to know the guy
http://www.wickedfastracing.com
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 06-01-2008, 06:24 PM   #12489
Did anyone else find that the rear toe block (3.0) that comes with the cyclone tc is different from side to side.
savageguy is offline   Reply With Quote
Old 06-01-2008, 06:41 PM   #12490
I need to try all this stuff... But for now, the LHS is the easiest....
Old 06-01-2008, 06:49 PM   #12491
i built my pro diff set recently and noticed the outdrives and the rings from the old diff do not fit. does the pro diff have a option alloy/steel outdrive set one can buy for it? the plastic version diff outdrives on the pro diff do not have the little adjustment hole to reach the screw head once it is installed which i find a pain.
TomB is offline   Reply With Quote
Old 06-01-2008, 07:57 PM   #12492
Scott B's Avatar
Well since in the new pro-spec diff the screw goes in on the short side now instead of the lond side as in the old diff, there won't be an adjustment hole like before. And yes there are alumn outdrives for the pro-spec diff.
Old 06-01-2008, 09:51 PM   #12493
lightfoot's Avatar
YES... mine was the same way... I was getting 4 degrees on left rear and 2 degrees on right rear... I posted a comment about it a week ago and received no comment... I'm guessing the block is off center...
lightfoot is offline   Reply With Quote
Old 06-01-2008, 10:07 PM   #12494
STLNLST's Avatar
just ordered me up som alum blocks for the car. I expect my corner speed to be even faster with equal toe from left to right. Mine rear toe was fine until I broke a ball stud in my right rear hub. Every other block has been off.
Old 06-02-2008, 01:32 AM   #12495
how how can you adjust it quickly then? if they designed an L shaped tool to reach the screw head that would be fine, but i don't think they do anything like this, plus i think the cvd sits too far in and there isn't enough room to slip in a tool to get to the screw head....does this mean to access and adjust the diff we need to pop of one of the ballcups?! = increased slop, and a pain int he butt when adjusting in pit lane. it means taking body of and taking a long time
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
