Old 05-26-2008, 05:27 AM   #12406
Smartypants,
The best model shop in the Orlando area is Superior Hobbies, based in Casselberry, about a half hour drive from International Drive area. They do sell some hotbodies stuff but when I was there last September looking for a WCE Cyclone, they never had any :-(
There is also Central Florida Hobbies which is a bit closer to International drive, somewhere close to Central Florida Fair Grounds. Look them up on the web. They deal with Hotbodies also and you might have a better chance getting a new TC there.
Raymond.
rk-cyclone is offline   Reply With Quote
Old 05-26-2008, 07:47 AM   #12407
CLK@racing's Avatar
Default Hara wins Reedy ROC 2008
Atsushi Hara just won the Reedy 2008.
Congratulations to him and team HB.
I know this may be too early to ask, as most racers are still having their hangover from the race, but any photos of Hara's car to share?
Eager to see his setup to win the tough Reedy Race.
Real man races Modified.. simple.
CLK@racing is offline   Reply With Quote
Old 05-26-2008, 09:12 AM   #12408
STLNLST's Avatar
Trader Rating: 17 (100%+)
We were all pretty much running Hara's set up. I will post what we ran in mod and let ya have a look at it. I learned allot from Hara this weekend and he helped get my car pretty dialed. Just couldn't put in that killer run. My boy Billy made the mod A main running this set up also. I'll try to give you a brief run down of the set up now cause after a week of straight racing I might be killed if I'm caught on the computer talking RC stuff.....LOL
Front
pink springs
40wt oil (losi) no foam spacers in bladder
#3 pistons
#2 position on front tower (WE)
outside hole on front arm
1.4 front sway bar
2.0 front block
droop 5mm on blocks (change I made not sure what Hara's was at)
1.5mm shims under all front suspension blocks.
4mm ackerm
3mm spacer under front camber tie rod
arms all the way forward. (spacers in rear of arms)
1.5 of camber
5mm ride height
Rear
silver springs
40wt oil (losi) no foam spacer in bladder
#3 pistons
#1.5 position on rear tower (WE)
middle hole on old arm (outside hole on new arm)
1.2 rear sway bar
3.0 rear block
1.5 mm shims under all suspension blocks.
rear hub spacers 0.75 in front 2.0 in rear
2mm spacer under rear camber tie rod
arms all the way back (spacers in front of arms)
1.5 of camber
5mm ride height
I was using the Black Cyclone with all the hop up's and Billy had a WE with a 3m racing 5 cell chassis with the new arms. His car was slightly better than mine but I think it's because he's a better driver. Our laptimes were only 2 tenths off but he was more consistent. This is what Hara had us put on our cars.
STLNLST is offline   Reply With Quote
Old 05-26-2008, 09:49 AM   #12409
Trader Rating: 28 (100%+)
Wow.That's almost the exact same setup I run everywhere.
racenut123 is offline   Reply With Quote
Old 05-26-2008, 09:52 AM   #12410
One thing to note.The setups most used at Reedy are very unique because of the conditions of the track and tires used.It really is like no other place I have raced before.I think alot there would agree.Gotta love the CYCLONE!
Old 05-26-2008, 10:00 AM   #12411
STLNLST's Avatar
The inserts that Speedmind uses really hurt the tire's performance a little but was still better than everything else we were sent to test with. These same tire's with hara inserts, Yok firms, or sorex firm B's would have been much faster and wouldn't over heat like these did. You had to adjust your driving and set up's slightly but it was the same for everyone.
Old 05-26-2008, 10:14 AM   #12412
Yeah those tires with Hara inserts would have rocked.With the speedmind garbage it was agony.Your right the same for everyone in the end.I got my new TC coming tomorrow.Cant wait.
Old 05-26-2008, 10:21 AM   #12413
STLNLST's Avatar
The only thing I'm going to get is the new arms. I already have the new diff in the car and nothing else is a must have. I just need to find some alloy ZERO degree hubs for the car. I think HB only offers a 1 degree rear hub. I'd prefer the ZERO. Hara said ever though you can put on a 2 degree rear block and get a total of 3 it's not the same feel. He prefers 3 inboard and ZERO outboard.
Old 05-26-2008, 02:17 PM   #12414
rc pete's Avatar
Default Which springs?
I'm looking at the HPI spring chart here http://www.hpi-europe.com/pdfs/spring_chart.pdf, which has duplicate colors.
Can anyone tell me which set of springs I should be looking at for the Cyclone?
HPI Pink: #6849 (15.2lb/in) or #6759 (30.2lb/in) or #6548 (Pro4 17.9lb/in)
HPI Silver: #6825 (8.6lb/in) or #6543 (Pro4 16.9lb/in)
HPI Gold: #6826 (11.2lb/in) or #6544 (Pro4 19.0lb/in)
There are also 4 different blues, 4 reds, 5 yellows, 2 whites... am I looking at the right chart?
Thanks.
rc pete is offline   Reply With Quote
Old 05-26-2008, 02:31 PM   #12415
you want the PRO4 springs.
Old 05-26-2008, 04:39 PM   #12416
RC MARKET's Avatar
have Hara in reedy race photo ?
RC MARKET is offline   Reply With Quote
Old 05-26-2008, 04:57 PM   #12417
bob szeto's Avatar
John,
I was there at the Reedy Race last weekend, Hara was using the Pro4 Silver springs in Front & Rear.
Bob S.
bob szeto is offline   Reply With Quote
Old 05-26-2008, 05:17 PM   #12418
Yeah,I was told that Bob. His setup is really really close to what I have been running except for the front silver springs.
Team I'm Over It
Old 05-26-2008, 05:28 PM   #12419
bob szeto's Avatar
John,
Do you know where I can get those #3 pistons?
Thanks,
Bob S.
Old 05-26-2008, 05:33 PM   #12420
Did you try Billy @ Speedworld? If not www.rcmarket.com.hk has them. Try Billy 1st.
Team I'm Over It
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
