Old 05-24-2008, 10:03 AM   #12391
bmmer701's Avatar
Trader Rating: 17 (100%+)
Originally Posted by RC MARKET View Post
yes best diff !
yes i agree. before even if i'm using ceramic diff balls and thrust it can only last for like 6 runs using a mod motor. but now, i already ran it for 22 runs with a mod motor and 7 runs of using a 23t motor and it's still smooth. finally, you can relax on your heat without rebuilding your diff in the mains
bmmer701 is offline   Reply With Quote
Old 05-24-2008, 10:18 AM   #12392
andyh's Avatar
Default ...
Originally Posted by jimbobmahua View Post
Hi Andy,
Can you tell me if they are new arms on the TC too? I mean are the rear arms slightly shorter or have HB just gone with a new mold?
Cheers
New arms, they are the same arms left/right (so no more..I only have a left/right arm..etc )
Thanks,
AH
andyh is offline   Reply With Quote
Old 05-24-2008, 11:49 AM   #12393
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Originally Posted by andyh View Post
Hot Bodies does sell direct to shops. Shops can contact Hot Bodies directly to set it up.
The TC has:
-New chassis/upper deck, accepts molded battery trays, additional cut outs for more tuning options
-New re-designed rear diff with a larger diameter diff screw
-Combination spool/one way front diff
-Comes stock with 18T pulleys/belts
-FRP middle block for added traction
-3.6 mm front and rear shock towers (front tower also sits lower)
-Re-designed sway bar mounts (more tuning options)
-Re-designed suspension arms (left and right are the same)
RE: WCE Andy Moore Cyclone
The WCE Cyclone was created as a replica of Andy's ride at World's, so it does have more "bling-bling" parts.
The TC is the next generation of the benchmark Cyclone chassis, so more function, less a few "bling-bling" parts.
Thanks,
AH
AndyH, where can we find the pro-diff and front spool/one-way here in USA?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 05-24-2008, 03:20 PM   #12394
andyh's Avatar
Default ...
Either on line at the HB shop or contact you're local store and they can either order directly from us or from they're distributor.
http://www.hotbodiesonline.com/products/en/67720.html
Have to see if we have the new spool/one way front diff as a spare part set yet, we'll be back in the office on Tuesday
Thanks,
AH
Old 05-24-2008, 08:54 PM   #12395
ASM
ASM's Avatar
I have a brand new diff still in the bag..........it can be yours and shipped to you for $47 which is $42 for the diff (RC Market's price) and $5 shipping. I bought two when I got mine. Let me know if you're interested.
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 05-24-2008, 09:46 PM   #12396
SammyZ's Avatar
Trader Rating: 138 (100%+)
i ran this car for the first time on assphalt today and it performed extremely well with a standard tarmac setup from HBonline, that setup works extremely well on medium-hi bite assphalt. I opted for the one-way over the spool for forgiveness.
Track temp was probably about 80F, cool day, MuchMore 24r's were the hot ticket. They lasted the entire day (8 runs) and still have life left.
SammyZ is offline   Reply With Quote
Old 05-25-2008, 12:45 AM   #12397
Thanks,
AH
Sorry maybe i should rephrase my question...
I notice the front and rear lower arms for the HB Cyclone TC are not the same mold as for the previous models (black, Hara, Surikarn and WCE). They have the sway bar mounts on both sides of each arm and the first prototype TC that Hara tested looked like it had a modified front arm on the rear. So i was curious if the extra sway bar mounts are so the arms can turned over for further tuning options? Or are the rear arms just lightly shorter than from the previous model Cyclones?
Cheers
jimbobmahua is offline   Reply With Quote
Old 05-25-2008, 01:31 AM   #12398
Thanks,
AH
Where can you find arms, shock towers, Chassis, ect. I have looked everywhere and cant find any parts for this car?
Mitch
Mitch P. is offline   Reply With Quote
Old 05-25-2008, 02:22 AM   #12399
The new arms save you redrilling the old style as they have the new positions already moulded in.
Basically on low grip the hot ticket was to turn rear arms round and drill a hole 13mm form rear hub hinge pin hole.
This gives you a shock position between holes 2 and 3 from inside on standrd arms. thus you also had to drill new droop screw and roll bar mount holes
The new arms have all this so are a must buy again.
This extra hole dosent work on carpet but is superb on ashphalt.
TBH i found all my parts on rc market and after a inital hiccup they turned up real quick to uk.
richard baker is offline   Reply With Quote
Old 05-25-2008, 02:37 AM   #12400
Thanks alot for that explanation, i appreciate it
Old 05-25-2008, 04:13 AM   #12401
RC MARKET's Avatar
HB June release a lot option parts for Cyclone TC
http://www.hpiracing.co.jp/
RC MARKET is offline   Reply With Quote
Old 05-25-2008, 04:14 AM   #12402
RC MARKET's Avatar
posted June release !
Old 05-25-2008, 04:17 AM   #12403
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Originally Posted by B18C Turbo View Post
all cyclones do that, both of mine do.
Unfortunately they have had a batch problem I'd say. I had some older hubs which were perfect, but if you don't, try and get some alloy rear hubs from HPI. Pretty sucky that you have to do it though.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 05-25-2008, 09:56 AM   #12404
Does anyone know of any Florida based model shops that have the cyclone TC instock as i am travelling there soon
Smartypants is offline   Reply With Quote
Old 05-25-2008, 11:00 AM   #12405
RC MARKET's Avatar
Yes rear hub toe-in had problem !
& new sus. arm too soft !
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
