Old 05-21-2008, 12:17 PM   #12376
Originally Posted by B18C Turbo View Post
its the same car with different parts, you dont need to drive the new TC, it has a different diff in the back, the bulkheads are either taller or shorter and the upper bulkheads are taller or shorter,so no difference in performance just makes it even harder to find replacements.
The chassis is different but pretty much the same, just some battery slots for NI-MH. A different top deck with an option for the ATC posts. There aren't alot of hop-ups on it like the WCE.
-alloy shock mounts
-alloy belt tensioner
-alloy spring pirches
-Ti turnbuckles
-MIP CVD's
-Graphite bumper brace
-purple shock collars
-alloy servo mounts
-Ti coated hingepins/shock shafts
the new TC doesnt have these parts.
thanks for the info ive already got the worlds car and i no someone that want a new tc car.
mwoods is offline   Reply With Quote
Old 05-21-2008, 01:27 PM   #12377
andyh's Avatar
Default ...
Hot Bodies does sell direct to shops. Shops can contact Hot Bodies directly to set it up.
The TC has:
-New chassis/upper deck, accepts molded battery trays, additional cut outs for more tuning options
-New re-designed rear diff with a larger diameter diff screw
-Combination spool/one way front diff
-Comes stock with 18T pulleys/belts
-FRP middle block for added traction
-3.6 mm front and rear shock towers (front tower also sits lower)
-Re-designed sway bar mounts (more tuning options)
-Re-designed suspension arms (left and right are the same)
RE: WCE Andy Moore Cyclone
The WCE Cyclone was created as a replica of Andy's ride at World's, so it does have more "bling-bling" parts.
The TC is the next generation of the benchmark Cyclone chassis, so more function, less a few "bling-bling" parts.
Thanks,
AH
andyh is offline   Reply With Quote
Old 05-21-2008, 01:47 PM   #12378
RC MARKET's Avatar
Originally Posted by RCLocos View Post
Hey guys,
speedtechrc has the Cyclone TC in stock for just $379
good price !
RC MARKET is offline   Reply With Quote
Old 05-21-2008, 02:07 PM   #12379
SammyZ's Avatar
Trader Rating: 138 (100%+)
3.6mm shock towers? that means they make 5 versions of the cyclone shock towers
-black cyclone 3mm
-hara/surikarn 3.5mm HD
-Moorespeed 3.5mm
-Low mount 3.5mm foam tyre
-3.6mm TC
SammyZ is offline   Reply With Quote
Old 05-21-2008, 02:23 PM   #12380
andyh's Avatar
Default ...
-black cyclone 3mm
-Moorespeed 3.5mm
-3.6mm TC
RE: shock towers
Specs are pretty much dictated by requests/inputs from the team guys, so it's a continuous evolution.
Thanks,
AH
Old 05-21-2008, 02:56 PM   #12381
the last two are the same shock towers
bionictony is offline   Reply With Quote
Old 05-21-2008, 04:20 PM   #12382
SammyZ's Avatar
the low mount foam tyre shock tower is stock on the new TC?
Old 05-22-2008, 02:56 PM   #12383
yeah 61287 is the part number for both shock towers
Old 05-22-2008, 06:08 PM   #12384
Originally Posted by andyh View Post
RE: shock towers
Thanks,
AH
Hi Andy,
Can you tell me if they are new arms on the TC too? I mean are the rear arms slightly shorter or have HB just gone with a new mold?
Cheers
jimbobmahua is offline   Reply With Quote
Old 05-22-2008, 08:32 PM   #12385
SammyZ's Avatar
umm, so they put a foam tyre shock tower on their new rubber tire car?
Old 05-22-2008, 11:30 PM   #12386
Guys
First run last night with the new diff in my WCE, all i will say is wow its a must have!
Its far far smoother doesnt slip at all, an still feels as good after 8 runs as it did when built.
The car handles much much better.
Well done Hot Bodies.
richard baker is offline   Reply With Quote
Old 05-23-2008, 03:42 AM   #12387
RC MARKET's Avatar
Originally Posted by richard baker View Post
Guys
yes best diff !
Old 05-23-2008, 11:40 PM   #12388
lightfoot's Avatar
Default Cyclone TC rear toe
I just finished building a Cyclone TC ... very nice... but on my set up board I was getting a 2 degree toe-in on the right rear and a 4 degree toe-in on the left rear... as far as I can tell the rear toe is determined by the Pivot Block ( part # 75162 ) which is a 3 degree... I can't figure out why one side of the car is getting more adjustment then the other ??? Is there anything I can do to correct this ? Thanks
lightfoot is offline   Reply With Quote
Old 05-23-2008, 11:46 PM   #12389
STLNLST's Avatar
Trader Rating: 19 (100%+)
The car is working pretty good but the driver can't keep it together for a full heat. I just rebuilt the car again for qualifying and hopefully mother nature doesn't ruin things for us as it's suppose to rain tomorrow.
STLNLST is offline   Reply With Quote
Old 05-24-2008, 08:27 AM   #12390
SammyZ's Avatar
all cyclones do that, both of mine do.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
