Old 05-08-2008, 01:36 PM   #12241
STLNLST's Avatar
Trader Rating: 19 (100%+)
another week and two days and I get to race again......LOL
STLNLST is offline   Reply With Quote
Old 05-08-2008, 01:52 PM   #12242
inconceivable's Avatar
Originally Posted by Scott B View Post
Try increasing the ackerman from 2.5 to 4, and or change the front pivot block from the 1 to a 1.5 or 2, try it and see which one works good for you.
Also you could try raiseing the front rear block from the 1.5mm spacer to a 2mm giving the car some anti-dive. I'm going to be trying this change this weekend.
I recently purchased a Cyclone S to race in some of the "spec class" events they hold here in SoCal. Anyway, I've been meaning to ask a stupid question, what do the pivot blocks do ? The S comes standard with 0 in front and 3 in the rear. My assumption was (or is) that the 3 in the rear is toe in, however the front toe can be changed via tie rods ..... right ? If so, what is 0 do or for that matter what will a 1.5 or 2 do ? Thanks.
inconceivable is offline   Reply With Quote
Old 05-08-2008, 02:13 PM   #12243
dstyles's Avatar
you're dealing with arm sweep with the front blocks...reducing the track width. usually a narrower track width at the front can make the car feel twitchy.
dstyles is offline   Reply With Quote
Old 05-09-2008, 02:41 AM   #12244
mangoman's Avatar
On the front a higher number pivot block will make the steering a little more aggressive. You shouldnt need it on the Cyclone S as it has more flex than the full cyclone and thus should have more grip anyway.
At the rear 3.0 toe in is pretty standard on the cyclone. As the toe in decreases you effectively get more straight line speed/acceleration, however, as it decreases the car will not hold corners as well.
I find with a 540 motor on asphalt 1.5 - 2.0 is about optimal with stock 2.0-2.5 maybe manageable. After that anything else i would leave at 3.0 including a 13.5 brushless motor.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 05-09-2008, 04:04 AM   #12245
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
OK I got my winning 13.5 setup from the REEDY Warmup race up on gearchart.com..
http://www.gearchart.com/setup/setup...RMUP_SETUP.pdf
Any Questions let me know..
Hey Scott - don't know if you noticed this or not, but you FDR is wrong...
The sheet doesn't take into account for your 18t center pulleys and it gives the internal ratio of 2.4375 (16/39) instead of the "proper" 2.1667 (18/39)
Sorry man...Just figured I'd let you know
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-09-2008, 05:15 AM   #12246
Thanks again Scott ...I will try the changes you suggested.
inconceivable
I ran the 0* front block on carpet and my car was very twitchy, I added 1mm wheel spacers to make the front wider and my car was not twitchy at all and drove very nice. I had to keep the wheel nuts tight with the 1mm spacers.
Lazer Guy is offline   Reply With Quote
Old 05-09-2008, 06:22 AM   #12247
Scott B's Avatar
Trader Rating: 43 (100%+)
Ya I know, I could type in the new D/R in the box put it would just change back to the stock ratio.
That's why I noted it on the setup sheet.
My final D/R that I ran was 4.6 with a Novak SS pro 13.5. 100/47
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 05-09-2008, 06:23 AM   #12248
Scott B's Avatar
inconceivable
Make sure you adjust your front toe after changing the front pivot block.
Were you running rubber or foam tires??
Also oneway, diff or spool??
Old 05-09-2008, 08:49 AM   #12249
inconceivable
Sometimes the 0 block makes more initial turn in especially when you have lower roll center in the front.
I would recommend you to move the spacers on the inner hinge pins to make the wheel base shorter (front a-arms will move toward back) when you have 0 block in the front. This will reduce the front drive shaft (cvd) sweep angle.
I hope it helps.
Hi-LowBlow is offline   Reply With Quote
Old 05-09-2008, 12:44 PM   #12250
Wow ... thanks for all the input on pivot blocks and their application. I'll be racing this car this weekend and will try some of these suggestions. Again, thank you !
Old 05-09-2008, 12:48 PM   #12251
This is a "bone stock" spec class that HB is running here in SoCal. No alterations are allowed other than gearing. As a matter of fact you have to run their super swift 27T Saturn motor and grippy Gumball tires
That said, it's running a diff and rubber tires.
Thanks again for the help.
Old 05-09-2008, 06:05 PM   #12252
mangoman's Avatar
Originally Posted by Matt Pocknell View Post
I would start with thickening your oil, try 45-50wt.
Ive always liked 40wt oil, 30wt when i tried it felt too twitchy especially on the front.
30 wt in the rear shocks should be ok though, and ive seen it a few times on setup sheets.
www.smaracing.org
Old 05-09-2008, 09:27 PM   #12253
Thank you
I will make sure my toe is right.
I was running rubber with a diff on some layouts and a spool on others. My Cyclone had so much steering on carpet I had to use a 1.6 sway bar and 0* front block to stop it from hooking coming out of corners on power. I TQed and won every race after that. The xray guys went down working hard on there cars, my Cyclone ruled the carpet this winter in 10.5 rubber and I had fun doing it.
Old 05-10-2008, 08:55 PM   #12254
mangoman's Avatar
Thank you
Lazer guy if you have too much steering try removing the ackerman shims under the side by side ball studs on the servo saver.
That i believe should reduce initial turn in.
www.smaracing.org
Old 05-10-2008, 11:04 PM   #12255
SammyZ's Avatar
Trader Rating: 138 (100%+)
Thank you
wish i coudl get that much steering, what springs/oil are you running? ride height?
SammyZ is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
RMP750
