Old 05-07-2008, 06:24 AM   #12226
RC MARKET's Avatar
Pro Spec 1/16" Thrust Ceramic ball arrived !
RC MARKET is offline   Reply With Quote
Old 05-07-2008, 06:55 PM   #12227
SammyZ's Avatar
Trader Rating: 138 (100%+)
I need some help for assphalt setup, the car keeps coming around, stepping out and then doing a 180, drifting etc...this is on corner entry and exit.
My current setup:
1.5 neg camber all around
30wt AE oil all around
Gold/silver springs
3mm under front ball studs
2mm under rear ball studs
2.5 degree front pivot block
3 degree rear block
no roll center shims
1.6mm front sway bar
1.2mm rear sway bar
4.5mm ride height
6mm front droop
5mm rear droop
Muchmore 24 R premounts
SammyZ is offline   Reply With Quote
Old 05-07-2008, 07:03 PM   #12228
mangoman's Avatar
Soft tyres... what class are you running, i assume you are running stock or brushless stock with a one-way?
Any reason why your arent running the roll center shims? (1.5mm is pretty standard).
Is the rear of the car too hard? Are you using the centre holes on the rear shock towers maybe ditch the rear sway bar **SHRUG**
Pull off the pinion and check there is no binding in the drive train (especially the front universal cross joints).
Also double check the hinge pins arent bent (the front ones are the most likely ones to be out of whack).
I also find that the car can handle funny if youve been putting off rebuilding the diff
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 05-07-2008, 07:04 PM   #12229
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
My current setup:
Gold/silver springs
3 degree rear block
1.2mm rear sway bar
4.5mm ride height
6mm front droop
5mm rear droop
My set up is similar, I have .5 deg of toe, 1.5mm of shims under all the toe blocks, 2.5 toe block in the rear, and 1.5 toe block in the front, copper sway bar in the rear, silver up front, 2mm of ackerman..
24's? How cold is it over there LOL? Thats a soft tire! Are you sure you arent overheating them? That will cause the problem you are having... Maybe try 28's, or 32's
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 05-07-2008, 09:29 PM   #12230
SammyZ's Avatar
you guys are both running 1.5mm shims under the blocks? what does it do? Its like 70 degrees here, the tires dont get too hot!
I also shoulda stated im running on my driveway which is completly unswept, and untreated!
Im just wanted to see what the car would do on assphalt since its pretty dialed on carpet? I was shocked that it would slide like a drift car!
Old 05-07-2008, 09:31 PM   #12231
SammyZ's Avatar
I love building diffs so mine is always smooth, i check all hinge pins after every race, im running 10.5 with a one-way.
Old 05-07-2008, 10:11 PM   #12232
Yup! Raising roll center, which if I remember right is sacrificing transition speed for traction.... How hot is your surface your running on?
Thats def a problem! Why not a track?
Old 05-07-2008, 10:14 PM   #12233
SammyZ's Avatar
the surface was 80 degrees, but it still shoulda been close, the car was scary to drive with the way it would drift.
Old 05-07-2008, 10:34 PM   #12234
STLNLST's Avatar
Trader Rating: 19 (100%+)
driving on the un treated surface would require a slightly different set up. Carpet is normally med to high grip depending on how much traffic the race has. Unswept and untreated is the reason why your car felt like a drift car.
STLNLST is offline   Reply With Quote
Old 05-08-2008, 05:58 AM   #12235
Originally Posted by Scott B View Post
OK I got my winning 13.5 setup from the REEDY Warmup race up on gearchart.com..
http://www.gearchart.com/setup/setup...RMUP_SETUP.pdf
Any Questions let me know..
Scott B
Thanks for posting your setup.... I'm going to try it in mod and see how it works for me this Sunday. I know it's for 13.5 but I am using a 4600MM (a little more than a 10.5) to start my asphalt mod season with. My layout has many tight turn, is there something I should change or should I try it like it is first ????
Thanks again
Lazer Guy is offline   Reply With Quote
Old 05-08-2008, 06:24 AM   #12236
Scott B's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Lazer Guy View Post
Scott B
Thanks again
Try increasing the ackerman from 2.5 to 4, and or change the front pivot block from the 1 to a 1.5 or 2, try it and see which one works good for you.
Also you could try raiseing the front rear block from the 1.5mm spacer to a 2mm giving the car some anti-dive. I'm going to be trying this change this weekend.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 05-08-2008, 06:42 AM   #12237
STLNLST's Avatar
I'm going back to our standard set up. It was consistent and always kept me in the hunt for the win. I tested alot of set up's in two days and find myself sticking with the regular.
Old 05-08-2008, 10:03 AM   #12238
SammyZ's Avatar
what happens when you raise the roll centers?
Old 05-08-2008, 10:12 AM   #12239
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
higher roll center will keep the car from rolling (leaning), making the car react faster and have more traction. On low bite outdoor tracks with
rubber tires a high roll center will get you the best results.
Old 05-08-2008, 12:58 PM   #12240
Matt Pocknell's Avatar
I would start with thickening your oil, try 45-50wt.
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
