Old 04-30-2008, 12:28 AM   #12151
I bet Hara was building a wet car just in case.
Its very difficult to fully waterproof brushless systems in a flat chassis car, so using a tub chassis makes sence.
Also the plastic tub gives more grip due to flex also a great idea for the rain.
richard baker is offline   Reply With Quote
Old 04-30-2008, 01:25 AM   #12152
Matt Pocknell's Avatar
So why was he running it in the dry?
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Old 04-30-2008, 01:42 AM   #12153
JL
Originally Posted by JL View Post
I've just bought a rear WCE shock tower to replace one on my original black cyclone. I've just discovered that the holes in the WCE tower are higher than the original. Because of this I can only set my droop at 6 or less as the shock aren't long enough for me to set the droop where I want.
Have other people found this too? What's the solution? Is it just a case of lengthening the shock?
Can anyone help? I'm sure someone can guide me in the right direction.
Thanks in advance,
Jason
JL is offline   Reply With Quote
Old 04-30-2008, 01:58 AM   #12154
mangoman's Avatar
I doubt hara can make it rain on queue, perhaps if you asked andy he could do it :P
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 04-30-2008, 02:40 AM   #12155
Matt
Already answered it Flex
I am led to believe the track had been resurfsced and not that grippy, also the tyres are hard so maybe trying to generate more grip through flex and make the tyres work harder.
Old 04-30-2008, 03:19 AM   #12156
TryHard's Avatar
Personally, think of it this way. When using 5cells at 1500g it's a very easy way to add weight where required (down low)...
You could use a thicker chassis plate (which will weigh more), however the flex would then be way off. This way, he can use a heavier bottom plate, but with similar flex characteristics to a thin carbon plate.... simple really...
Ed
Old 04-30-2008, 04:57 AM   #12157
Trader Rating: 21 (100%+)
Originally Posted by NickM View Post
I stand corrected by mangoman. Perhaps I overstressed the difference in the level of kit. I'm just surprised that the new supposedly top-level HB car is missing a bunch of top-level bits. I mean, yes it's got the diff that the cyclone should have had since its inception - one that won't break diff screws every five minutes - but then they go and put delrin out drives on it instead of aluminium...
So,is the outdrives the only differences besides the turnbuckles?Or are there others?Need to get a comparison because I only race stock.Maybe 19 turn once in a while.Mario.
lotus1 is offline   Reply With Quote
Old 04-30-2008, 05:04 AM   #12158
Lonestar's Avatar
Hi guys
can anyone please confirm whether the pro-spec diff rings are the same as the Cyclone 12? I couldnt find an exploded view of the new diff, the pro-spec diff doesn't list rings as separate parts either... Soooo... does the pro-spec diff use #61627 as diff rings? Thanks!
Paul
Lonestar is offline   Reply With Quote
Old 04-30-2008, 05:56 AM   #12159
sonic31's Avatar
hello mr. iceman76, how's the cyclone? make sure your setup is good cause' the tc5 is coming back to hunt you down and tear you up. oh yeah what's up with the new avitar ? its a hurricane not a cyclone, go to a japanese weather website and look for a cyclone pic there
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 04-30-2008, 06:25 AM   #12160
STLNLST's Avatar
Trader Rating: 19 (100%+)
That's too funny. I actually had to go and look at his avitar
STLNLST is offline   Reply With Quote
Old 04-30-2008, 06:43 AM   #12161
Originally Posted by Lonestar View Post
Hi guys
Paul
As looking into the manual, seems that pro-spec uses those diff rings #61627.
You can check the manual here:
http://www.hpiracing.co.jp/contents/...b/ep/67700.pdf
Cheers.
jorgesimes is offline   Reply With Quote
Old 04-30-2008, 07:23 AM   #12162
yyhayyim's Avatar
Trader Rating: 26 (100%+)
TC5 is back on track
te llamo hoy despues de las 4 broder
yyhayyim is offline   Reply With Quote
Old 04-30-2008, 10:01 AM   #12163
SammyZ's Avatar
Trader Rating: 138 (100%+)
Hi guys
Paul
yes the pro spec diff uses cyclone 12 diff rings, unknown what the thrust washers are!
SammyZ is offline   Reply With Quote
Old 04-30-2008, 10:19 AM   #12164
RC MARKET's Avatar
Thrust Washers part no. 61148
next week arrive Thrust Ceramic ball .
RC MARKET is offline   Reply With Quote
Old 04-30-2008, 04:23 PM   #12165
Thank you RC MARKET.... I will get 3
Lazer Guy is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
