Old 04-24-2008, 06:28 AM   #12061
HarshGuy's Avatar
Originally Posted by STLNLST View Post
I may have to go and check it out. I still never fully recovered from coming in 2nd to your Darth Maul (sp) paint job and the Norrca nats back in the day
Sounds almost as bad as not even placing at the paint job contest @ ROCKS
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 04-24-2008, 06:33 AM   #12062
STLNLST's Avatar
Trader Rating: 19 (100%+)
You had to bring that up again huh. That was crap losing to a two color rattle can paint job and another one that was all sticker's. That's why I will never enter that contest again. They play favorite's. I really like the rule that you had to paint the body yourself yet just about everyone there had their bodies painted by that one girl Oh well......I still have my 2nd place to Charlie B. trophy
STLNLST is offline   Reply With Quote
Old 04-24-2008, 02:35 PM   #12063
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by karlo511 View Post
i've been running this set-up
http://www.petitrc.com/reglages/hotb...etup200712.pdf
but i made the following changes:
front block = F 1mm R 1.5mm
front droop = 6
front oil = 40wt
front spring = hpi white
rear droop = 6
rear ride height = 5.3
rear oil = 30wt
rear spring = hpi pink
tamiya red foam on top of bladders
front suspension arm spacer = F.5mm R 2mm
rear suspension arm spacer = F 2mm R .5mm
rear upright spacer = F 2.75mm R
other things to try:
1.2 mm front sway bar
reduce the rear toe-in block to 2.5
thanks dude. im going to print this out and look it over. ive seen your cars they're always very stable in low traction tracks like Corona and LM.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-24-2008, 03:20 PM   #12064
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
hey Chris where you gonna be pitting? Gonna wanna ask you how that setup works for you this weekend...
as long as i been doing onroad, im still nooby to setting up a car other than shock position, camber and toe-in (even then im still nooby), shock oil weight, and springs.
@_@
Syber Serulean is offline   Reply With Quote
Old 04-24-2008, 03:52 PM   #12065
karlo511's Avatar
steve weiss posted that set-up a couple years back and i always start with it and adjust from there.
karlo511 is offline   Reply With Quote
Old 04-24-2008, 04:06 PM   #12066
whats the suggested rear plate thing for medium to low asphalt track conditions? Right now i have th aluminum rear plate like the WCE kit would include. Between the FRP plate, the carbon fiber plate, and a modded plastic cyclone S rear plate, whats the best to use in this scenario and what are the disadvantages if any?
Old 04-24-2008, 04:17 PM   #12067
dstyles's Avatar
anything but the aluminum would benefit you. the plastic S deck with the webbing cut out or the FRP plate work would work well. it won't give you a drastic traction change, but it will allow the rear to flex a little more than the aluminum piece.
dstyles is offline   Reply With Quote
Old 04-24-2008, 09:02 PM   #12068
overflow's Avatar
Sorry guys, but i think i just broke my scroll wheel going through 70 pages... does any one have pics of the cyclone with a gtb mounted? im looking for ideas for wiring. Thanks!
Dennis Vice
[HOTBODIES] [SPEED PASSION]
overflow is offline   Reply With Quote
Old 04-24-2008, 10:10 PM   #12069
SammyZ's Avatar
Trader Rating: 138 (100%+)
SammyZ is offline   Reply With Quote
Old 04-24-2008, 11:07 PM   #12070
ill snap a pic of mine hold on...
here you go:
Old 04-25-2008, 02:05 PM   #12071
SammyZ's Avatar
I used all the new HB 3.6mm chassis, 2.5mm top deck, 2.5mm middle deck, ATC chassis posts, low mount foam tyre shock tower.
Old 04-25-2008, 06:01 PM   #12072
1st round of controlled practice on complete.
Atsushi Hara top dog with a near perfect run , Here are the top 10
ATSUSHI HARA 19 5:00
VIKTOR WILCK 19 5:04
HAYATO MATSUZAKI 19 5:06
MEEN VEJRAK (local) 19 5:07.0
KIM EUNG-CHAN (KOREA) 19 5:07.09
BILLY EASTON 19 5:07.34
JILLES GROSKAMP 19 5:07.39
HUPO HONIGL 19 5:07.59
MASAMI HIROSAKA 19 5:07.66
MARC RHEINARD 19 5:08
iceman76 is offline   Reply With Quote
Old 04-25-2008, 06:03 PM   #12073
Round 2 complete, No 20 lap run, but still good clean runs, here are the top 10. Resort done with best 1 run of the 2
ATSUSHI HARA
SHIN ADACHI
VIKTOR WILCK
MARC RHEINARD
MASAMI HIROSAKA
HAYATO MATSUZAKI
MEEN VEJRAK
KIM EUNG CHAN
BILLY EASTON
JILLES GROSKAMP
That is the run down after 2 rounds. 6 rounds of quals start at 9am Bangkok time.
Old 04-25-2008, 06:15 PM   #12074
arn671's Avatar
Trader Rating: 14 (100%+)
Default Spare parts?
Hey Guys, Just picked up a Surikarn Edition and was wondering if anyone had a source for spare parts; Looking for arms. Thanks in Advance!
arn671 is offline   Reply With Quote
Old 04-25-2008, 06:24 PM   #12075
trigger's Avatar
Hey guys, what kind of spurs do you guys like to run and which ones fit the best. My local shop is out of xenon so just curious what every one else is running?
trigger is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
