Old 04-15-2008, 04:59 PM   #11866
pcar951's Avatar
Trader Rating: 19 (100%+)
I'll post some pics of the 3R spool kit tonight, it's still in the package.
Maybe you rubber tire guys can let me know if it's crap.
pcar951 is offline   Reply With Quote
Old 04-15-2008, 05:05 PM   #11867
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Masato View Post
Thank you
yyhayyim is offline   Reply With Quote
Old 04-15-2008, 05:20 PM   #11868
Do you know witch bones fit that spool??? I'm using the HB heavy duty black steel bones, will they fit ???
Lazer Guy is offline   Reply With Quote
Old 04-15-2008, 07:00 PM   #11869
STLNLST's Avatar
Originally Posted by BlackedOutREVO View Post
TC5 diff blades are like 5 bucks for like 8 or something of them
All you have to do is ream out the hole because the HB's CV pin is bigger
Much better for the price, and they last just as long
That's why I kept my TC5 blades and the car still has the orginal set we put on it with no signs of wear.
STLNLST is offline   Reply With Quote
Old 04-15-2008, 07:10 PM   #11870
Trader Rating: 194 (99%+)
The V1 bones fit the 3Racing spool. If you had a black Cyclone then you have V1 bones.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-15-2008, 07:31 PM   #11871
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Yup, I have a bag of them ready to use
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 04-15-2008, 08:02 PM   #11872
bmr
Trader Rating: 27 (100%+)
I have about 30 races on a 3Racing spool with no problems.
13.5 and rubber on asphalt. Using the HD version 1 bones.
bmr is offline   Reply With Quote
Old 04-15-2008, 09:00 PM   #11873
SammyZ's Avatar
Trader Rating: 138 (100%+)
I liek the 3racing spool kit, very trick looking. Unfortunately if your going to use worlds CVD's then you must drill the centers on the cups to fit the CVD.
SammyZ is offline   Reply With Quote
Old 04-15-2008, 09:35 PM   #11874
Trader Rating: 22 (100%+)
How much easier is it to drive with a front diff instead of a one-way?
...how about a spool instead of a one-way?
I have a one-way installed and I've gotten somewhat used to it, but I wonder how a diff might improve my driving/lap times.
...the lack of front brake and perfecting my coasting is getting annoying.
SantozRey is offline   Reply With Quote
Old 04-15-2008, 10:44 PM   #11875
pcar951's Avatar
Here's the pic of the 3R spool. You're right V1 bones....no blades. I'd expect the steel drive cups to notch early but, if you've all had luck with them, I'll bolt the little bugger in and see how it holds up.
Old 04-16-2008, 01:26 AM   #11876
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
i went from a car with front diff to a cyclone with front spool and, among other things, the car feels incredibly better. For stock racing, but fast enough to where you have to tap the brake, i say go spool (go spool for MOD for sure). For one-way, if you slow down enough due to drag brake, traction, whatever...then you dont need break and can carry speed much better through turns and not worry about lack of front brake. Personally, i like the spool. It makes my car feel soooo much more stable.
Syber Serulean is offline   Reply With Quote
Old 04-16-2008, 05:14 AM   #11877
Taffyjnr5's Avatar
Trader Rating: 31 (100%+)
Hi,
I have just raced my new Moorespeed Cyclone last weekend in Brushless Stock and all I can say it handles much better than my old black Cyclone I used my old setup and seem to have enen more rear grip than before. I beat my PB lap time by nearly 1/2 a second.
Retired..........
Taffyjnr5 is offline   Reply With Quote
Old 04-16-2008, 05:41 AM   #11878
Thank you guys and yes my Cyclone was black when I got it. now it's 85% purple.
My pro spec diff should be at my house this week, One thing I did not think about was will my V1 steel rear bones fit the new PS diff ????
B18C turbo... You drilled the cups to fit... Are the cups that come with the 3racing spool hard steel ???
Thanks again
Old 04-16-2008, 05:51 AM   #11879
Default droop
I am setting up my cyclone using the Hotbodies site setup to my understanding the ride height is 5.5mm rear and 5mm front but this is where I am confuse the droop is 5.5 and 5mm my question is this above ride height? if it is that is a lot of droop because when I am on carpet I would use 1.5mm above ride height front and rear but asphalt the setup on droop is different but 5+mm above ride height seems too much can some one help me with where to start my droop setting at.
Ramyuras is offline   Reply With Quote
Old 04-16-2008, 06:56 AM   #11880
ShaunMac's Avatar
The droop isn't above ride height. The 5.0 and 5.5 refer to droop when measured on a droop gauge.
ShaunMac is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
