Old 09-26-2005, 08:19 AM   #1171
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
foam carpet high traction
front
shock position
2nd hole on shock tower
inner hole on arm
shims under camber link upper deck 2.5 mm
camber 2
castor 4
rd ht. 4
droop 5
diff
stab 2mm
toe in 0
arms
front .5
rear 1.5
camber link pos 1
rear
shock tower 3
hole on arm 2
shims under camber link upper deck 2mm
camber link pos 1
upright inner hole
toe in 2.5
camber 2
rd ht 4.3
droop 5
ackerman
4mm shim
shocks
piston
hole size 1.2mm
holes 2
oil f45 r40
springs f35 r30
rubber carpet high traction
front
shock position
3rd hole on shock tower
outer hole on arm
shims under camber link upper deck 2 mm
camber 1.5
castor 4
rd ht. 5
droop 5.5
one way
stab 1.4mm
toe in 0
arms
front 1
rear 1.5
camber link pos 1
rear
shock tower 3
on rear arms 2
shims under camber link upper deck 1mm
upright inner hole
toe in 3
camber 1.5
rd ht 5.3
droop 5.5
stab 1.4
ackerman
4mm shim
shocks
piston
hole size 1.2mm
holes 2
oil f30 r40
springs f gold r gold
bladder std
hope this helps you all. i dont have the means at this moment to provide you with a better sheet. good luck!
S-T-R-l-K-E-R is offline   Reply With Quote
Old 09-26-2005, 08:38 AM   #1172
Skill's Avatar
Not sure if anyone has noticed this or not, but there are a few Cyclone setups from different drivers on the HPI Japan website, looks like it was all in 23T.
http://www.hpiracing.co.jp/contents/setup/index.html
EDIT: I say a few but it's actually just Mio Hakamata and Kazuki Endo
Skill is offline   Reply With Quote
Old 09-26-2005, 08:57 AM   #1173
rc-zombies's Avatar
Finally picking up my Cyclone today...
will post some pics later this week...
Old 09-26-2005, 01:01 PM   #1174
Is there some plate available (1mm, 1.5mm) in order to raise the black pivot block???
I want to buy the purple cylinder nut from the pro4, does they have a O-Ring inside???
Thanks in advance.
Hugo is offline   Reply With Quote
Old 09-26-2005, 01:04 PM   #1175
rc-zombies's Avatar
Thanks in advance.
you can buy the pivot block spacer set...
and yes..the purple shock nut does have the O-ring inside...
what is wrong with the stock shock nut?
Old 09-26-2005, 01:11 PM   #1176
Does the pivot block spacer have large plates for the black pivot block?
I think that the black spring collar spins too easily, when you turn the spring, the collar turns with it. And the purple ones looks great on the car.
Old 09-26-2005, 02:36 PM   #1177
bencos is offline   Reply With Quote
Old 09-26-2005, 04:29 PM   #1178
Trader Rating: 16 (94%+)
nope, the pivot block kit is from the pro4, so just the regular pivot and f/r blocks...
hopefully hotbodies release spacers for the cyclone f/r blocks, otherwise it looks like shims and maybe the regular roll centre spacers might have to be used
domo is offline   Reply With Quote
Old 09-26-2005, 08:51 PM   #1179
rc-zombies's Avatar
I just got my kit today...unfortunately it was one of the early packaged kits with the bulkhead mis-packaging....
for racers in the US that received their kits with mis-matched lower bulkheads? if so..how long did you wait before you recieved replacements from HPI/HB?
a few complaints other than the bulkheads problems...
*no O-ring on the shock adjusting collar.
*round shock cap.. make tightening more difficult. I like the hex style shock cap. less effort to tighten
to be continued...
Old 09-26-2005, 08:54 PM   #1180
ngo8's Avatar
Send a message via ICQ to ngo8
i got mine today as well and i had the right bulkheads (thank god ) on it but you are right acout the shock caps that sucks the only complain is the rear diff wiggles back and forth they include 4 bearinggs but only use like one hmmmm
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 09-26-2005, 09:50 PM   #1181
Default Spur Gear section Lots of Left Right Play
Hi Guys,
Just checking with you guys if you faced similar problems as me when fixing the Spur Gear section. If you follow the manual's orientation on placing the top graphite brace, there is a lot of horizontal play. Meaning the spur can be moved from right to left. it's like 1mm gap! When I turned the graphite orientation around, it becomes okay. However, when I checked against the updated manual, there wasn't any correction on this. What's your experience on this?
Lastly, other than using the Pro 4 front spool with lots of shim and changing to Pro4 universals, anyone come across a spool that's made for Cyclone?
Thanks.
chiatf is offline   Reply With Quote
Old 09-26-2005, 10:44 PM   #1182
Originally Posted by chiatf
Hi Guys,
Thanks.
the manual isnt very clear on this, but I think you need to adjust and fix the position of the fixed pulley and the spur mount usings the set screw to take up the play...
what i did was put the fixed pulley and the bearing on the layshaft and tighten it so the bearing is flush with the end of the layshaft, then put the spur mount and one way pulley + bearing +a thin shim on the layshaft, do not tighten the set screw yet, put the layshaft onto the car, push on the spur mount so the one way pulley+bearing+shim is tight against the bulkhead then tighten the set screw, remove the layshaft from car, remove the shim, and then place the layshaft back in the car and it should be just about perfect with very little play and no binding...
Old 09-26-2005, 11:47 PM   #1183
B&O
B&O's Avatar
I had mine missing a collar for the rear diff.
So I end up using another bearing instead.
So far, with Pro 4 experience, I can build Cyclone without any major problem
B&O is offline   Reply With Quote
Old 09-27-2005, 01:46 AM   #1184
Thumbs down
don't think there are any spacers for the black bulkheads? (well not what I can find)
crangon is offline   Reply With Quote
Old 09-27-2005, 04:34 AM   #1185
& main chassis touch belt
HKRCMODEL is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
