Old 04-11-2008, 01:21 AM   #11776
trigger's Avatar
Hey guys, just got a hold of the original cyclone. Does any one know where I can get two 18 tooth lock center pulleys and the belts to accomodate the pulleys. Hot Bodies site is out of them. I know the car is old compared to the moorespeed but just I just thought i'd try and and make the car somewhat competitive. any help would be appreciated. got the car for a good deal and couldn't get a hold of the moorespeed.
trigger is offline   Reply With Quote
Old 04-11-2008, 02:57 AM   #11777
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
who said an "original" cyclone would not be competitive against a AME or WCE version? From what I can see - there are not many MAJOR differences better each chassis that would say this is better than that...
as far as I can tell - ALL the cyclones (barring maybe the newest revision that's not even out yet) come with a 16t center pulleys...So for any version, the 18t pulleys are add-ons
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-11-2008, 04:12 AM   #11778
Lonestar's Avatar
Originally Posted by CRASH View Post
Where can this whole setup be found at?
Thanks,
not sure, but that's all the info you need - no swaybvars and shock in middle or middle-high holes on towers... what else is missing?
Later
Paul
Lonestar is offline   Reply With Quote
Old 04-11-2008, 04:17 AM   #11779
Lonestar's Avatar
the moorespeed in essence is just a black cyclone with different anodizing, shock towers with more holes, and some improved parts for reliability (diff screw, ...). With the same setup and the same driver, they will turn the same lap times
Later
Paul
Old 04-11-2008, 09:11 AM   #11780
Originally Posted by Teddy View Post
hi everybody,
I've seen the Instruction manual from HPI Japan of the new Cyclone TC, and i notice that all the bulkhead(front & Rear) have a different Part Number in comparison with the cyclone Moore one.
Someone knows what is different?
The new bulk heads have been reinforced.
They are much stronger than the existing one.
Hi-LowBlow is offline   Reply With Quote
Old 04-11-2008, 10:03 AM   #11781
SammyZ's Avatar
Trader Rating: 138 (100%+)
oh thats wicked cool! will they be the same price as the old ones?
SammyZ is offline   Reply With Quote
Old 04-11-2008, 10:07 AM   #11782
andyh's Avatar
Default ...
Gear charts...
andyh is offline   Reply With Quote
Old 04-11-2008, 02:10 PM   #11783
Trader Rating: 22 (100%+)
What's the recommended FDR when running 19T ?
SantozRey is offline   Reply With Quote
Old 04-11-2008, 02:14 PM   #11784
jaz
When using bigger center pulleys to change the internal ratio, do you have to keep both center pulleys the same? For example, use two 16T or two 18T, or can you mix them up?
jaz is offline   Reply With Quote
Old 04-11-2008, 02:18 PM   #11785
Hebiki's Avatar
Trader Rating: 26 (100%+)
mixing them up will cause overdrive or underdrive.. depending on what you do. each one does something different (more steering, less steering) etc.
now dont ask me which one causes more steering and which one causes less.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-11-2008, 03:56 PM   #11786
andyh's Avatar
Default ...
..depends on track of course, but So Cal La Mirada (med sized track) I usually start with a 6.0 and go one up or down (CP brushed 19T motor)
Old 04-11-2008, 04:09 PM   #11787
SammyZ's Avatar
I just finished building my carpet moorespeed. I used ALL the NEW hotbodies graphite parts for foam tyres! They are amazing! I used
-foam tyre low mount shock tower
-3.6mm solid main chassis w/ battery cut outs
-2.5mm solid upper deck
-2.5mm solid middle deck
-ATC-adjustable torsion control chassis posts
I will have pics up tomorrow! its soo nice!
Old 04-11-2008, 04:47 PM   #11788
Nice to hear that B18C Turbo!!
Please give us some feed back after you try the car.
Can't wait to see the pictures.
Old 04-12-2008, 03:33 AM   #11789
Skill's Avatar
The Cyclone TC also has a new shock body which, from the instructions looks at if it's not threaded all the way down the shock body.
Talking about shocks, does anyone know how the HPI Competition shock (75194) compare to the shocks in the Cyclone?
Skill is offline   Reply With Quote
Old 04-12-2008, 04:07 AM   #11790
t4m1y4niac's Avatar
what is the size of the cyclone front belt??
thx
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
