Old 04-09-2008, 03:04 PM   #11761
CRASH's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Lonestar View Post
"base" setup for one-way grippy rubbers on carpet is the super-famous "1.5" setup - rolle centers raised 1.5mm via shims under all pivot blocks and ball joint holders on chassis side, 4mm ackerman, LWB all over, 40 to 50 oil all around with 3-holes 1.1mm pistons, pink springs front blue springs rear, 6mm droop front 5mm droop rear, that's with a mazda 6.
Where can this whole setup be found at?
Thanks,
CRASH is offline   Reply With Quote
Old 04-09-2008, 11:06 PM   #11762
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default Update your old style diffs
I just finished "modding" the old style alum. outdrives and diffs for the bigger 2.6mm screw and alum diff nut, 8thrust balls. Awesome is all I can say. Granted it took two packages from Hotbodies to get all the parts needed but it's a cheaper alternative to the new pro-spec diff kits.
Originally Posted by Joehwee View Post
Make sure that you run a 2.6mm drill bit thru the centre of the diff outdrives.
http://www.hotbodiesonline.net/searc...=61535&lang=en
http://www.hbeurope.com/piw.php?lang=en&partNo=61544
Jaz406 is offline   Reply With Quote
Old 04-09-2008, 11:17 PM   #11763
Mirage are saying hopefully next week as they havnt ordered any yet from HPI
richard baker is offline   Reply With Quote
Old 04-10-2008, 05:41 AM   #11764
jaz406
I have been using that diff mod for a long time and I do not think that screw can break. I am using a shock rebound foam on top of the screw to keep the lube in and the dirt out, also the jaad diff covers. I can get 40 or more runs out of my diffs.
Lazer Guy is offline   Reply With Quote
Old 04-10-2008, 06:16 AM   #11765
Update on the toe thingy: at home with more time i tried swaping one by one the suspension components again. I did manage to get 2 toe on both sides (thats with the 3 block). I also measured the chassis holes carefully and they seem to be ok.
Im thinking this is more likely a problem with the molded compenents, although it is weird both me and jorge had problems on the same side of the car.
I will try again to get 3 on both sides. If not maybe a 4 block will give me (i hope) 3 even on both sides.
Itchy is offline   Reply With Quote
Old 04-10-2008, 06:51 AM   #11766
Teddy's Avatar
hi everybody,
I've seen the Instruction manual from HPI Japan of the new Cyclone TC, and i notice that all the bulkhead(front & Rear) have a different Part Number in comparison with the cyclone Moore one.
Someone knows what is different?
Teddy is offline   Reply With Quote
Old 04-10-2008, 09:14 AM   #11767
SammyZ's Avatar
Trader Rating: 138 (100%+)
yeah, they changed the front & rear lower and upper bulkheads for the new TC. I don't know why, the old ones are awsome!
SammyZ is offline   Reply With Quote
Old 04-10-2008, 09:34 AM   #11768
Trader Rating: 195 (99%+)
Anyone know the release date of the new TC?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-10-2008, 09:38 AM   #11769
Crashmaster's Avatar
Says mid april on the translated HPI Japan site. How true that is, we'll wait and see I guess. Can't be too far off if they've got a manual uploaded on the internet and that!
Crashmaster is offline   Reply With Quote
Old 04-10-2008, 01:02 PM   #11770
Stew Noble's Avatar
Originally Posted by bob33 View Post
thanks noble, now just about the new car u got any idea's when they might be relesed so we can get 1? think i no the answer to that..
Late May or early June would be my guess for the UK.
// S N F //
Stew Noble is offline   Reply With Quote
Old 04-10-2008, 02:19 PM   #11771
RC MARKET's Avatar
We was pre-order New kit & new parts ,
waitting they packing now !
do you need pre-order new spare parts ?
RC MARKET is offline   Reply With Quote
Old 04-10-2008, 02:29 PM   #11772
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
do you have a website I need the new diff.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 04-10-2008, 02:40 PM   #11773
SammyZ's Avatar
his website is rcmarket.com.hk, its awsome! new pro-spec diff is just $45
Old 04-10-2008, 03:23 PM   #11774
arn671's Avatar
Trader Rating: 14 (100%+)
Default set up sheets
Hey Guys, just picked up a Surikarn cyclone and am looking for set up sheets? The search here didn't really produce any. Thanks in advance!
arn671 is offline   Reply With Quote
Old 04-10-2008, 03:32 PM   #11775
yyhayyim's Avatar
got to: http://www.petitrc.com/view_news.php?id=4553
Later
Yohan
yyhayyim is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
