Old 04-05-2008, 10:07 PM   #11701
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by STLNLST View Post
Man this car is awesome. Looks like I found my new home. I wonder if my girl will get mad if I bring my Cyclone to bed with me.....LOL
Tested alot today and also blew some stuff up but the show still went on. I will be back out for more in two weeks.
Did the orange happen to blow up?
What setup are you running now?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 04-05-2008, 10:23 PM   #11702
STLNLST's Avatar
Trader Rating: 21 (100%+)
Yeah....after all these years running the orange I finally had one go up on me. I was in the lead too My car was a rocket. The set up is still the same except I change to the 2.5 front block to get a little more steering and Scotty went with 1mm more ackerman to get his. I still think that his car worked a little better than mine. The ackerman was too much for me when I made that change so I tried to get it elsewhere.
STLNLST is offline   Reply With Quote
Old 04-05-2008, 10:50 PM   #11703
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Good to hear Clint !!! We will see you guys May 3rd..... I will be building my car soon.... Any tips will be much appreciated..
King of B Main is offline   Reply With Quote
Old 04-05-2008, 10:52 PM   #11704
Haha, just the speedo? Or did you kill a motor to?
Sounds good, I have to get school sorted out before I can even touch my cyclone
Old 04-05-2008, 11:12 PM   #11705
NickM's Avatar
Originally Posted by jaz View Post
You have to do that much grinding to get the Core 5000 to fit even though it is only .5mm taller than the Orion 4800 and Trakpower 4900, both of which I hear fit with no modification??
My Orion 4800 will fit without grinding but is pushing on the bulkhead and introduces some tweak. When I swap out to a different battery the tweak disappears, so it's definitely the battery. It's not severe, but it's noticeable.
TRF 416 | Corally Φ | TOP Scythe | F103GT
NickM is offline   Reply With Quote
Old 04-05-2008, 11:39 PM   #11706
STLNLST's Avatar
Originally Posted by King of B Main View Post
Good to hear Clint !!! We will see you guys May 3rd..... I will building my car soon.... Any tips will be much appreciated..
Just really pay attention to your diff is about the only thing I can suggest. If it's not working right then the rest of your setup doesn't mean squat. I keep wanting to try the stock diff screw but once I look at it I just keep my AE one installed. I can't wait for the Reedy warm up race. I would have liked to see the spec tire announced soon so that racers can come out and get some track time and make the regular club races better.
The motor harness connected to the speedo took a little of the heat so it has some battle wounds on it. Nothing major though. I put in my back up and continued to race.
Old 04-06-2008, 12:47 AM   #11707
Hebiki's Avatar
Trader Rating: 26 (100%+)
can a "non-properly" working diff cause the car to be loose everywhere?
just curious because im trying to nail down a set up for my AME cyclone...and maybe the root of all my problems is my diff?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-06-2008, 02:41 AM   #11708
JonboyGB's Avatar
Default New top deck?
Apologies if this has been posted elsewhere. Just saw this pic from the recent LRP Masters in Germany. Looks like Andy Moores top deck has been cut for extra flex? He is also using the new bulkheads and main chassis with battery bits.
JonboyGB is offline   Reply With Quote
Old 04-06-2008, 06:39 AM   #11709
CRASH's Avatar
Does anyone know where you can get Edit Rc Products in the states?
Thanks,
CRASH is offline   Reply With Quote
Old 04-06-2008, 07:06 AM   #11710
STLNLST's Avatar
Yes it can. The local AE guy here had a few troubles yesterday and once he rebuilt his diff his car was pretty good. This rule should be applied to every car. I just think that they diff in this car could use a little extra love. Once that's done go and set TQ
Old 04-06-2008, 10:10 AM   #11711
I was wondering the same lol..... My car is hooked up, but its something to try
Old 04-06-2008, 10:39 AM   #11712
Welcome aboard Mike!!
Hi-LowBlow is offline   Reply With Quote
Old 04-06-2008, 02:22 PM   #11713
xraysteve's Avatar
i got beat by one of though darn purple cars. if this keeps up i will have to switch.
lazer speedway everything else is a parking lot
xraysteve is offline   Reply With Quote
Old 04-06-2008, 02:29 PM   #11714
Originally Posted by birdman View Post
Guys, I need help with my Cyclone, why when I setup my car and check my toe-in for the rear wheels the reading is not the same from left to right. I am using a 3.0* pivot block for the rear but the reading can be left 3.0* and right 1.5*. Isn't it suppose to bothe side reads 3.0* if my pivot block is 3.0*? Is this something that I need to worry about or can I just ignore the different reading. I have use different setup kits to check, and it also give me different readings.
Hi Birdman, I purchased a moorespeed cyclone last week and built Friday/Saturday and did notice that my rear toe was not even both sides. It should be the same 3deg both sides with the 3 deg block. As you look at the car from the front the left rear wheel is only toeing in 1.5deg and the right 3deg when running the standard 3deg block.
I did speak to Mirage Technical and they have tried to help but no joy. I have disassembled the rear of the car and checked everything. I removed the rear pivot pins and rolled them along a flat piece of glass and they are perfect, I have swapped both rear wishbones and hubs for my Tamiya ones and still no change.
I did notice that my cyclone has different colour of carbon than older versions that makes up the chassis, top deck and suspension mounts. Mirage said that HPI have recently changed there carbon supplier and it looks like for a cheaper version IMO, the carbon weave bends as it runs down the chassis and is very light in shade in comparison to the older black carbon. I'm wondering if the holes are incorrectly positioned and this makes my car crab badly. I also do not no where to go next as it is very difficult to find the reason.
Can Anyone Help Please?
blue247carz is offline   Reply With Quote
Old 04-06-2008, 02:56 PM   #11715
Hello,
Could you please send some pics to the address that I pm'd you?
thank you.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
