Old 04-02-2008, 09:03 AM   #11671
revo61's Avatar
Trader Rating: 18 (95%+)
Does anyone know if you can upgrade a Cyclone black to the Cyclone TC? Are all the parts close to the same?
revo61 is offline   Reply With Quote
Old 04-02-2008, 10:56 AM   #11672
ShaunMac's Avatar
An XRAY racer at the track runs a SMC 5000 pack. He shaved off material from the case to make it fit the 008. I tried his pack in my Cyclone and it fit. I have also taken about 1mm off the bulkhead to allow for more room. So yes, the 5000 will fit with some mods to the pack and car.
revo61 - Yes you can upgrade to a TC. You will also want to use some of the parts from the WCE to build the ultimate Cyclone.
ShaunMac is offline   Reply With Quote
Old 04-02-2008, 10:57 AM   #11673
Stew Noble's Avatar
Originally Posted by B18C Turbo View Post
I immediatly realized that once i switched to Muchmore 24r's the car pushes into every corner on and off power. It also has no rear traction and likes to step out. Is this because I haven't broken in/scrubbed in the new tires? The Jaco's took 4 packs to get good.
My current setup:
Gold/Silver springs
30wt AE oil all around
-1.5 Camber around
0 Degree front bloock
3 Degree rear block
2mm shim under camber links (inner hole)
mid shock mount positions
one-way up front
smooth real ball diff
4.5mm ride height
6mm droop around
If you don't remove the molding bead on the tyre when new, this will have a negative impact on the cars handling.
Use a tyre sander and abrasive material to remove the bead.
Try HPI pink front springs, this will make the car feel a little more direct and give better bite into the turn.
If you run the 0 front block, you'll need to add a 1mm width spacer to the axle, as reducing the arm sweep on the block reduces the track width, a narrower track width at the front can make the car feel twitchy.
Also your additive routine and bodyshell may contribute to your difficulties...
// S N F //
Stew Noble is offline   Reply With Quote
Old 04-02-2008, 11:06 AM   #11674
Trader Rating: 194 (99%+)
That is good to know. But the pack become ileagal in a ROAR event. I plan on racing at the Paved Nat's in June. But I will probably be running NIHM's since they are faster in stock.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-02-2008, 04:23 PM   #11675
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Originally Posted by dodgeguy View Post
I like the Core 5000 lipo. It had more punch than my orion 4800.
I would like to try the SMC 5000 myself. But it does not fit into any of the cars I would run.
The Reedy 5000 looks like a good pack. Rick Howart ran them in mod at the Nats and did well with them.
If you ground the rear bulkhead a little would the SMC 5000 pack fit?
I have the Core batteries in my car and they fit just fine as long as you grind a little off the RR bulkhead and grind the screw a little as well.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 04-02-2008, 09:10 PM   #11676
SammyZ's Avatar
Trader Rating: 138 (100%+)
the orion 3600mAh lipo is def the nicest one i've ever owned so far, fits perfect and looks wicked nice.
SammyZ is offline   Reply With Quote
Old 04-02-2008, 09:58 PM   #11677
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
You and the looks lmao!
Have pics of the updates?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 04-02-2008, 11:29 PM   #11678
SammyZ's Avatar
Im gonna wait for my orion 13.5 and then I'll post updated pics, it looks so sweet so far though! I have to admit, at the local club i get flamed for a faggy flashy car, but its certainly pretty in the pits
Old 04-03-2008, 06:15 AM   #11679
He's still running a 13.5 since current 17.5's don't have a detachable harness. The only reason he bought a cyclone was because of the anodized purple. Looking pretty doesn't help you on the track Sammy.
JoelV is offline   Reply With Quote
Old 04-03-2008, 06:20 AM   #11680
STLNLST's Avatar
Trader Rating: 19 (100%+)
That's too funny. I get the same for some of my paint jobs because I put the "PRINCE" symbol on my ride.
STLNLST is offline   Reply With Quote
Old 04-03-2008, 07:17 AM   #11681
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I wouldnt rock the NPG symbol, but your car looks good clint.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 04-03-2008, 07:45 AM   #11682
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I heard Clint once made pancakes for Charlie Murphy
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 04-03-2008, 03:06 PM   #11683
HAHAHA, why are you swapping to a orion 13.5? Whats wrong with the novak?
Except when its a cyclone, then pretty WILL help you!
STLNLST, that body looks pretty cool! Why dont you still use that scheme?
Old 04-03-2008, 03:53 PM   #11684
STLNLST's Avatar
I have it tatooed on my arms as well That's how I roll.
I rock different paint schemes from time to time and my boy that painted that one doesn't paint that much anymore. I may go back to my pink paint scheme for the Reedy race though. I haven't used it in a while.
Old 04-03-2008, 04:08 PM   #11685
Pink? LOL Never saw pics of that one
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
