Old 04-01-2008, 10:28 PM   #11656
SammyZ's Avatar
Trader Rating: 138 (100%+)
I need a lotta help with my WCE on carpet/rubber. It's just all over the place and im not that bad a driver! It feels like im driving on ice! I took the sway bars off since nobody at my track runs them on their rubber tire cars, I didn't notice any difference.
I did break a Jaco green and then switched over to Muchmore 24R's. I didn't have time to scrub them in, so I mad maybe 4 laps and the tires picked up all the foam tire peices off the track!
I immediatly realized that once i switched to Muchmore 24r's the car pushes into every corner on and off power. It also has no rear traction and likes to step out. Is this because I haven't broken in/scrubbed in the new tires? The Jaco's took 4 packs to get good.
My current setup:
Gold/Silver springs
30wt AE oil all around
-1.5 Camber around
0 Degree front bloock
3 Degree rear block
2mm shim under camber links (inner hole)
mid shock mount positions
one-way up front
smooth real ball diff
4.5mm ride height
6mm droop around
SammyZ is offline   Reply With Quote
Old 04-01-2008, 10:45 PM   #11657
Trader Rating: 194 (99%+)
Originally Posted by jaz View Post
I would recommend trying the Associated diff screw. Many people have had a lot of success running it in their Cyclone diffs rather than any of the HPI/HB screws.
This is the only screw to use in the Cyclone or Pro4 diff. You will not break these near as easy.
Has anyone tried to fit an SMC 5000 hard pack into the Cyclone?
And any idea when the new car will be out?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-01-2008, 10:58 PM   #11658
STLNLST's Avatar
Trader Rating: 19 (100%+)
it won't fit. The 4800 barely fits into this car. The SMC 5000 is too tall.
STLNLST is offline   Reply With Quote
Old 04-01-2008, 11:02 PM   #11659
You know it seems the only car the 5000 fits in without any major mods is the TC5 and one of the Tamiya's I do not know what Danny was thinking for TC.
www.donatelife.net
Old 04-01-2008, 11:04 PM   #11660
mangoman's Avatar
The pro 4 diff screw is fine. I have never used anything else. In my opinion the titanium coating does nothing for the screw. I think hot bodies say its meant to make it smoother.
I've only ever had a diff screw snap once, and that was when a friend of mine told me to tighten it up as hard as possible as we didnt have a spool. But i also usually dont use the screw that much. After rebuilds i look at the screw and you always see little cuts in the screw from where its been rubbing on something.
If the cut is even mildly deep i put the screw back in my box (got a little stack of them cause im terrible at not throwing stuff out :P).
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 04-01-2008, 11:10 PM   #11661
jaz
What about the Reedy? Here are the dimensions as far as I can find:
Length: 139mm
Width: 46mm
Height: 23.1mm excluding nubs /25.1mm including nubs
jaz is offline   Reply With Quote
Old 04-01-2008, 11:13 PM   #11662
jaz
I should add that the specs on the SMC as far as I can find are:
HxWxL: 24.5mm x 47mm x 136mm
...just trying to figure out which lipo to go with
Old 04-01-2008, 11:15 PM   #11663
STLNLST's Avatar
Length: 139mm
Width: 46mm
it should fit as that is smaller than the Orion 4800.
Old 04-01-2008, 11:20 PM   #11664
jaz
I'm just hoping the nubs on the Reedy sit low enough in the battery slots for the battery to clear. I just measured the clearance on my Cyclone and it's about 23.8mm
Old 04-01-2008, 11:24 PM   #11665
pcar951's Avatar
Originally Posted by rc pete View Post
Jim, were you running the AME last weekend?
My thick chassied XRay was great on carpet with foams, but it will be useless on rubber... both outdoors and Carpet (next season we're running rubber tires instead). So I need to drop it for either the Cyclone, the TC5, or whatever EU edition XRays happen to be out: 008, 009, 010...
Is HB coming out with a LiPo/weight solution any time soon?
Associated is coming out with one for the TC5... sounds like it might be a plate that mounts to/fills the battery slots somehow, which would be much nicer than the odd pieces of lead that everyone else seems to be using.
Pete, my 19T car is a Hara / BMI with a few hop ups. There is a new Cyclone on the way apparently, more like an upgraded version of the original design rather than a ground up thing (a good approach IMO). Problem with Hot Bodies is parts support in our area, you gotta get used to importing. I've heard noting about lipo weight compensation for the car, Dwayne mentioned that lipo's are not legal for racing in Asia, so little is being done to address the problem.....not sure.
If you'd like to try a Cyclone let me know, I've got a whole fleet of them. Maybe for the DTP race.
pcar951 is offline   Reply With Quote
Old 04-02-2008, 04:09 AM   #11666
Taffyjnr5's Avatar
Trader Rating: 31 (100%+)
Hi,
Is the Associated diff screw from the TC4 or TC5 and are any mods required to fit it to the Cyclone diff. Thanks
Serpent ERYX 4.0
Sworkz EVO LE/OS Speed
Sworkz EVO 2/Hobbywing
Taffyjnr5 is offline   Reply With Quote
Old 04-02-2008, 04:31 AM   #11667
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by Taffyjnr5 View Post
Hi,
I'm pretty certain its the one from the TC5 - considering the TC5 usings a pulley set-up like the rest of the belt cars
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-02-2008, 07:22 AM   #11668
karlo511's Avatar
just need to ream out the outdrives a little for the thickness of the screw.
http://www3.towerhobbies.com/cgi-bin...&I=LX2869&P=ML
karlo511 is offline   Reply With Quote
Old 04-02-2008, 08:18 AM   #11669
I like the Core 5000 lipo. It had more punch than my orion 4800.
I would like to try the SMC 5000 myself. But it does not fit into any of the cars I would run.
The Reedy 5000 looks like a good pack. Rick Howart ran them in mod at the Nats and did well with them.
If you ground the rear bulkhead a little would the SMC 5000 pack fit?
www.donatelife.net
Old 04-02-2008, 08:27 AM   #11670
jaz
Hi,
It's actually from the TC3. This is the one:
http://www3.towerhobbies.com/cgi-bin...&I=LX2867&P=OW
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
