Old 03-29-2008, 08:18 AM   #11626
Shaun Mac and all you great guys..... You have help me with my set up and I am very grateful. I do run on low grip carpet and low grip unprepared asphalt and with 35wt oil and 1mm under the front and 0mm under the back pivot blocks with 1.6 sway bar front(the rest of my car is Stew Noble's set up) works well for my style of driving. That being said I do drive to cautiously and find when coming out of a corners I can get right on it and it does not hook and the back stays in. Also it does chicane's better then anybody else's car. I can drive my car with confidence with this set up. I will not stop trying to make my car better and will try any thing you guys can suggest. Me and Xray Steve have found over the past year that what works on the Xray also works on the Cyclone so I have been using the Xray set up book witch explains things very well.
Thanks for all the help I have gotten from all of you.
Lazer Guy is offline   Reply With Quote
Old 03-29-2008, 08:57 AM   #11627
mangoman's Avatar
Taffyjnr5,
I assume you have already checked, but just incase, have you checked the neutral is set properly on your esc or you dont have drag brakes set?
Also if you changed to a different motor, perhaps the different motor maybe effecting it?
You have checked the belt isnt tight but also make sure that the belt tensioner is not riding on the belt. It should be sitting just above the belt.
You may want to check that the bulkheads arent on the wrong way around (there is a correct right and left side) otherwise you may get binding in the diffs against the bearing holders (which sit in the lower bulkheads). You may also want to check to see if you need less shims on the diff before the bearings (although i would be surprised if that was the problem).
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 03-29-2008, 12:40 PM   #11628
CRASH's Avatar
Trader Rating: 26 (100%+)
Does anyone know for sure if the Version 2 Steel drive shafts part number 61398 can be used for the front and rear? The web site says front and does not mention the rear.
Thanks,
CRASH is offline   Reply With Quote
Old 03-29-2008, 01:57 PM   #11629
ShaunMac's Avatar
Glad I could be helpful Lazer Guy. Suggesting set-up info can be tricky because everyone has their own driving style and what works well for one doesn't necessarily work for another. Don't be affraid to try new things in search of your perfect setup.
ShaunMac is offline   Reply With Quote
Old 03-29-2008, 08:26 PM   #11630
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
As was said before, the pro-squat can be a big help when the car wants to "step out" on you. I've had the exact same issue on asphalt.....pulling the trigger hard coming out of the corner and it feels like it wants to break loose, right? You may have to compensate up front for the slight push you may develop using pro-squat but that pretty simple to fix. Good luck!
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 03-30-2008, 04:42 AM   #11631
mangoman's Avatar
Thanks,
I have used them front and rear **SHRUG**, but performance wise i finally got around to putting aluminium ones in the back (as they dont cop as much damage so you dont really need the HD Steel Uni's on the rear).
www.smaracing.org
Old 03-30-2008, 05:52 AM   #11632
CRASH's Avatar
Thanks,
Old 03-30-2008, 10:06 PM   #11633
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
So when is the Hara, or Moore version of the new cyclone coming out?
I want to build me a new car lol
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 03-30-2008, 10:46 PM   #11634
SammyZ's Avatar
Trader Rating: 138 (100%+)
ehhh I wish! but realistically I doubt there gonna release something like that. Muchmore already discontinued all their Limited stuff, chargers, dischargers, power supplies, tire warmers etc.
SammyZ is offline   Reply With Quote
Old 03-30-2008, 11:05 PM   #11635
pcar951's Avatar
Trader Rating: 19 (100%+)
Default diff trouble
I finally ran into diff trouble this weekend.....nothin but grief at our final series race! Broken screws, mysterious tension loss, all the stuff everyone has been complaining about here for months. Guess it finally caught up to me. Has anyone been running the new diff yet? Is it good? Does anyone have them in stock?
pcar951 is offline   Reply With Quote
Old 03-30-2008, 11:11 PM   #11636
Trust me Pcar951, the new pro-spec diff is awesome! super silky smooth action with long lasting.
you won't be disappointed with it.
Hi-LowBlow is offline   Reply With Quote
Old 03-30-2008, 11:19 PM   #11637
Well MM stuff was over priced anyways lol, I never cared for there stuff really..
There will be, or atleast a pro level kit (alu turnbuckles, TI parts ETC..)
Old 03-30-2008, 11:20 PM   #11638
You running the alu out drives?
Old 03-31-2008, 02:32 AM   #11639
mangoman's Avatar
I hope you mean titanium turnbuckles!!!!!
www.smaracing.org
Old 03-31-2008, 02:11 PM   #11640
pcar951's Avatar
Yes, front and rear for carpet. Tried ceramic and carbide balls in the thrust and diff, sanded washers, the whole enchalada! I even tried to go back to the delrin outdrives....no luck.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
