Old 03-23-2008, 12:59 AM   #11536
Trader Rating: 28 (100%+)
Its an upgrade for all the cyclones....yeah!
racenut123 is offline   Reply With Quote
Old 03-23-2008, 02:14 AM   #11537
Thanks for that
and yes that is awesome news
jimbobmahua is offline   Reply With Quote
Old 03-23-2008, 09:02 AM   #11538
SammyZ's Avatar
Trader Rating: 138 (100%+)
I think your gonna be fine with your stock diff's unless your having issues with snapping diff screws! But if your snapping diff screws I don't think the diff is being assembled correctly.
My trick is to tighten the diff until its pretty smooth but not super tight. Then I test it in the car! Hold the spur gear and the driver side rear tire. Spin the passenger side tire fast, it should spin and hear a slight chirp. That means they are loose but won't slip! perfect!
SammyZ is offline   Reply With Quote
Old 03-23-2008, 06:53 PM   #11539
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by bmmer701 View Post
what's your setup for your cyclone? asphalt ? track condition? thanks
I will get the set up on to a set up sheet and post a link on www.gearchart.com However....I won't take credit for this set up. My boy Scotty Barnes is the guy that put this set up on my car. He use to be the Cyclone master until the student beat the teacher this weekend Love ya Scotty if you're reading this.
Originally Posted by BlackedOutREVO View Post
Haha the STLAWY or however you want to spell it
Your car look good! def had some ponies
It's called the STLAWAY!!!!! No one passes me down the straight....NO ONE!!!!
Originally Posted by B18C Turbo View Post
how are you gearing the 3.5?
I used the 13mm rotor with a final drive ratio of 9.4 This was with Novak motors and spread spektrum speed control using profile #1. The cyclone also had the stock pulley so the internal drive ratio was 2.4???
Last edited by STLNLST; 03-23-2008 at 06:54 PM. Reason: too excited to tell my story I mis spelled a few words
STLNLST is offline   Reply With Quote
Old 03-23-2008, 06:55 PM   #11540
STLNLST's Avatar
I'm going to try the stock diff screw the next time out just to see how it holds up. What diff lube are you using when you build your diffs?
Old 03-23-2008, 06:56 PM   #11541
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Stock Cyclone ratio is : 2.4375
yyhayyim is offline   Reply With Quote
Old 03-23-2008, 07:01 PM   #11542
STLNLST's Avatar
Thanks bro. I have it on my gear chart but it's not near me and I don't know the car well enough yet to have the info flowing from my mouth just yet
Old 03-23-2008, 07:15 PM   #11543
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
LOL
Your car was fast!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 03-23-2008, 09:08 PM   #11544
SammyZ's Avatar
I use the associated diff lube and black grease only becayse my LHS has lots of it and its super cheap! I know MuchMore has their own stuff as do many other manufacturers, there all the same.
Old 03-23-2008, 09:15 PM   #11545
STLNLST's Avatar
They are not all the same. Schumacher has the best lube I have used thus far so I'm planning on getting a few tomorrow when I call them up in the morning. The Schuie diff lube is thicker than the AE lube and doesn't melt off in warm weather. Give it a try one of these days.
Old 03-23-2008, 09:32 PM   #11546
Agreed.Not all the same by a longshot.
They are not all the same. days.
Old 03-24-2008, 02:48 AM   #11547
birdman's Avatar
Guys, I need help with my Cyclone, why when I setup my car and check my toe-in for the rear wheels the reading is not the same from left to right. I am using a 3.0* pivot block for the rear but the reading can be left 3.0* and right 1.5*. Isn't it suppose to bothe side reads 3.0* if my pivot block is 3.0*? Is this something that I need to worry about or can I just ignore the different reading. I have use different setup kits to check, and it also give me different readings.
birdman is offline   Reply With Quote
Old 03-24-2008, 05:54 AM   #11548
STLNLST's Avatar
check to see if anything is bent (hinge pins) and make sure your rear hubs are spaced the same left to right. Other than that I'd have to look at my car and see what other suggestion I could give you.
Old 03-24-2008, 07:46 AM   #11549
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Does anyone know the part # of the gold springs??
Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 03-24-2008, 08:13 AM   #11550
RC MARKET's Avatar
Thanks!
http://rcmarket.com.hk/product_info....oducts_id=1615
RC MARKET is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
