Old 03-04-2008, 09:45 PM   #11176
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by BlackedOutREVO View Post
At Speed world, no I dont think so
My radio comes today (I hope!) And the servo is at futaba, so I should be back for day one of the new track
What about you? You going for the grand opening?
I'll run my car tomorrow if I want. I don't need a grand opening......LOL I'm at Norcal next weekend and hopefully at Speedworld the following weekend.
STLNLST is offline   Reply With Quote
Old 03-04-2008, 09:54 PM   #11177
SammyZ's Avatar
Trader Rating: 138 (100%+)
i stripped the threads on my servo horn tonight. Im wondering if its because I put an aluminum servo saver arm on it in place of the stock black plastic one. Im talking about that arm that the steering turnbuckle connects to and that arm is bolted to the ackerman links.
its basically now an ALL aluminum servo saver. Would that cause the stripped servo horn?
SammyZ is offline   Reply With Quote
Old 03-04-2008, 10:14 PM   #11178
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I could to Got my crap today
Sounds good
I ran a alu arm for a while, but when I swapped to a Futaba servo I run plastic now..... Sounds like you need to loosen your saver in the center of the car, and stop hitting the wall so hard LOL, that must of been some abuse to strip that
Just loosen the saver in the center a half-3/4's of a turn looser should do it, to much and it will just get annoying, so play with it a little
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 03-04-2008, 11:42 PM   #11179
SammyZ's Avatar
I use a futaba servo too! Why did you go back to the stock plastic arm over the aluminum? I think the extra purple is gorgeous and helps stiffen my steering.
The manual says to leave 1.5mm open thread on the servo saver, are you saying to loosen it up some more?
Old 03-05-2008, 04:26 AM   #11180
Ballsie's Avatar
Originally Posted by pcar951 View Post
You should be able to use the old bmi setups with the new HB carpet chassis.
Thanks man - can you point me in the direct of these?
Cheers.
Ballsie is offline   Reply With Quote
Old 03-05-2008, 07:09 AM   #11181
Because the ones that come with the Futaba servo are tough as heck! I havent had any problems, or regret from switching....
What brand was the arm? Maybe it was a bad one? IDK
Yes, loosen it up more, but not a ton
Old 03-05-2008, 07:45 AM   #11182
pcar951's Avatar
Cheers.
Here's one, it's a good starting point.
pcar951 is offline   Reply With Quote
Old 03-05-2008, 10:37 AM   #11183
SammyZ's Avatar
im scared im gonna strip another servo horn. Was this caused by the aluminum steering servo saver arm?
Old 03-05-2008, 11:35 AM   #11184
Ballsie's Avatar
Cheers!
Old 03-05-2008, 03:28 PM   #11185
No, I dont think so
Just to tight of a servo saver, and hard hits
Old 03-05-2008, 03:41 PM   #11186
SammyZ's Avatar
yeah but I went by what the manual said to do, leave 1.5mm thread available!
Old 03-05-2008, 03:51 PM   #11187
Well If your breaking alu arms, thats not at all normal......
Old 03-05-2008, 03:52 PM   #11188
mangoman's Avatar
Did you have the right servo horn on? The futaba one is different to the KO/Sanwa one.
Although even with the wrong servo horn you must be having some decent size crashes to strip it?!?!?!?!?
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 03-05-2008, 06:47 PM   #11189
SammyZ's Avatar
hmm...maybe I should have been more clear. The stock plastic servo horn stripped, its the arm that mounts DIRECTLY onto the servo itself. Its labeled "25" for futaba.
On the cyclone WC the servo saver gives you an aluminum ackerman mounting lower piece with a plastic upper arm to attach the steering turnbuckle too.
So i replaced that plastic upper arm! I used an aluminum piece instead! The car was fine before I did this mod. Now im thinking they made it plastic stock for a reason!
but is that the reason it stripped?
Old 03-05-2008, 07:00 PM   #11190
I know what your talking about
I said more then once, loosen your servo saver (in the ackerman, center steering thing)
Im sure it was plastic to cut down on cost...... From what you say about the stock plastic parts, you hit hard! I ran a alu saver and never bought one for my Futaba, didnt need to
I do not thing that making the upper part of the steering column would make a alu servo arm strip, thats a HARD hit
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
