Old 02-29-2008, 10:03 PM   #11101
karlo511's Avatar
hey hiro, don't forget those parts!!! - karl
karlo511 is offline   Reply With Quote
Old 02-29-2008, 10:24 PM   #11102
SammyZ's Avatar
Trader Rating: 138 (100%+)
nice pics! that should have been added to the instruction manual.
SammyZ is offline   Reply With Quote
Old 02-29-2008, 11:17 PM   #11103
Originally Posted by B18C Turbo View Post
why and how would a servo make the chassis tweak?
The Futaba servos have angled ear tubs. (not straight) when the screws for the servo mounts tighten up, the chassis will be tweaked a little bit.
Hi-LowBlow is offline   Reply With Quote
Old 02-29-2008, 11:21 PM   #11104
SammyZ's Avatar
so if you just use Hara's servo install method you avoid the tweak right? as long as you can see light between the servo case and the chassis its ok?
Old 03-01-2008, 03:30 AM   #11105
Matt Pocknell's Avatar
Hey, do you have a working link to the hara build guide? Mine doesn't seem to work any more.
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Old 03-01-2008, 06:59 AM   #11106
karlo511's Avatar
click on the hara setting button on the left side and then text by the #'s 1-6 at the top of the page. you'll need to translate it though.
http://www.miragejapan.co.jp/
Old 03-01-2008, 07:38 AM   #11107
Thanks for that.
Old 03-01-2008, 08:25 AM   #11108
SammyZ's Avatar
any other tuning/build tips?
Old 03-01-2008, 08:27 AM   #11109
STLNLST's Avatar
Trader Rating: 19 (100%+)
now that the site is working again I guess I'm back.....LOL I will be posting pics of my car (finally) later on today. The wiring was done by Scotty B. (the local HB fast guy) Now that I have one he will be #2 hhhhhhhhhhmmmmmm!
We used shoe goo to mount our servo's to the chassis. He says that he has never had one come out and I've seen him have some crashes that should crack a chassis in two and the servo stayed in place. All that's left is for me to paint up a body with my usual colors and go racing.
STLNLST is offline   Reply With Quote
Old 03-01-2008, 09:54 AM   #11110
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
about time!
I have a question, I bought some shoe goo in a red tube, and everyone at SWR uses the tube that's white. Is there a difference? Because on the tube doesnt say it sticks to plastic...
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 03-01-2008, 10:01 AM   #11111
STLNLST's Avatar
Originally Posted by BlackedOutREVO View Post
about time!
I don't know what Scotty used for the servo but the shoe goo I always use is red on the front and white on the back. It says original formula in white writing on top of an orange start looking thing in the upper right hand corner.
Old 03-01-2008, 10:08 AM   #11112
Yeah, so the main color of the bottle is white?
Mine is all red with white letters...
Old 03-01-2008, 10:14 AM   #11113
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
all the 'goo is the same...I've used the "shoe goo" (in the red tube) and other "goo" in the green tube...
its all the same...
and I'VE NEVER LOST A SERVO that was mounted with any of the "goo's"
this is from TC to 12th scale to 18th scale off-road and 10th off-road the stuff just sticks that well...
I have a little trick to get it to set better
1) take a thin piece of servo tape and run it down the center of the servo
2) apply the goo to boh side of the tape
3) peel the back off the take and stick it too the chassis...
the tape allows the servo to stick to the chassis and not move around while the goo dries Plus it also gives you an area to pry the servo off when its time to change the servo
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-01-2008, 11:00 AM   #11114
its all the same...
Thats a good idea! Never thought of using the servo tape
Good to know its all the same
Thanks!
Old 03-01-2008, 02:12 PM   #11115
SammyZ's Avatar
What is the proper method for measuring droop? At my local carpet track everyone uses the "over ride height" method. This is where we measure ride height first, then lift the chassis up and push the ride height gauge further into the chassis, where it stops is the droop over ride height. Typically between 1-3mm.
I was told this is inaccurate? So I tried measuring with a actually droop gauge and found that my right arm was 1mm different than the left!
I set my droop with the droop gauge on the rear of the car, unfortunatlely the way the alloy c-hubs are designed, the set screw securing the outer hinge pin disables me from getting an accurate reading!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
