Old 02-28-2008, 09:58 PM   #11086
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by B18C Turbo View Post
Im a little confused how you are setting droop? When you say 4.5mm ride height and 4.5mm droop, do you mean no droop at all?
the way i set droop is I put the ride height gauge under the chassis over the desired amount of droop. For example, if ride height is 4.5mm, I will lift the chassis to 5mm using the ride height gauge. Then adjusting the droop screw until that tire is barely touching the surface.
I don't use a specialized droop gauge.
So going off what you described.....your droop would be at .5mm correct?
STLNLST is offline   Reply With Quote
Old 02-28-2008, 10:35 PM   #11087
pcar951's Avatar
Trader Rating: 19 (100%+)
that is confusing...i usually refer droop to "how much you want the car to roll". Simple.
i guess that's one effect but what about front and rear weight transfer? droop also affects those actions and creates another synergy of reactions, right. i usually adjust roll characteristics with upper link angle and length and lower arm pivot height (roll center) and of course springs and sway bars to stiffen or soften the car to reduce or increase chassis roll.
hmmm, deep
pcar951 is offline   Reply With Quote
Old 02-29-2008, 07:50 AM   #11088
RC MARKET's Avatar
New HB Cyclone diff.
RC MARKET is offline   Reply With Quote
Old 02-29-2008, 10:03 AM   #11089
SammyZ's Avatar
Trader Rating: 138 (100%+)
do you have the new diff?
SammyZ is offline   Reply With Quote
Old 02-29-2008, 10:33 AM   #11090
RC MARKET's Avatar
HPI Japan web site posted MARCH release !
we was order !
Old 02-29-2008, 12:05 PM   #11091
SammyZ's Avatar
i found it!
the first one is the complete ball diff with 2.6mm diff screw and 3mm ceramic thrust balls, possibly a pair of new thrust washers?
the second is aluminum diff halves to replace the steel ones that come one the new diff!
i think' i'll stick with my stock WCE diff's
Old 02-29-2008, 12:53 PM   #11092
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
i found it!
Steel outdrives? You mean derlin?
If they were steel they wouldnt have rings..
Looks nice, I need to get some when my current ones are shot
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-29-2008, 05:14 PM   #11093
SammyZ's Avatar
I said the same thing! they certainly look like derlin, but the website said steel? Maybe they were confused LOL.
Whats your guess on the price?
Old 02-29-2008, 05:46 PM   #11094
Probably the same as the old set..
Old 02-29-2008, 06:18 PM   #11095
Sorry for the confusion. Yeah,The black one is POM(derlin) and the other one is the aluminum for option. those work excellent and smooth operation last very long.
thanks,
Hi-LowBlow is offline   Reply With Quote
Old 02-29-2008, 07:21 PM   #11096
LOSI123's Avatar
Trader Rating: 63 (100%+)
How common is it to bend or twist a bulkhead in a crash?
i have a tweaked chassis, and was wondering if its worth me totally disasembleing my whole car to check the bulk heads, or just order a new main lower deck.
the chassis wont sit totally flat on my setup board, & i have already tryed all the screws on top and bottom deck to try and fix it.
any advise welcome.....
LOSI123 is offline   Reply With Quote
Old 02-29-2008, 08:28 PM   #11097
There is one thing I noticed that your signature says "Futaba". Do you have a Futaba servo on your car? if so, you should check the chassis tweak with servo mounts screw off. it some time makes the chassis tweaked with the Futaba servo like 9550. If those servo mounts are making the chassis tweaked, you might need to grind the servo case a little bit. Please also make sure the servo is slightly floating. (there should be a little gap between the servo and the main chassis)
Thanks,
Old 02-29-2008, 09:45 PM   #11098
SammyZ's Avatar
why and how would a servo make the chassis tweak?
Old 02-29-2008, 09:52 PM   #11099
SammyZ's Avatar
you know those setup boards are not a perfect surface like glass? try putting the car on glass. I actually put mine on a peice of glass, had my mom hold the shock towers down, and I installed the top deck.
After that I put the car on my tweak station and it was flawless! I've never had a TC be flawless! im so glad it worked!
Old 02-29-2008, 10:02 PM   #11100
Believe me, if they werent perfect, then the ALL the top guys would have glass.... But you see pretty much all hudy boards
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
