Hot Bodies Cyclone
#1097
The bulkheads are still black are they? I can feel that purple "upgrade" verions by HB would be available in the near future.
#1098
Marc you thinking about getting the cyclone?
#1100
Trader Rating: 22 (100%+)
Originally Posted by Davo
Hey Josh are you buying a kit?
#1101
Originally Posted by Joehwee
Sorry for the confusion, the kit come only with 1 direct pulley for the rear. if you dun intend to run center 1 way, you will need to buy another direct pulley.
#1102
kit specs (have been posted on the MirageRacing.com - UK distributor - site for a few days)
Hot Bodies Cyclone Specifications:
Chassis Length: 365mm
Width: 190mm
Wheelbase: 256-259mm (adjustable)
Kit Weight: 1,430g (with electronics)
Drive System: 4WD Belt Drive
Camber: Adjustable Front & Rear
Caster: Adjustable Front
Toe: Adjustable Front & Rear
Roll Center: Adjustable Front & Rear
Down-Stops: Adjustable Front & Rear
Ride Height: Adjustable Front & Rear
Ackerman: Adjustable
Bump-Steer: Adjustable
Anti-Dive/Kick-Up: Adjustable
FEATURES:
50/50 Weight Distribution
Vertical Camber Link Adjustment
Adjustable Ball Bearing Single Bell Steering
One-Way Differential
Aluminium:
- Front Bulkhead
- Rear Bulkhead
- Middle Block
- Upper Bulkhead
- Steering Arm
- Pivot Blocks
- Threaded Racing Shocks
- Motor Mount
- Hex Clamp Hubs
- Spur Gear Adapter
Titanium:
- Purple Turnbuckles
Woven Graphite:
- Main Chassis
- Upper Deck
- Middle Deck
- Shock Towers
Carbon Plastic:
- Arms
- Uprights
- Hub Carriers
- Steering Blocks
Differentials:
- Rear Carbide Ball Diff
- Front One-Way Diff
64-Pitch Spur Gear
Drive Ratio 2.4375
Width: 190mm
FEATURES:
Aluminium:
- Front Bulkhead
- Rear Bulkhead
- Middle Block
- Upper Bulkhead
- Steering Arm
- Pivot Blocks
- Motor Mount
- Hex Clamp Hubs
- Spur Gear Adapter
Titanium:
Woven Graphite:
- Main Chassis
- Upper Deck
- Middle Deck
- Shock Towers
Carbon Plastic:
- Arms
- Uprights
- Hub Carriers
- Steering Blocks
Differentials:
64-Pitch Spur Gear
Drive Ratio 2.4375
#1103
TiRacing will be testing their prototype spool and driveshafts for the Cyclone at this weeks UK National (so I have heard). Good upgrades on the way!
#1104
what are the rear diff out drives made from?
#1105
same as Pro4 - Graphite plastic stuff
#1106
#1107
Can someone tell me if I have built the Diff correctly. The large belt pulley bit in the middle of the rear diff (not sure of the right name) just sits on the diff balls and can move side to side (couple of mm). Is this correct?
#1108
more like a purple Hara Edition or all black Surikarn Edition.
maybe I should wait til next year for these kits to be released with all the new option parts that are still under developement.
#1110
Which Pro 4 purpule driveshafts will fit the cyclone?
HPI80828
HPI75185
Cheers
HPI80828
HPI75185
Cheers
