Old 02-22-2008, 12:04 PM   #10996
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by B18C Turbo View Post
the car drives fine with 50wt oil all around, carpet or assphalt i find.
Alot of people normally will change oil from carpet to asphalt...the thicker oil for carpet is fine since most carpet tracks aren't as bumpy as asphalt, so the shocks can react slower...but it still comes down to a personal feel/perferance
I know back when I got my first TC3, we had a completely different set-up for carpet than outdoor - but then the carpet settings gradually starting coming outside
I need some nice weather so I can finally take my Cyclone outside and play - the guy I got it from ran it strictly on carpet, so I have a feeling I'll be making some changes for asphalt
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-22-2008, 06:36 PM   #10997
SammyZ's Avatar
Trader Rating: 138 (100%+)
I am soo happy that the Parma T2 bumpers fit the cyclone! I ordered 2 they rock!
My question is that do you sauce the tires, then put the tire warmers on? or vice versa?
SammyZ is offline   Reply With Quote
Old 02-22-2008, 10:07 PM   #10998
mangoman's Avatar
There are different tyre treatments, someone was telling me the other day that the oil based ones need to be baked in (i think thats what they said).
There are some which dont need to be baked though.
Generally speaking what i do is i put the traction compound on and bake the tyre then for the last 10-15 minutes wrap them in some paper toweling then put the warmers back on. The toweling helps to soak up any excess residue from the tyre otherwise the tyres can be slippery for the first couple of laps.
With my shocks i use 40wt oil (but then again ive never really played with the oil much as i hate rebuilding shocks, actually i should rephrase that to i hate doing any maintenance on my car!!!! :P)
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 02-22-2008, 10:37 PM   #10999
SammyZ's Avatar
ya rebuilding shocks is far too time consuming. How long are you supposed to bake the tires for and what temperatures? I have the CTX-w's from Muchmore.
Can I skip putting the napkin in between the warmer and tire during baking instead just wipe the tires off before putting it on the track?
Old 02-22-2008, 11:41 PM   #11000
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
i dont use tissue between the warmer and tyre u might have to depending what type of tyre ur using (sorex bigger than take off) as theres diffrent size cups for the much more tyre warmers.
and yeah just wipe it off if there is any residue. i have my warmers on 60 degrees and i put them on a couple of races before mine so around 15 minutes.
mild seven is offline   Reply With Quote
Old 02-22-2008, 11:41 PM   #11001
Hebiki's Avatar
Trader Rating: 26 (100%+)
any news about the new car from the TITC?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-22-2008, 11:48 PM   #11002
SammyZ's Avatar
its balogna. Probably just using the new parts liek the 18t pulley's, i saw some guys using the new 3.6mm chassis, nothing new.
Nothing wrong with the current cyclone, I love mine!
Old 02-23-2008, 01:44 AM   #11003
Crashmaster's Avatar
Jst found this (there are more) on the TITC Thread. Looks like new arms, cell inserts (ala DB). Maybe other bits, but I've only had the WCE for a week so I have no idea what the differences are!
Crashmaster is offline   Reply With Quote
Old 02-23-2008, 06:51 AM   #11004
SammyZ's Avatar
looks like the only thing different is the front and rear A-arms. The chassis cell slots are an option that was added recently with their new 3.6mm chassis. rumor is they will sell the slots seperatly.
Maybe they will start selling new Arms to update their cyclone even though theres nothing wrong with the Pro 4 arms.
Old 02-23-2008, 09:01 AM   #11005
mangoman's Avatar
I assume it will also be a new CF Chassis to fit those cell inserts, the holes will need to be wider to accommodate the cell inserts otherwise the batteries will sit higher in the chassis. (That is when you file the battery slots on an angle that gets the battery to sit in the chassis better and also slightly lower).
www.smaracing.org
Old 02-23-2008, 09:33 AM   #11006
Matt Pocknell's Avatar
I think also a new diff, but they have been testing with that for a while now.
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Old 02-23-2008, 11:53 AM   #11007
SammyZ's Avatar
yes i noticed trhe different upper bulkhead clamps are slightly different if you look close, im sure they also had to bore out the bulkheads some to fit those large outdrives.
But pretty much no crazy changes.
Old 02-23-2008, 03:15 PM   #11008
RC MARKET's Avatar
Yes in new type upper bulkhead !
& new sus. arm
Ball Diff maybe in EDIT release !
RC MARKET is offline   Reply With Quote
Old 02-23-2008, 05:24 PM   #11009
& new sus. arm
New 3mm Pro-Spec Ball Diff will be available pretty soon! (Yes, from HB. not Edit...)
you guys should check with the shape of the main chassis too
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 02-23-2008, 10:10 PM   #11010
SammyZ's Avatar
what was wrong with the old ball diff? Also what is being changed to 3mm, the diff balls, thrust balls, or both? or am i completely off
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
