Old 02-20-2008, 12:34 PM   #10981
LOSI123's Avatar
Trader Rating: 63 (100%+)
Originally Posted by B18C Turbo View Post
3.0 FD is pretty mucn impossible, I just don't see it happening as going to 3.5 is enough of a challenge. By switching to 18t pulley's and longer belts you drop half a point on your FD so its a must.
Shoot for a 3.5 FD for the 17.5 motor and a 4.0-4.5 for your 13.5 motor.
Precision racing systems sell a 76t spur and a 65t pinion , so yes its posible..
LOSI123 is offline   Reply With Quote
Old 02-20-2008, 12:43 PM   #10982
wikedgmc's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via MSN to wikedgmc
it is probably here somewhere but I could not find it, I would like to know what center pulleys are needed and new belts to lower the ratio of the car?
thanks
wikedgmc is offline   Reply With Quote
Old 02-20-2008, 01:33 PM   #10983
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Holy crap! 3.0 with the stock pulleys and belts is possible with that 76 and 65!
though by the looks of the 76, it doesnt look like it will fit into the adapter but who knows. Regardless, with a 87 spur from Spedtech and the 65t pinion from Precision, the FDR ends up being 3.26
anyone know if this will physically fit in the Cyclone? Wondering and thinking it will is great, but whether it can actually take a pinion that big....heh...anyone?
Syber Serulean is offline   Reply With Quote
Old 02-20-2008, 02:38 PM   #10984
Crashmaster's Avatar
Hi all,
Just getting back in racing again and picked up a MooreSpeed Cyclone and got a few questions.
The car has alloy Jet knuckles, c hubs and rear up rights on it, and I'm wondering what people thing of these (whether there likely to bend etc). Should I stick with these or put the standard composite parts on?
Also, can anyone recomend a spring set for the car, or failing the the springs that I'm most likely to need for tuning etc?
Cheers, and thanks for the help
Dan Chambers
Crashmaster is offline   Reply With Quote
Old 02-20-2008, 08:38 PM   #10985
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by Crashmaster View Post
Hi all,
Dan Chambers
Well for one your name is crashmaster...so I would stick with the aluminum
Anyways I only use aluminum c-hubs, steering knuckles, and rear hub carriers on all my cyclones. They look trick, they stay true, there super stiff, and there awsome! Keepem.
SammyZ is offline   Reply With Quote
Old 02-20-2008, 09:42 PM   #10986
mangoman's Avatar
Hi all,
Dan Chambers
For onroad asphalt you can pretty much get around with the gold (front) and silver (rear) springs which should be the kit springs for the wce (I hope i got the colours the right way around).
I personally dont use aluminium parts but the jet racing ones should be decent if you break a lot of parts when driving. I find 3 racing aluminium to be relatively weak (but cheap).
Personally Im a pretty ordinary driver but ive barely broken anything racing a lot of 19T and 5 cell mod (although im also not a very aggressive driver).
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 02-20-2008, 10:47 PM   #10987
SammyZ's Avatar
does anybody know the pound rate for the kit WCE springs?
Is it 17lbs gold
14lbs silver? Im not sure
Old 02-21-2008, 01:06 AM   #10988
Cheers Turbo and mangoman! Hoping I've left the crashmaster title behind now, not really sure how it came about in the first place..... Can't wait to run the car, got to wait till 23rd of March though Damn uni.....
Cheers for the help guys!
Old 02-21-2008, 07:33 AM   #10989
ShaunMac's Avatar
Is it 17lbs gold
HPI #6544 Gold = 19lbs
HPI #6543 Silver = 16.9lbs
ShaunMac is offline   Reply With Quote
Old 02-21-2008, 02:06 PM   #10990
Hmmm...
since i didnt get to set mine up before i raced it, i just looked at it and the springs on the back are the HPI blues and the fronts are HPI Pinks (the paper says they are Pro4 springs...you know).
Im starting to think that isnt too ideal of asphalt? What do you all think?
Old 02-21-2008, 02:31 PM   #10991
i have try all the hara springs and the car works the best with the stock springs gold and sliver
iceman76 is offline   Reply With Quote
Old 02-21-2008, 04:25 PM   #10992
NickM's Avatar
I've also tried all the hara springs and am back to running the stock gold/silver combo. Which is odd for me, as my xray FK05s were tuned for different tracks and conditions basically exclusively by spring changes. I'd make a few spring changes and the car would then be dialled. It doesn't seem to be the case with the cyclone.
TRF 416 | Corally Φ | TOP Scythe | F103GT
NickM is offline   Reply With Quote
Old 02-22-2008, 02:15 AM   #10993
xraysteve's Avatar
I WOULD GO WITH 20 OR 30 WEIGHT OIL FOR YOUR SHOCKS
lazer speedway everything else is a parking lot
xraysteve is offline   Reply With Quote
Old 02-22-2008, 05:57 AM   #10994
XraySteve is right.... I tried 50w and the car was hard to drive. I put in AS 30w and it drives very nice with the #3 or#4 pistons. I also found the stock gold and silver springs work the best out doors with rubber. I am going to try the pink 18 and blue 15.3, I think they might be A little better. I'v not tried 1lb moves away from stock.
Lazer Guy is offline   Reply With Quote
Old 02-22-2008, 11:37 AM   #10995
SammyZ's Avatar
the car drives fine with 50wt oil all around, carpet or assphalt i find.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
