Old 02-12-2008, 04:53 AM   #10846
Matt Pocknell's Avatar
Originally Posted by B18C Turbo View Post
what happens to this car when you run a spool? a one-way?
In general terms, a one-way gives lots of steering all the way through a corner, while the spool gives lots of steering on the mid/exit of a corner. A one-way is almost always fastest on carpet rubber, but difficult to drive consistently. Most people end up running a spool and setting it up to enter the corner well.
HTH
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Old 02-12-2008, 05:23 AM   #10847
mangoman's Avatar
Did you know HPI offers a "high traction" suspension arm set for the cyclone?!
HPI31420 includes 2 front arms and 2 rear arms for $9!
Yeah, they also come standard on the cheaper Cyclone S
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 02-12-2008, 07:56 AM   #10848
ShaunMac's Avatar
SWEET!
These are the same arms that come standard with the Cyclone S. They are more flexible than the graphite arms. This helps produce more traction. I ran these last year outside on low-traction asphalt.
You have to be careful when running the softer arms. The graphite arms will stay true until they break. The "high traction" nylon arms will take a big impact without breaking, but the arm will not be true anymore. It will bend or get twisted causing the car to do weird things. Depending on how the arm gets damaged, it can change your toe, camber, caster and droop settings.
If you run the "high traction" arms just be sure to check to make sure things are okay after a big impact and you'll be fine.
ShaunMac is offline   Reply With Quote
Old 02-12-2008, 08:06 AM   #10849
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Originally Posted by Syber Serulean View Post
whats the suggested differential setup style for medium sized asphalt tracks?
I originally thought one-way but i see alot of people using spools...
what about in the center as well?
Syber Serulean is offline   Reply With Quote
Old 02-12-2008, 08:26 AM   #10850
ShaunMac's Avatar
Fixed center pulley with spool in front.
Old 02-12-2008, 01:51 PM   #10851
is the fixed the regular one or anohter option?
Old 02-12-2008, 02:55 PM   #10852
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Fixed is the non one way pulley...
I think the normal cyclone comes with the center and front one way insted of the spool and direct center
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-12-2008, 04:33 PM   #10853
LOSI123's Avatar
Trader Rating: 63 (100%+)
for outdoor ashpelt rubber tyre racing, Front spool, and centre solid/fixed/locked is the way to go, in my opinion
LOSI123 is offline   Reply With Quote
Old 02-12-2008, 04:53 PM   #10854
I agree
I just got done shoe gooing my servo in... A local racer here (Scotty) shoe goo's his servo farther forward so he can fit a bigger RX on the chassis easier.... So I did the same, had to make a new servo horn, but I have a ton of room now, I can have a full size spektrum RX (the grey one) and my LRP TC sphere on the chassis long wise (so no elec's hang off the chassis)
Old 02-12-2008, 06:38 PM   #10855
Cool thanks. Just one more thing, im getting a Hara Cyclone (its on its way) and was wondering if said "solid/fixed/locked" center pulley is the stock one?
Old 02-12-2008, 07:00 PM   #10856
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
i think it comes with both types but not 100% sure
mild seven is online now   Reply With Quote
Old 02-12-2008, 07:10 PM   #10857
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to HVFracingwilly
syber, you will be getting a front one-way center one-way and a spool and a locked center pulley
Hobbytown USA Oshkosh
www.revolutionraceway.com
HVFracingwilly is offline   Reply With Quote
Old 02-12-2008, 08:07 PM   #10858
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by BlackedOutREVO View Post
I agree
Mine is done the same way. I can't wait to run my car for the first time. My Novak powered Cyclone is waiting to put the power down.
STLNLST is offline   Reply With Quote
Old 02-12-2008, 09:15 PM   #10859
Nice! Wheres the pics?
Are you going out saturday?
Old 02-12-2008, 09:31 PM   #10860
all seperate units? Sweet! Awesome you rock.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
