Old 09-20-2005, 02:47 AM   #1066
Originally Posted by Hugo
Did you have 1 or 2 direct center pulley???
u can choice TRF415 gear use in cyclone right side !
We weekend arrive all spare parts
& upper bulkhead easy broke !!!! take care !
HKRCMODEL is offline   Reply With Quote
Old 09-20-2005, 02:48 AM   #1067
& Cyclone have stock now !!
Old 09-20-2005, 06:48 AM   #1068
Trader Rating: 16 (94%+)
Originally Posted by jonny69
Hey, I have been building my car this evening and can not get the rear diff gear to sit 'tight'. There is alot of side to side play in the gear, the diff is definately tight and I can not work it out. If anyone can help that will be great. Thanks. Jonathan
i've also noticed this, it's quite disturbing having so much play in the gear
domo is offline   Reply With Quote
Old 09-20-2005, 08:08 AM   #1069
andyh's Avatar
Default Rear diff
....people, people, just drive it....
andyh is offline   Reply With Quote
Old 09-20-2005, 08:10 AM   #1070
Skill's Avatar
Has anyone actually experienced the upper bulkheads breaking? Where does it break exactly, I'm finding it hard to believe that something like that could break so easily.
Skill is offline   Reply With Quote
Old 09-20-2005, 08:15 AM   #1071
Tomorrow i will have some photo !
Because some driver was broke !
Old 09-20-2005, 09:31 AM   #1072
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Rite then,so it comes with-
all roll bars
1 way diff
1 way layshaft
and a fixed lay shaft
Correct? No spool?
What hubs are standard? and what degree piviot blocks come as standard?
Cheers
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 09-20-2005, 09:36 AM   #1073
rc-zombies's Avatar
Originally Posted by Joehwee
I have my cyclone yesterday, all the parts are correct. The kit also come with all the roll bars, center direct pulley , 1 way pulley, direct center shaft and 1 way center shaft.
I also find out that the Alum UJ are abt 1mm shorter than the pro4
I didn't think that it would come with all the roll bar set, direct center pulley etc.....
and who said this car was over priced... if you look at the similar YOK BD and add up the sway bars and direct drive gears etc......
it would cost equal or more than the cyclone.
Old 09-20-2005, 09:53 AM   #1074
Thats the thing witht this cyclone!!
Where are the specs of the kit!!! How can you realsese a car and leave everyone in the dark about what omes in the box!!
I want to buy the car and everything with it all in 1 go as i will be buying from HK! But how can i do that when i dont even no what comes in the feckin box!
Old 09-20-2005, 10:04 AM   #1075
all roll bars
1 way diff
1 way layshaft
Correct? No spool?
Cheers
It come with the following:
1 Way center and shaft,
One way front diff,
Shaft to lock the center drive but no locked pully,
All the roll bars,
2.5 deg front suspension block to give the arms some rearward sweep,
3 deg rear suspension block for 3 deg rear toe in.
Thats your lot.
Rick Draper is offline   Reply With Quote
Old 09-20-2005, 12:17 PM   #1076
Yes this week end arrive direct center pully , upper bilkhead ... all spare parts
Old 09-20-2005, 12:20 PM   #1077
Send a message via AIM to odawg315
Originally Posted by tcdrvr
Adrian & ODawg,
If there is one thing I don't have it is worn out cars. I've bought several cars this year alone from Yokomo, Corally, HPI. I haven't had them long enough to wear out the parts. What I was refering to that the Cyclone out of the box with only a few very minor changes handled far better than any car I have had. Unlike some other manufacturers cars where you have to buy aftermarket shocks, chassis, pulleys, steering bell-cranks, etc. to have a competitive car (You know what I mean) I only had to change springs in the front.
As far as the 415MSX I'm sure it will be a great car and probably handle better than any of it's predecessors, it ought to, it's only the third revision of the same chassis. Which I'm sure most of the Tamiya faithful are happy about since the original 415 is $345 then upgrade to a 415MS is $475 now to an MSX that is another $150 to $275. But you guys are right the Cyclone shouldn't be that impressive since it is Hotbodies first TC, albeit with HPI help.
Also if you paid attention to what I wrote I stated that the spool I had on the car was slipping so the car's handling was less than perfect.
bro, nobody is bashing your car, merely making a statement... everyone does... there new car is always better than there old one. whether its true or not, theyll always make that statement.
it was a joke...ha ha!!! either your a kid and need to ask your parents for a quarter to buy a sence of humor, or your an adult who needs to take a realty pill and realise were talking TOY CARS here!!!
odawg315 is offline   Reply With Quote
Old 09-20-2005, 12:21 PM   #1078
Will you receive the spool at the same time???
Hugo is offline   Reply With Quote
Old 09-20-2005, 12:58 PM   #1079
tcdrvr's Avatar
I didn't realize there was such a thing as a "realty" pill
I understand that they are toy cars, maybe I should've made my original comments clearer since stating that "it's better than anything I've driven" does come across as "I got a new car and I like it better than my old car."
What I meant to communicate was that after switching through various cars with various setups, the Cyclone has the "feel" I have been looking for in that it has lots of steering and traction at the same time, with very little done to the car. Hopefully that clarifies what I meant.
tcdrvr is offline   Reply With Quote
Old 09-20-2005, 01:04 PM   #1080
One way front diff,
All the roll bars,
Thats your lot.
1 way layshaft
1 way front diff
Shaft to lock the center drive but no locked pully?? huh
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
