Old 02-06-2008, 10:28 AM   #10756
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
STLNLST. haha yeah I'm getting sick of the slow site. But good info here!!
I'm not positive if you add one more bearing, but I think thats what you do. Idk wobbly pulleys ifnt messing anything up, why does it matter???? Its bugs me a little bit to, but not much anymore.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-06-2008, 10:37 AM   #10757
pcar951's Avatar
Trader Rating: 19 (100%+)
forget the pulley wobble, it's fine, floating as another dude said. my diffs work best with carbide balls, wet sand the rings with at least #600. xray lube is the smoothest, schumacher lube stays the best, hpi lube is a balance of both. assoc black grease in the thrust is good, hpi grey is better if you have some. cyclone diffs are the smoothest of any when built correctly...period.
pcar951 is offline   Reply With Quote
Old 02-06-2008, 11:27 AM   #10758
Originally Posted by B18C Turbo View Post
I wanna use a titanium hinge pin for the BMI chassis rear. I need a titanium 3x48mm pin, who makes it?
Xray T2 pins are what I use.
Lazer Guy is offline   Reply With Quote
Old 02-06-2008, 12:00 PM   #10759
STLNLST's Avatar
[QUOTE=BlackedOutREVO;4153195]STLNLST. haha yeah I'm getting sick of the slow site. But good info here!!
QUOTE]
what good is the info if you can't access it....LOL Looks like the weather is getting better so I might be out for some practice once I get over this pnuemonia
STLNLST is offline   Reply With Quote
Old 02-06-2008, 12:02 PM   #10760
STLNLST's Avatar
Originally Posted by Marcos.J View Post
just get the xray ones if not just get any and then just cut them to size
I'm still a cyclone virgin. I still haven't picked out a new name for the chassis With all this time off work maybe I'll come up with something.
Old 02-06-2008, 12:06 PM   #10761
what good is the info if you can't access it....LOL Looks like the weather is getting better so I might be out for some practice once I get over this pnuemonia[/QUOTE]
I should be ordering my speedo, and starting on parts soon! I want to use my cyclone so bad!
Old 02-06-2008, 12:13 PM   #10762
STLNLST's Avatar
I should be ordering my speedo, and starting on parts soon! I want to use my cyclone so bad![/QUOTE]
did you destroy it the last time out?
Old 02-06-2008, 12:20 PM   #10763
Just ask Scotty LOL..... He will tell you how it always is.
I used plastic out drives, and Scotty said do the alu ones, The diff screw is still good, but im getting a new one anyways, then I need carbide diff balls, thrust washers, D rings
Then I need to get the shims, 3 hole pistons, 50, and 55 wt shock oil, and a 1.5deg toe block for the set up
And then I need to replace a few screws and thats about it
Old 02-06-2008, 12:25 PM   #10764
STLNLST's Avatar
Geez man. I replaced my diff screw with an AE one because it's thicker. Even the Ti coated moore one is suspect. IMO You better get to ordering or go to Billy's.
Old 02-06-2008, 12:32 PM   #10765
I dont have problems with the screw anymore, I just want to have new stuff in the car..... Then there should be problems because some parts are new, and others arent...... I just want to have a car the works
What washers, and balls did you use to put the AE one in?
And I just got off the phone with Billy, I just need the $$$ to buy it
Old 02-06-2008, 01:03 PM   #10766
STLNLST's Avatar
I got what ever Scotty put in the bag when I was at Billy's. He set my car up exactly the way his is.
Old 02-06-2008, 01:07 PM   #10767
Could you ask him what he used?
Is he using the AE screw also?
Old 02-06-2008, 02:45 PM   #10768
Trader Rating: 46 (100%+)
Hi Cyclone owner
One questions. On the regular (black version) kit that comes with center one-way and one way diff, how would the car drive if I just change the one way diff to a spool and leave the center one way pulley alone?
Yellowtaro is offline   Reply With Quote
Old 02-06-2008, 03:02 PM   #10769
Originally Posted by Yellowtaro View Post
Hi Cyclone owner
Crappy (IMO).... Because the front would be a spool no matter what, so you would have no brakes, and you loose front power off power..
I wouldnt do it
Old 02-06-2008, 04:36 PM   #10770
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
what about front diff + center one-way?
Syber Serulean is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
