Old 02-05-2008, 05:17 PM   #10741
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Woz View Post
i know im going to get my head blown off for this, but i use the xray tape. works a treat.
not blown off but maybe slapped around a little....
STLNLST is offline   Reply With Quote
Old 02-05-2008, 05:18 PM   #10742
STLNLST's Avatar
Old 02-05-2008, 05:27 PM   #10743
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by syndr0me View Post
The IRS tape is the only way to go. I double it up and use one piece for an entire day.
https://www.ssl-stormerhobbies.com/c...2&showbig=6809
If you read that description and then look around, you can find the original source of the tape (Scotch) for a lot cheaper around the internets.
I have seen that, I wondered how well it worked
I am going to have to try some when I run out of my current roll
Way to post 4 times STLNLST........ lol
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-05-2008, 06:30 PM   #10744
Woz
they sell that stuff trackside for 50p a roll
Woz is offline   Reply With Quote
Old 02-05-2008, 07:16 PM   #10745
ShaunMac's Avatar
Originally Posted by Lazer Guy View Post
OK ! Great back to set ups.
My Cyclone hooks coming out of corners on power,,,, Going in and middle corner is good, Did it with a Diff and now with a spool and a one way. I am now running.
0* front toe pivot block and have used 1* and 1.5* never more then 1.5* in front.
3* rear toe pivot block.
2mm under ball studs in front, 1.5mm back.
1.5mm under pivot blocks front and back.
4 degree caster.
long front and back links, tried short and middle, still hooked coming out.
1.4 sway bar front none in back but tried 1.2 in back and it was worse.
22lbs front 19lbs back springs.
10.5 motor.
Small technical track with 180* and 90* corners.
Rubber tires and carpet.
BMI 3mm chassis, stock upper chassis.
Man if I could get it to stop hooking coming out I would be one happy guy. Any help would be much appreciated.
Are you running the car with a shorter or longer wheelbase? I have run with the wheelbase on the short side and the car would over rotate very easy. I moved the wheelbase out long and it smoothed the car out nicely. Also, narrowing the rear track width(narrow hexes) will give the car more rear traction at corner exit.
You may also look at your droop settings. Running a little more droop in the front(greater mm above ride height) will help transfer more weight to the rear when your on-power exiting the corner.
I would play with different springs too. I was running pretty soft(16lbs) in the rear at the Snowbirds and it really calmed the car down and kept the rear end planted in the 19T Rubber Class.
These are just a few suggestions. Change one thing at a time and good luck to you.
ShaunMac is offline   Reply With Quote
Old 02-05-2008, 07:27 PM   #10746
Trader Rating: 22 (100%+)
What's the ideal gearing ratio for 27T stock racing?
SantozRey is offline   Reply With Quote
Old 02-05-2008, 09:55 PM   #10747
SammyZ's Avatar
Trader Rating: 138 (100%+)
are your diff pulley's wobbly? Mine are! I have some play in the pulley and it looks retarded, not much but enough that i can wiggle the pulley in between the outdrives.
SammyZ is offline   Reply With Quote
Old 02-05-2008, 10:15 PM   #10748
Thats been normal since the first cyclone......
To take the slop out I *Think* that you put one more bearing in-between the out drives
Old 02-05-2008, 11:14 PM   #10749
SammyZ's Avatar
holy crap! 1 more bearing? are you serious?
Old 02-05-2008, 11:47 PM   #10750
LOSI123's Avatar
Trader Rating: 63 (100%+)
its normal to woble, its a "floating pulley" . Nothing is wrong with you car!!!!
Team Durango - Speed Passion - Gens Ace
LOSI123 is offline   Reply With Quote
Old 02-06-2008, 06:26 AM   #10751
ShaunMac
Thank you very much for your help !!!!!!
The BMI chassis is 2mm longer witch will let me move the rear wheels back 2mm more then the stock chassis. I have not tried moving it back all the way yet. I will try all the suggestions you have given me and thanks again.
Lazer Guy is offline   Reply With Quote
Old 02-06-2008, 08:01 AM   #10752
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default DIFFS
Anyone have any building tips for diffs with alum. outdrives? I bought the Hotbodies outdrives in hopse they will be more solid and work better.
Associathed stealth lube for diff balls and black grease for the thrust balls? Locktite for the Titanium coated set screw?
Jaz
Jaz406 is offline   Reply With Quote
Old 02-06-2008, 08:20 AM   #10753
STLNLST's Avatar
not my fault this site keeps freezing up. I may just stick with rcracing.com......LOL
Old 02-06-2008, 11:21 AM   #10754
SammyZ's Avatar
ShaunMac
I wanna use a titanium hinge pin for the BMI chassis rear. I need a titanium 3x48mm pin, who makes it?
Old 02-06-2008, 11:23 AM   #10755
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
just get the xray ones if not just get any and then just cut them to size
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
