Old 02-04-2008, 12:19 PM   #10726
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Originally Posted by BlackedOutREVO View Post
Yes... I dont, but my buddy swapped from a cyclone S, to a normal cyclone, and he just drilled, and countersunk 2 holes to screw the posts down, and it works pretty good
anyway to do it without drilling?
Syber Serulean is offline   Reply With Quote
Old 02-04-2008, 03:26 PM   #10727
SammyZ's Avatar
Trader Rating: 138 (100%+)
what happens when you switch from 0, 1, 1.5, 2 and 2.5 degree blocks in the front?
SammyZ is offline   Reply With Quote
Old 02-04-2008, 03:33 PM   #10728
LOSI123's Avatar
Trader Rating: 63 (100%+)
apparently the higher the number of the front toe block the more aggresive steering you will get, providing you re-adjust the camber and ride height and toe back to where they where before you changed the block, as changing the block will effect all these things......
Team Durango - Speed Passion - Gens Ace
LOSI123 is offline   Reply With Quote
Old 02-04-2008, 04:02 PM   #10729
SammyZ's Avatar
by aggresive(sp?) do you mean more steering?
Old 02-04-2008, 04:05 PM   #10730
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Not that I know of...... I use tape
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-04-2008, 04:10 PM   #10731
LOSI123's Avatar
yes more
Old 02-04-2008, 06:04 PM   #10732
dang! whats the magical way to get tape to work without having the batteries fall out all the time?
Im already trying to figure out a work around...
does tape thats part velcro exist? Would rock if it could be regular strong fiber-type tape as it goes underneath the chassis then over the top of the batteries it can be velcro style stuff...hmmm....
i just got the perfect idea for a battery strap. But uh...now that i think about it, it wouldnt work without help. The holes for the tape to pass through...well i figured id get some really strong reinforced tape or zip ties or something and modify a battery strap from a different car to loop through the bar and then tighten the tape/velcro/whaterver down to pull and tighten down the battery strap over the batteries. After i thought about it though, id require a stopper id have to loop through then pass the tape (or whatever materieal i use) through the slot for the tape, the stopper would have to be really long and flat or tapered so as to not add any thickness or portrude from the bottom of the chassis. Thats the problem lol. Seemed like a good idea to me at first but that last bit made me sad. I wouldnt even know how to make/find a loop holder/stopper like that. I was hoping there would be two holes so i can loop through the slots instead...boooo....
then again i need to get a good look at a cyclone to really know what im doing lol.
Old 02-04-2008, 06:52 PM   #10733
Buy nice tape..... I buy tape from Intertape, its black, and it comes in a huge roll, its sticky, and strong as heck! Its like 10 bucks a roll at my track (speed world raceway) And then you have to file/shave the bottom of the chassis where the tape goes into the chassis... And then after that, I double up my tape just to make sure, so tape the batt in, and then put another round of tape on
Im still on my same roll after a race season, and TONS of practice, and I still have a good bit left.... You can use the same set of tape for atleast a race day
Old 02-05-2008, 01:23 AM   #10734
SammyZ's Avatar
just use strapping tape from your hardware store, thats what the R/C industry uses but they jack up the price. This strapping tape is less than $4/roll at your hardware store.
Old 02-05-2008, 08:47 AM   #10735
STLNLST's Avatar
Trader Rating: 17 (100%+)
using tape to secure your batteries in should almost be 99% effective. Unless you're using some real cheesey tape you shouldn't have any problems.
STLNLST is offline   Reply With Quote
Old 02-05-2008, 03:59 PM   #10736
Old 02-05-2008, 05:00 PM   #10737
Woz
i know im going to get my head blown off for this, but i use the xray tape. works a treat.
Woz is offline   Reply With Quote
Old 02-05-2008, 05:11 PM   #10738
syndr0me's Avatar
Trader Rating: 32 (100%+)
The IRS tape is the only way to go. I double it up and use one piece for an entire day.
https://www.ssl-stormerhobbies.com/c...2&showbig=6809
If you read that description and then look around, you can find the original source of the tape (Scotch) for a lot cheaper around the internets.
syndr0me is offline   Reply With Quote
Old 02-05-2008, 05:16 PM   #10739
STLNLST's Avatar
not blown off but maybe slapped around a little....
Old 02-05-2008, 05:17 PM   #10740
STLNLST's Avatar
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
