Old 02-03-2008, 10:05 PM   #10711
SammyZ's Avatar
Trader Rating: 138 (100%+)
I need a setup for rubber tires on carpet, im sure its been asked 1000x.
Also would you run the 2.5 degree pivot block up front for this?
SammyZ is offline   Reply With Quote
Old 02-03-2008, 10:07 PM   #10712
Trader Rating: 194 (99%+)
I ran an S last year and a Black Cyclone. I like the S better. I wanted to see how well the S could run. I ran the stock setup and it was very good in 19T rubber tire racing. Ran the stock dogbones well lubed. I ran diffs fr and rr. The diff half's are ok. The inner steem that the diff pulley rides on break easy. So I use the 3Racing rear ally diff half's. I did not run a spool up front due to the spool I had was a V1 and the bones are V2. the center pully does wear faster with 19t racing. So the 3Racing or stock Cyclone center pulley will work.
The stock S shocks are great. I did not have any problems with them.
Over all the S ran very well for the money. Also run the carbon C hubs and a P-Dub front bumper.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-03-2008, 10:47 PM   #10713
Guy1966's Avatar
Default Help
Could some one please help me?
What is the best diff?
ONE WAY or
SPOOL?
For stock 27t or 13.5 Brushless.
Thanks GUY
Guy1966 is offline   Reply With Quote
Old 02-03-2008, 10:50 PM   #10714
mangoman's Avatar
Yeah with all the plastic parts and softer (high traction) arms the Cyclone S handles very well on asphalt. It is a little heavy though (but you cant have it all :P)
Ive also had the post on the diff halves which the pulley sits on snap a couple of times. Its probably more suited to stock and 540 racing. If you find the diff keeps undoing itself every run, then the post has probably snapped off.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 02-03-2008, 10:52 PM   #10715
mangoman's Avatar
ONE WAY or
SPOOL?
Thanks GUY
Depending on driving style the diff or one-way will be better for 27T, if the track is big and open you might be able to use a spool with a 13.5
Personally though i would go with the one-way as you shouldnt be needing brakes.
www.smaracing.org
Old 02-03-2008, 11:07 PM   #10716
Guy1966's Avatar
Thumbs up Thanks
I race at the St Ives club at Narrabeen.
Old 02-03-2008, 11:08 PM   #10717
SammyZ's Avatar
any setup sheets for rubber tire on carpet?
Old 02-04-2008, 12:46 AM   #10718
The standard carpet setup here works well:
http://www.hbeurope.com/setups.php?partNo=66450&lang=en
If the rear end is a little twitchy, removing the rear roll bar settles it down nicely.
THancock is offline   Reply With Quote
Old 02-04-2008, 01:48 AM   #10719
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
any easy ways to modify the cyclone to use a battery strap or velcro straps?
Syber Serulean is offline   Reply With Quote
Old 02-04-2008, 07:15 AM   #10720
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Yes... I dont, but my buddy swapped from a cyclone S, to a normal cyclone, and he just drilled, and countersunk 2 holes to screw the posts down, and it works pretty good
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-04-2008, 09:17 AM   #10721
SammyZ's Avatar
he ran a spool on carpet? I heard never to do that? Am i wrong? Also what would happen if I switched from the 2.5 degree front pivot block to a 0 degree in the front for carpet & rubber.
Old 02-04-2008, 10:20 AM   #10722
Matt Pocknell's Avatar
When it comes to rubber on carpet, a spool works very well. Here in the UK, most people running in the modified/19 class use a spool.
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Old 02-04-2008, 10:31 AM   #10723
I did post the following a week ago!
Originally Posted by Arn0 View Post
Not a hardcore rubber tire guy but look this page http://www.petitrc.com/view_news.php?id=4553 for Phil Chambers - Starting Setup Carpet or Jean Marc Betticher - SITCC RD4, 23T or Jean Marc Betticher - CRF - Katana 23T
Hope that helpful
Arn0 is offline   Reply With Quote
Old 02-04-2008, 10:34 AM   #10724
OK ! Great back to set ups.
My Cyclone hooks coming out of corners on power,,,, Going in and middle corner is good, Did it with a Diff and now with a spool and a one way. I am now running.
0* front toe pivot block and have used 1* and 1.5* never more then 1.5* in front.
3* rear toe pivot block.
2mm under ball studs in front, 1.5mm back.
1.5mm under pivot blocks front and back.
4 degree caster.
long front and back links, tried short and middle, still hooked coming out.
1.4 sway bar front none in back but tried 1.2 in back and it was worse.
22lbs front 19lbs back springs.
10.5 motor.
Small technical track with 180* and 90* corners.
Rubber tires and carpet.
BMI 3mm chassis, stock upper chassis.
Man if I could get it to stop hooking coming out I would be one happy guy. Any help would be much appreciated.
Lazer Guy is offline   Reply With Quote
Old 02-04-2008, 10:37 AM   #10725
Essnowyt's Avatar
Send a message via AIM to Essnowyt
PM me your email. I have a few that will get you started.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is online now   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
