Old 01-27-2008, 06:18 PM   #10636
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by ASM View Post
Honestly, I sell (in my opinion) some of the best diff lube you can buy. However, I don't have any stock right now and may not for awhile due to several factors. Check out my site and you'll see why I came up with it. I even addressed the "runny" issue that STLNLST spoke of. My local hobby shop does have it in stock and I believe Superior Hobbies in Orlando may have some as well.
www.wickedfastracing.com
PNP Hobbies 321-723-7318
Superior Hobbies 407-834-9299
Marcos, remind me to give you some to try...LOL.
good ole ASM. How have you been bro? I haven't talked to you in a while. I'll see if Michael Bruce has it in stock along with some other things. I don't want to pay to ship just a small thing of lube.....but if it works then hey....ship it away!
STLNLST is offline   Reply With Quote
Old 01-27-2008, 06:40 PM   #10637
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
cool ill take you up in that!!
Old 01-27-2008, 06:43 PM   #10638
Trader Rating: 22 (100%+)
Tamiya 501X pulley's.... who's done the conversion? How is it working for you?
(37T 501X pulley's w/ 18T center pulley's)
SantozRey is offline   Reply With Quote
Old 01-27-2008, 07:16 PM   #10639
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I think rc zombies has done that...
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-27-2008, 08:15 PM   #10640
STLNLST's Avatar
Originally Posted by pcar951 View Post
I installed the 18T pulleys and longer belts, a must if you're gonna run
17.5,13.5 or 10.5 brushless. The pulleys are OK but I found the front belt to be a little long, there's no adjustment left once the tension is set. If it wasn't such a pain, I'd tear it down again and try a used (stretched) stock belt maybe. Overall though, it's alot easier to deal with the 2.16 ratio for brushless. I also run regularly on a smallish carpet track with foams.
I heard that the newer belts for the 18tooth pulley seem a bit too long. I'm mostly running mod some I don't need to run the lower gear ratio's but I may run 19turn every now and then and Hope I can hit the 5.2 ratio I like running the 10.5 at. Are people having problems with ratio's with the regular pulley?
Old 01-28-2008, 04:21 AM   #10641
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Hey man everything is good....mostly just raising kids. Can you say 3 in college...with one more to go!! It's good to see you on the same thread. Remember those "old" schumacher days?
I have the new pulleys and belts and ran them for the first time last week-end. It was nice to be able to back down on the pinion size. Personally, I'm NOT finding any issues with belt length. Mine actually seemed to fit real nice.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 01-28-2008, 10:11 AM   #10642
SammyZ's Avatar
Trader Rating: 138 (100%+)
feel free to use your stock belts with the new 18t pulley's.
SammyZ is offline   Reply With Quote
Old 01-28-2008, 10:19 AM   #10643
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Installed the new belts on mine with no issues, not too loose- not too tight...are you haveng issues after running them for a while?
Blizzard Concepts ~Big-Dog Graphics
Cyclone ~ Orion ~ LRP Sphere ~ S9550
M03 ~ Orion ~ LRP QC3 ~ S9550
RC18R ~ Castle Creations ~ Hi-tec
Slash ~ 9550 ~ SMC Power
8ight-T~9550~V-Spec
rcarmchl is offline   Reply With Quote
Old 01-28-2008, 10:29 AM   #10644
SammyZ's Avatar
the belts feel really good using the 18t pulley's with stock belts (62t and 169t)
Acutually the front belt feels so good I have chosen to remove the tensioner, it looks cleaner without it and has the proper tension.
Old 01-28-2008, 10:54 AM   #10645
rc-zombies's Avatar
Works Great!
hard getting into the low 5's FDR without going to a small spur and large pinions.
Old 01-28-2008, 11:27 AM   #10646
Woz
70t spur, 34t pinion is 5FDR on normal pulley&belts
outdoor closest i have got so far for 13.5 outdoor is 66/40 ~ 4FDR
Still feel the need for more push though
48dp pitch
Last edited by Woz; 01-28-2008 at 12:51 PM. Reason: pitch (64pitch wouldn't work), wrong pinion sizes
Woz is offline   Reply With Quote
Old 01-28-2008, 12:31 PM   #10647
a 100 spur and a 47 pinion is a 5.2 ratio I believe.... Or atleast thats the ratio I used in stock...
Old 01-28-2008, 12:58 PM   #10648
Stew Noble's Avatar
It's a stabliser, not a tensioner.....it's there to make sure theres no excessive up-and-down movement from the belt.
It should be set to be very slightly above the belt, not touching it.
// S N F //
Stew Noble is offline   Reply With Quote
Old 01-28-2008, 01:18 PM   #10649
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default rubber carpet setup
For all you hardcore rubber tire guys in the us and europe....
Is their a standard starting setup for indoor carpet for stock/19t?
Jamie
J.Gonzalez is offline   Reply With Quote
Old 01-28-2008, 01:56 PM   #10650
Is their a standard starting setup for indoor for stock/19t?
Not a hardcore rubber tire guy but look this page http://www.petitrc.com/view_news.php?id=4553 for Phil Chambers - Starting Setup Carpet or Jean Marc Betticher - SITCC RD4, 23T or Jean Marc Betticher - CRF - Katana 23T
Hope that helpful
Arn0 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
