Old 01-27-2008, 11:24 AM   #10621
Trader Rating: 8 (83%+)
Originally Posted by B18C Turbo View Post
what happened to the shocks that were on their man?
i got a cyclone s lol
i730 is offline   Reply With Quote
Old 01-27-2008, 11:51 AM   #10622
SammyZ's Avatar
Trader Rating: 138 (100%+)
dang man, i just looked into getting some nice HB shocks, they want $20 for a pair of bodies, $8 for a pair of lower caps, $8 for a pair of upper caps, $3 for shocks parts, $8 for a pair of titanium shock parts, $2 for o-rings, $3 for bladders, $2 for reboudn foams, $2 for shock pistons, $2 for e-clips, then $20 for aluminum spring perches, then another $8 for a pair of spring collars.
I think once you get all of it, cost you at least $100.
SammyZ is offline   Reply With Quote
Old 01-27-2008, 12:20 PM   #10623
if i go that way ill keep my current rods and eclips and orings unless the rings need changing
Old 01-27-2008, 02:28 PM   #10624
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by MonkeyNuts View Post
Don't touch the 3Racing shock as they are rubbish.
This has probably been asked already but has anyone found that the new center pulleys(18t) and belts(170t,63t) make any difference as i wouldn't mind getting them if they do. I run on a small indoor carpet track.
Liam
I installed the 18T pulleys and longer belts, a must if you're gonna run
17.5,13.5 or 10.5 brushless. The pulleys are OK but I found the front belt to be a little long, there's no adjustment left once the tension is set. If it wasn't such a pain, I'd tear it down again and try a used (stretched) stock belt maybe. Overall though, it's alot easier to deal with the 2.16 ratio for brushless. I also run regularly on a smallish carpet track with foams.
pcar951 is offline   Reply With Quote
Old 01-27-2008, 02:30 PM   #10625
SammyZ's Avatar
yeah man from the sounds of it, just a set of 4 shock bodies is $40, upper caps $16, lower caps $16, spring perches, $20, springs $10, spring collars $20, even using your old parts still comes out to way over $100 lol.
Old 01-27-2008, 02:31 PM   #10626
HarshGuy's Avatar
Originally Posted by BlackedOutREVO View Post
You put the diff together, and put it in the car, and tighten it till you cant make the pulley slip, you want the diff as loose as possible... But if it slips, that just makes your diffs crunchy fast.....
You could always boil them.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-27-2008, 02:32 PM   #10627
SammyZ's Avatar
I used the stock 62t and 169t belts and havent ran into any slack or over tensioned issues, good deal!
Old 01-27-2008, 02:34 PM   #10628
SammyZ's Avatar
ive never heard of boiling diffs, what does that do?
Old 01-27-2008, 02:46 PM   #10629
Yup, tried the grease thing and still didn't like the way they worked. Honestly, I don't have much trouble with my pulleys being open but I race primarily on indoor carpet right. I rarely race outdoors.
The diff stickers work great for me and I am racing carpet now. Anything that helps keep my diff working longer is a good thing so I think everybody should give them a try and see for your self.
Lazer Guy is offline   Reply With Quote
Old 01-27-2008, 02:55 PM   #10630
2-Bad's Avatar
Trader Rating: 24 (100%+)
What I use for a spare set of Shocks are the ones from HPI. They run a small cap, but effectively they are the same in how they feel and function. I can't remember where I got mine, but Speedtech have them listed for $34US (but out of stock).
2-Bad is offline   Reply With Quote
Old 01-27-2008, 03:17 PM   #10631
Woz
HP75194 - threaded shock set
Woz is offline   Reply With Quote
Old 01-27-2008, 03:42 PM   #10632
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
LOL, Its a inside joke...... Long story lol
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-27-2008, 05:24 PM   #10633
SammyZ's Avatar
that is for a pair of HPI shocks, there about $38 and you dont get aluminum spring pirches, or aluminum shock bushings, nor do you get titanium shock shafts. After you get those parts and 2 sets of these your at about $130.
Old 01-27-2008, 06:03 PM   #10634
maybe ill get some tamiya trf shocks and have them re annodized purple lol
Old 01-27-2008, 06:13 PM   #10635
starting in about three weeks i will be annodizing parts so if u want other then blue or purple let me know PM
iceman76 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
