Old 01-23-2008, 10:10 AM   #10561
SammyZ's Avatar
Trader Rating: 138 (100%+)
looking for a good setup for a moore-speed using foams on carpet
SammyZ is offline   Reply With Quote
Old 01-23-2008, 10:27 AM   #10562
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
i have a great set up but it calls for the BMI chassis it may work with the regular chassis just dont know.
Old 01-23-2008, 10:41 AM   #10563
SammyZ's Avatar
hey Marco, i would really appreciate that setup, although I don't have the BMI chassis, im planning on picking up the HB 3.6mm chassis once $$ comes around. But that setup will really help.
Oh and I don't wanna rebuild my shocks again, i just did them last night with stock pistons and AE 50wt oil all around. Gold springs up front with silvers in the rear, no rebound foams in the rear.
Old 01-23-2008, 11:59 AM   #10564
ICEMAN's Avatar
Put some Rubbers on that Clone and Run it. Leave the foams at home.
Blizzard Concepts / Team Losi / Team ProMatch / Team MuchMore / The SPEED Shop / Ko Propo USA / AVID RC / BigDog Graphics / Nitro R/C Chop Shop /
The ONE that DIES with the Most Toys WINS!!!
ICEMAN is offline   Reply With Quote
Old 01-23-2008, 12:06 PM   #10565
ShaunMac's Avatar
Here's the winning stock foam set-up from the Snowbirds last year. You have to take into account that the traction level at the Snowbirds is insane!
MarcosJ - You going to the Snowbirds this year?
ShaunMac is offline   Reply With Quote
Old 01-23-2008, 12:34 PM   #10566
Drifter73's Avatar
what is the bennefit of useing aluminum c-hubs and othe componets?
Drifter73 is offline   Reply With Quote
Old 01-23-2008, 01:00 PM   #10567
SammyZ's Avatar
hey man thanks for that setup sheet!
I plan on running 4 degrees castor for our low-medium grip carpet, did that setup sheet call for 6 degrees since it was high grip?
Old 01-23-2008, 02:55 PM   #10568
tomracing's Avatar
Originally Posted by LOSI123 View Post
I have a setup station and i want to measure steering throw on the out side wheel (as i heard this is where to measure it)
can any one tell me in detail how to get 20 degrees throw on the outside wheel, as even at maximum throw mine is at about 17 degrees?
sorry to get back to this one but as i just bought a setup station after borrowing my friend's for a while first i just figured out the following
integy version measures the inside wheel angle
hudy measures the outside wheel angle.
now to get a spare plate from the other brand and you can actually tell the ackermann function from both readouts.....
tomracing is offline   Reply With Quote
Old 01-23-2008, 04:10 PM   #10569
2-Bad's Avatar
Trader Rating: 24 (100%+)
IMO, there isn't any, other then your wallet will be lighter....
2-Bad is offline   Reply With Quote
Old 01-23-2008, 08:47 PM   #10570
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
anyone have a decent asphalt/parking lot set-up for MOD?
I'm sure it might be somewhere in this thread, but 300+ pages is a little much to go thru
thanks!!
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-23-2008, 11:00 PM   #10571
pcar951's Avatar
Trader Rating: 19 (100%+)
Try this, it's decent and very consistent for a 2.5 chassis setup. Sorry about the scan quality and penmanship.
pcar951 is online now   Reply With Quote
Old 01-24-2008, 09:59 AM   #10572
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default Diff problems
I'm running a 13.5 pro with rubber tires. One way in front and diff in back.
The diff will come loose after one run. I have plastic out drives and a new titanium screw and nut. I have broke them in and tightened them in steps and they loosen or will snap the screw over time.
I can get some alum. out drives will this help?
Jaz406 is offline   Reply With Quote
Old 01-24-2008, 09:59 AM   #10573
SammyZ's Avatar
Guys, I ordered HPIa495 39t ball diff pulley for the cyclone. I got it and it has wider pulley teeth than the HOT61050 pulley. Also the HPI pulley has larger cut outs in the diff ball section to hold the diff balls, so the diff balls can move up and down, whereas in the Hotbodies pulley they can't.
Stormer hobbies and speedtechrc.com both have the HPIA495 pulley listed as a balldiff pulley for the cyclone. If you look at your manual, it calls for HOT61050. Although both pulleys have the same bearing diamater and thickness, it looks like the HPI pulley woudl work beside the fact the pulley for the belt is wider and the diff balls may move around.
Anyone have experience with this?
Old 01-24-2008, 10:04 AM   #10574
I think that older cyclones use the a495 pulley. The newer ones use the hot bodies 61050 pulley.
bionictony is offline   Reply With Quote
Old 01-24-2008, 10:14 AM   #10575
RC MARKET's Avatar
yes new one is HB61050
RC MARKET is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
